I have had this for almost a year now and all of the sudden now when I open the play list menu the top option is 'New playlist on the go' like it should be, but under it are 7 options of 'Delete a playlist' and if i scroll past them everything in the menu changes to what looks like Arabic, but i'm not sure. And if I try to scroll up instead of down it just has a bunch of blank options.
SOURCE: on the go playlist
on the MP3 player, go to the song(s) that you'd like to have on the "on the go" playlist, and if you search the sides on the device, you'll see a button that says "Playlist." Push that, and it'll automatically be added.
SOURCE: "Playlist On The Go" on a Philips 4 GB SA6045 mp3 player.
I just figured out how you clear the songs from the "playlist to go". go to playlist to go, then when it shows the songs you have added press the up button and you will see the words "clear playlist to go", press the forward button and it will ask you to clear it or cancel, select clear and it will tell you it's cleared.
SOURCE: no playlist found
One of the pesky features of windows Media Player is that if you delete the song/playlist from the computer's harddrive, and then resync your device to that same computer, then oftentimes the song/playlist disappears. Reacquire the song/playlist, and then try resyncing to the goGear again.
-Tha Mp3 Doctor
SOURCE: Philips SA3125\02 MP3 Player playlist
Plug it in *Before* you start WMP. then open it, make the play list, select them all and right click and click "sync". if that doesn't work look at the help file.
SOURCE: Philips GoGear SA3245 - Playlists Not Showing Up on Player
a letter i received from the Phillips Consumer Care:
We understand that you were unable to sync the playlist you created to
your Flash audio player. Please be informed that this unit is unable
to support playlist created on the computer. The playlist must be
created on the device. Please click on the link below to access the
user's manual:
http://www.p4c.philips.com/files/s/sa3245_37/sa3245_37_dfu_aen.pdf
Please refer to page 10 for information on what buttons to push to add
or delete currently playing song to list. Please refer to page 17
which shows how to to view songs in list.
Menu-Audio
player--Playlists-Create playlist--Now create playlist as you want-Now select
same playlist which you have created-Options-Add-Now if you want to add single
song, please click on song name and song will be added-if you want to add
multiple song, then select "Multi" option from left side of the bottom-Mark the
multi songs -Now press "Done" from left side of the bottom-Now select the first
option of "Play" to play songs of playlist.
Mayank Purohit
