It does not want to spin correctly. It makes some awful noises too when it spins.
  • 121 Answers
If it is a whirlpool that will be the clutch coupling
Posted on Apr 17, 2009
My washing machine does not stop filling up it runs over.It still spins the water out, but was making an awful grinding noise.
FIRST, IF IT DOESNT STOP FILLING YOU EITHER HAVE A CLOGGED VACUUM LINE OR A BAD PRESSURE SWITCH. AS FOR THE NOISE WHEN IT SPINS, TAKE OFF THE BELT, CHECK PULLEY FOR THE MOTOR AND PUMP, IT SHOULD SPIN FREELY AND TIGHT. IF THEY BOTH GOOD, AND THE NOISE IS AROUND THE MIDDLE OF THE TUB ON TOP OF THE TRANSMISSION, MEANS YOU HAVE A BAD TUB BEARING
BOYNISMO@YAHOO.COM OR 714-334-1998. I CAN WALK YOU THROUGH THE PROCESS IF NEEDED.
Jan 14, 2010 | Admiral Washing Machines
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
Awful noise won't rinse wash or spin, on my whirlpool washer
http://www.youtube.com/watch?v=WLPGs2UMUJc
This video will show how to replace the direct drive coupling that runs the transmission.
Jul 05, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
During the spin cycle it makes an awful clanging noise and will not spin.
Replace the direct drive coupling between the motor and transmission.
Jun 27, 2009 | Kenmore Washing Machines
Making an awful ratcheting noise during aggitation and spin cycles
Under the agitator there is a rachet mechanism that works the agitator. If it is stripped, it will skip until the next good tooth.. when it fails entirely the agitater will stop going back and forth. Its nylon and age along with overloading hastens its dearg.. If you can get the parts you can replace it yourself without difficulty. There is a single bolt in the center of the agitator top . Remove and loft agiyator straight up.
Jun 03, 2009 | Maytag Legacy Series Top Load Washer
Agitator ''dogs'' not gripping, agitator spins freely; tub rocks
Likely a broken dog itself was making the noise. They should all be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Kenmore Washing Machines
Spins during agitation makes noise
Welcome to FIxya
I would check the belt and i would also check the bearing
hard to help you out with out seeing it but i would check those first ....
hope this helps out have a good day :)
Oct 29, 2007 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
