Question about Intermec (T2480B3B45061) Network Terminal
Menu is Blocked error
Intermec 2480 fixed terminal displays error message "Menu is Blocked"
Look for, and scan, the "Enable Override" barcode in the Intermec Trakker Antares 2400 Family System Manual, available in the manuals section of intermec.com.
Posted on May 20, 2009
Error message is "Out of Paper". how to solve this error?
Hi Good day.. This error message means you have ran out of paper, you must must load a paper and then click continue, the printer should print now..
Regards:
JR
Oct 06, 2010 | Intermec EasyCoder PM4i Printer
How to reset factory defaults to CK31? How I can put the settings to access WPA2 in wireless network?
Restoring Default Settings
You can restore the CK31 to factory default settings from
Intermec Settings.
Note: Using the Restore Defaults option restores all parameters
including network settings. When you choose to restore defaults,
you erase the registry. As a result, you may lose network
communications.
To restore factory default settings
1 From Intermec Settings, select Device Settings > Restore
Defaults.
2 Select Restore Defaults and choose the Run App button. A
Run Application dialog box appears asking if you want to run
the restore defaults program.
www.portablesolutions.com
May 12, 2010 | Intermec CK31 Portable Terminal
Unit will not boot. Screen reads
"Check serial Input" is just part of the cycle on boot up. It checks for a key press on boot up so that it can access a hidden menu. A cradle, serial null modem cable and hyper-terminal is required to bring up this menu
You can try and re-install the operating system.
Download the latest image from Intermec (you will need to register) and then load the image onto an SD card.
Remove the front cover just above the scan engine; 2 slot head screws and insert the SD card. Cold boot the device. Take off battery and hit the reset button a few times. Re-install battery.
Image will begin to reload.
Detailed instructions are available with the download.
NOTE: The latest image downloads from Intermec not longer have the Telnet application pre-installed. If you require the telnet client then select a previous version, but then also not that there are usually 2 versions EX25 and non-EX25 scan engine type.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Oct 29, 2009 | Intermec CK31 Portable Terminal
Intermec CK30 Error Opening Wedge Problem
I was getting the same error and resolved it by removing the battery and pressing the reset button. When you turn the scanner back on all the data will still be intact.
Apr 24, 2009 | Intermec CK30 Handheld Computer
Intermec CK30 Won't Display Desktop
The ck30 does not have a desktop. Press the green then orange key to access the system menu. Alt then escape will bring up the task manager.
Nov 27, 2008 | Intermec CK30
Connect MC9090-G to an Intermec 2100 Access Point
Make sure that the ESS ID and security features match the ones on the AP.
Also, from the MC9090, you will need to click on the radio icon, select options and in the top drop down menu, choose regulatory. select the country where you are and uncheck the box named enable 802.11d.
This should have the terminal connected on to the network.
Jul 11, 2008 | Symbol MC9090 Barcode Scanner
Intermec 761B - ITCScan dll issue
Copy and paste the ITScan.dll file to as follows
c:windows/
and
c:windows/system/
and
c:windows/system32/
Please rate SOLVED if you like my solution.
Best regards,
Philip
Nov 02, 2007 | Intermec 761B Portable Terminal
"Protection Error"
the DVD is blocked in PAL system, ¿ How I can the DVD in NTSC system ? the menu is blocked. thank
Sep 24, 2007 | Toshiba SD-43HTS System
Intermec (T2480B3B45061) Network Terminal Logo
144 people viewed this question
Top Intermec Computers & Internet Experts
Computer Repairing
Computer Repairing
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
