Question about Saeco Magic De Luxe Espresso Machine
No response from control panel
Just got a Magic Deluxe as a gift. Powersource is confirmed, but I get absaloutley no response from any of the buttons on the control pannel. The warning lights seem to function but the unit just doesn't do anything. Please help!!
  • bansheracer May 11, 2010
    Hi
    Do you have any lights on the top row lite?
  • 1,089 Answers
Try this
Brew group missing indicator
Open the door on the right. Push on the upper left side of the brew unit until you hear a click. Close the door and see if the message is gone. If it is make sure that the grounds drawer is in place.
Tip: Pull the grounds drawer out, then push it back with only 1 finger and push it on the right side of the drawer. This will make sure that it engages the micro switch.
Posted on May 28, 2009
Kenmore dishwasher will not start cycle
Possible that the main controller unit is faulty which must be confirmed. Remove power and then switch on with the start button pressed ON. If there is no response on the panel or input valve opening to allow water flow then the control panel needs to be checked with consensus and estimate.
Nov 29, 2011 | Kenmore Dishwashers
The dryer stopped in the middle of a load, the display showing fast up-scrolling numbers...clearly faulting. Upon resetting it, including pressing back button, unplugging it, power button off/holds, I can...
It seems that the main board, the program controller unit is a suspect and to confirm you need to remove the customer control panel and check . Check the +5 to the processor, check the connectors and the power supply, check for leak in the storage electronic capacitors, check for faulty voltage to the control board.- check rectifier and regulators.
If not the fault can be the processor which must be confirmed with a data check or oscillations of the crystal.
Sep 29, 2011 | Asko T761 Electric Dryer
Panel won't light on Saeco Magic Delux
Sounds like a board issue. It was something that happened on the Saeco Magic Deluxe's enough to be noticed. The board is not available for magic deluxe's with oval buttons.
Parts for your magic deluxe
May 29, 2011 | Saeco Magic De Luxe Espresso Machine
Where is the magic focus button?
Most Sony Rear Projection TV have a small door under the screen with some manual controls. Push on spring loaded door to open. Magic Focus is near the bottom and labeled.
If Magic Focus does not restore for correct operation, check the Convergence Gallery to confirm if you have a convergence fault that needs repair. #8 is the Sony menu.
easyab@hotmail.com
Feb 11, 2011 | Sony KP-57WS500 57" Rear Projection...
Margin settings
You have to hold the magic margin button down while you move the carriage all the way to the left, then release the margin button. Then repeat for thr right margin. Hold the right magic margin button down while moving the carriage all the way to the right, then release the margin button.
Sep 05, 2009 | Office Equipment & Supplies
Saeco Magic Deluxe resets itself before completing brew cycle
Hi Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that doesn't fix it, then you might need a new flow meter.
Jun 12, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Deluxe - Coffee Cold,Lights not working
The thermoblock (boiler) element is burnt out and must be replaced.
Feb 10, 2009 | Saeco Magic De Luxe Espresso Machine
Using adobe reader 9 on a document which read fine on version 7 returns the error "root missing or invalid"
Solution 1
Upgrade to StuffIt 8.5, then unstuff the archive again. See Allume's Web site at
for more information.
Solution 2
Change the cross-platform preference in StuffIt, Magic Menu, or StuffIt Deluxe then re-extract the PDF file:
1. In StuffIt or Magic Menu, choose File > Preferences. In StuffIt Deluxe, choose Edit > Preferences.
2. Click the Cross-Platform icon on the left of the Preferences dialog box.
3. Select Never in the Convert text files to Macintosh format section, then click OK.
4. Re-extract the PDF file:
- If you're using StuffIt, drag the archive onto the StuffIt icon.
- If you're using Magic Menu, select the archive and then choose Expand from the Magic Menu.
- If you're using StuffIt Deluxe, press Control+Command while double-clicking the archive.
Regards
Samson Ved
Dec 17, 2008 | Computers & Internet
Magic De Luxe Frother won't work!
means you do have the hot water button pushed and not just the steam function.
Follow this SAECO
Jun 03, 2008 | Saeco Magic De Luxe Espresso Machine
Can't set up
You can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For replacement remotes visit www.sparky-uk.com)
Jan 14, 2008 | One For All URC-3445 Remote Control
Saeco Magic De Luxe Espresso Machine Logo
98 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
