Question about Lexmark Optra M410 Laser Printer
How do I install a fuser for Lexmark m412 - Lexmark Optra M410 Laser Printer
  • 320 Answers
On the back of the printer there is a door (outer rear cover) open this to about 35deg and lift it off. half way down the inner rear coverthere are 2 no2 philipps head screws remove these at the top of this inner cover there are 2 clips set in alittle about 2 inches down from the top 1 on the right and 1 on the left with a scxrewdriver depress these clips with a slight out ward pressure the cover will come free. now on the right side you will see a black palstic cover with one screww at the top unscrew this about an 1/8 of an inch or take it all the way out pull the cover towards you to remove it. you can see the fuser by now there is one screw on each side about an inch up from the flat deck remove these. some of these fusers have a ground wire remove the screw from it. remove the 6 or 7 pin connector rom the fuser control board. this might also have a 2 pin connector that youll need to unplug these will both be headed to the upper right side ofthe printer. pull them up out of the way. grab the fuser in the middle and pull straight backwards and its out.
Posted on Oct 24, 2009
    Genius:
  • 1,018 Answers
Lexmark supplies two types of replacable units.
Customer Replaceable Unit (CRU) and Field Replaceable Unit (FRU).
A fuser is a FRU and as such should only be reolaced by a factory trained technician.
Plase place a service call.
Don
Posted on May 26, 2009
4 Suggested Answers
don_farr
  • 1018 Answers
SOURCE: Lexmark Optra M412 pritner find IP address
Have you printed out the printer's Menu Settings?
Posted on Jun 30, 2009
  • 3 Answers
SOURCE: 921 service fuser error
NO THE LAMP IS BAD
Posted on May 13, 2010
mariolands
  • 2296 Answers
SOURCE: We have an Optra M412 that has a 921 Service
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
You can find the fuser at the back of the printer, remove the cover and there it is. It holds in two screws and a power connection. If the printer is out of warranty, your next option is to change the fuser which costs around $200, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Posted on Mar 09, 2011
Hello, I replaced the fuser on my 734de and I still get fuser life warning
Did you replace the fuser with a new Lexmark fuser or a refurbished unit? The original Lexmark units have a chip in them that resets the counter when installed. However this only works the first time the fuser is installed. If you install a used fuser in a different printer it will not reset the counter.
Sep 30, 2014 | Lexmark Office Equipment & Supplies
935 service printer head error. how do I fix it?
The Mirror Motor of the printhead is unable to reach operating speed. This means you have to replace the printhead.
Mar 08, 2011 | Lexmark Optra M412 Laser Printer
I don't have a owners manuknow how to change the paper trays from
Go to Menu, then Paper Menu. Select Paper Source then select Manual Feeder. You should also select manual feeder from the driver.
I'd like to add the link to download the User's Guide for future reference. http://www.lexmark.com/publications/pdfs/optram410/enUser.pdf. Hope this helps. Leave a comment if you need more assistance. Thanks.
Jun 29, 2010 | Lexmark Optra M412 Laser Printer
We have an Optra M412 that has a 921 Service fuser error. We don't know where to find the fuser
Sep 19, 2009 | Lexmark Optra M412 Laser Printer
Squeeks even after oiling
Sometimes the squeaks come from the drum inside the cartridge. If you remove the cartridge and power on and don't hear the squeaks, it's in the cartridge and not the printer...
Sep 15, 2009 | Lexmark Optra M412 Laser Printer
Jun 30, 2009 | Lexmark Optra M412 Laser Printer
Lexmark Optra M412
error 939 means --
RIP Communications Lost
Controller EngineCommunications Lost
The controller board and the engine board cannot
communicate with one another.
Solution --
POR several times
Check each board
for secure ground.
Replace the assys
in the following
order
1. Controller Bd
2. Engine Board
3. Intterconnect
  Board
Dec 12, 2008 | Lexmark Optra M412 Laser Printer
Load MP Feeder
That is not an error message. it is telling you to load the Manual Paper feeder. Put some papaer in it and it will print. check youyr set up to make sure that you are printing to the trays not the manual feeder
Nov 20, 2008 | Lexmark Optra M412 Laser Printer
Lexmark Optra M410 Laser Printer Logo
234 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
