Question about Toshiba Satellite Pro L350-S1001X Notebook
Toshiba L350 203 PSLD8E running XP Home Edition
Hi I have a Toshiba L350 203 PSLD8E I have installed XP and updated my drivers However my graphics are glitchy on Games that previously worked flawlessly when i had Vista installed.
I removed Vista in favour for XP because I use it for work and have not had the time to learn the in and outs of this OS.
I used the official XP drivers from the Toshiba Site and everything seems ok aprt from this issue with the Video Controller.
Please help I would appreciate it a lot!
PLEASE NOTE: Toshiba L350 203 PSLD8E was not listed in your "What product is it about?"
  • 1 more comment
  • allan_oneill Apr 17, 2009
    @ gough2960, No that is not the one. I used a manufacturers driver download (6.14.10.4953).
    Sutchman I think in this instance the manufacturers offer is flawed, My laptop came preinstalled with Vista, which I removed. Now Toshiba's Site has drivers for XP so i DL them and installed.
  • Anonymous Apr 17, 2009
    BUMP
  • Mark Gough May 11, 2010
    is this the display driver you used?
    driver_video_intel_27407A.exe
  • 48 Answers
Find out what graphics card you have. Go to the manufacturer website of the graphics card and download the latest XP driver.
Posted on Apr 17, 2009
Latest graphics driver for Toshiba a55 s1063
run the update utility,be sure to allow active x control to run when drop down box appears say run,otherwise it wont work follow this link to get started
http://www.intel.com/support/graphics/detect.htm
hope this helps,aloha from maui todd0708
Oct 22, 2009 | Toshiba Satellite A55-S1063 Notebook
My graphics card is fast at one point then slows down!
Make sure the driver for the notebook from the manufacturers website is installed, and not the video driver from Microsoft's Windows Update. After that, update Java, Adobe Flash and Adobe Shockwave. Finally, check for updates for DirectX (version 9.0C). Post back your results, please.
Sep 21, 2009 | Compaq Presario Notebook
I have a Toshiba satellite L350 PSLD8E and the DVD drive has gon
I had similar issues (but with L300). At the toshiba site i downloaded some win7 updates, and now all is good. try here: http://support.toshiba-tie.co.jp/windows7/download/Satellite_L300_32_au.htm
Jul 20, 2009 | Toshiba SD C2502 Internal DVD Drive
How to install usb
After you install Microsoft Windows XP Service Pack 2 on a computer that is running Microsoft Windows XP, the universal serial bus (USB) drivers do not appear to update. CAUSE After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers... loadTOCNode(1, 'cause'); After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers appear with the earlier version numbers, even though the files have been updated. uparrow.gifBack to the top RESOLUTION To resolve this problem, install Windows XP SP2, and then update the drivers for... loadTOCNode(1, 'resolution'); To resolve this problem, install Windows XP SP2, and then update the drivers for the USB devices that are connected to your computer. To update these drivers, follow these steps:
  1. Click Start, click Run, type devmgmt.msc, and then click OK.
  2. Double-click the type of device that you want to update.
  3. Double-click the specific device that you want to update.
  4. Click the Driver tab, and then click Update Driver.
  5. Follow the instructions in the Hardware Update Wizard.
  6. Repeat steps 2 through 5 for each USB device.
Note You can also install Windows XP SP2, and then disconnect and reconnect the USB devices that are connected to your computer. By doing this, you start the Plug and Play utility. The Plug and Play utility updates the version numbers for the drivers.
May 08, 2009 | Microsoft Windows XP Home Edition
Gigabyte GA-MA790FX-DQ6 installation problems
Hi speedfreak44, during the installation of windows one of the drivers did not install correctly & windows registry is messed up.
The blue screen is a typical response from windows. Even though you're windows installed SP2, there are another 89+ updates for SP2. (A reinstall with-out a format is not advised).
Suggest you enter you're bios & disable ACPI. This one I know for sure will show up in windows device manager as a PCI device with no name. Try again to boot windows. If it still fails to enter in standard mode than a complete re-install will be required including a format. Personally I do not use windows XP pro/home w/SP2 CD to perform the format, (After receiving a blue screen).
I have found it is 98% better to use the software tools, downloaded from the Mfg's web site for you're hard drive. Use the bootable software (On a floppy or CD), to format you're hard drive. Most Mfg's hard drive software will allow you to change the cluster size up. Windows standard uses a 4kb cluster size & you loose far more hard drive space. With a 16kb you loose only the file allocation or FAT, which is normal.
Than using the Win XP CD/SP2 install windows, clean.
(No need to format).
When finished installing windows, load the Gigabyte driver CD & install the chipset & other CD drivers. Turn on windows firewall & update windows SP2. (ASAP), (Save SP3 update for later).
It is in the updates of windows to iron out software & hardware driver updates. Do not install you're antivirus software until windows has finished updating its self & you install any hardware updates also through windows update. (Continue to leave the ACPI disabled in bios until updating is complete).
You can enable ACPI, antivirus software & printer software all.
You will find some needed software will install during windows update. Like; Quad Core processor update. With either home edition or pro it is advised to install .Net framework updates 1 at a time & only restart when prompted by windows. Other wise click the refresh button & continue windows updating. (You can save the .Net framework updates for last if you wish). You're video card may need .Net framework 2.0 or better for installation.
I am hell bent on installing windows once & correctly the first time. I understand you want to get this baby up & running but take the time & run the hard drive tools/utilities. (It's worth it)!
Good Luck speedfreak44!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Please let me know if this got you're system running without the blue screens?
One last item. It's also worth checking the dates on the Gigabyte CD to Gigabyte's web site before installing other drivers. Including the chipset drivers. You want to install the newest drivers the first time around. Here is the link to you're Gigabyte GA-MA790FX-DQ6 motherboard main web site.
(Click on the link).
http://www.giga-byte.com/Support/Motherboard/Manual_Model.aspx?ProductID=2690
Mike
May 27, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
O S disc, Toshiba L35-S1054
No unfortunately XP home and XP media edition are different but not completely. The only difference is the entertainment factor like TV control and live recording and pausing , viewing photos etc and media center is considered to be a bit more secure than XP home but i find this just a wrong perception of people as i also have XP home and also had media center, makes no difference at all regarding security but yes if u want much more features or facilities as far as entertainment is considered media center edition is far more good than XP home.......
IF U INSTALL XP HOME THAT DOES NOT MEAN U INSTALLED XP MEDIA CENTER
Now there are 2 ways to solve ur problem
1. Either get a NEW disc from microsoft or any computer shop for media center and then install it.
OR
2. Install XP home on your system and then try to put the CD for media center , it will update XP to media center . In this way u will get the media center back and u will also not lose any previous stored data.
NOTE: In both the above cases u will have to get the CD for Media center......
Wat matters is losing the data that is already stored on your system.
BUT AGAIN I WOULD LIKE TO REMIND HERE IS THAT INSTALLING XP HOME WILL NOT GET BACK U TO MEDIA CENTER AS THEY ARE DIFFERENT BUT IT MAKES NOT DIFFERENCE WHETHER IT IS XP HOME OR MEDIA CENTER AS ONLY DIFFERENCE IS ENTERTAINMENT>>> IN THE WORLD THERE ARE MORE PEOPLE USING XP HOME THAN MEDIA CENTER>>>
I would recommend to cont. with XP home
Feb 19, 2008 | Computers & Internet
TOSHIBA LAPTOP DRIVER
It looks like that there are so many brothers here with the similar problems as I. I bought the Toshiba Satellite A135-S2386 with Vista Home Basic on it. And, of course, I wiped out the Vista and installed the XP Home. Like most people, I had 6 unfound drivers at first. Thanks to the previous posts, I got video cards, wireless and SM bus working.smile.gif Now, I still can't get modem and two other unknown devices to work.frown.gif Can anyone help me this?biggrin.gif My Drivers does not load From CD. Like Vidio Controller, Graphics etc.. Lindly Send me The Drivers so that I Can Up Load My Labtop Mode No. A 135- S2386. Toshiba Satellite Doul-Core Inside Please Help & Mail me the Drivers Thanks....
Dec 07, 2007 | Computers & Internet
Toshiba Satellite Pro L350-S1001X Notebook Logo
548 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
