Question about Konica Minolta Office Equipment & Supplies
Biz hub C252
Error code C2551
    Sniper:
  • 108 Answers
I have found that if you don't use make a lot of color copies the toner can bind up in the cartridge. Pull out the cyan toner, shake it up and tap on it, and reinstall into copier. This has fixed 99% of problems with this error code and the others related to TCR sensors for colors. If it is a new toner make sure the black gear didn't fall off of the back of the cartridge.
Posted on May 12, 2010
  • 24 Answers
YOU CAN RE-TONE THE MACHINE BY ENTERING SERVICE MODE SELECTING IMAGE PROCESS ADJUSTMENT AND TCR SUPPLY SELECT THE COLOUR THAT IS DEFICIENT AND RUN THE SUPPLY JUST ONCE. BEFORE YOU DO THIS CHECK THAT THE SEALING STRIP ON THE TONERS HAS COME AWAY AND NOT STUCK OVER THE HOLE HENCE STARVING THE MACHINE OF TONER.
Posted on Jul 27, 2009
C2551 Abnormally low toner density
detected cyan TCR sensor
• TC ratio in the developing machine, which is
determined by toner replenishing amount control
mechanism, is 5 % or less for a given number of
times consecutively.
Posted on Apr 21, 2009
Error c252
no such code for bizhub c252
Apr 01, 2014 | Konica Minolta bizhub C250 All-In-One...
Biz Hub C252 is printing dark
The machine probably needs a service and the gradations needs to be set.
Sep 27, 2013 | Konica Minolta bizhub C250 All-In-One...
Error code c1144
I have 5 biz hub 654s. There is no "utility" hardware button. Instead, open the front cover (marked "biz hub 654") - switch off the main power - white switch in an orange rectangle. Wait 30 secs. Flip back on- then QUICKLY close the door while holding down the yellow RESET button. "Trouble reset" appears - tap it - OK appears below it. Use main power to power down. Wait 30 seconds. Power back up. Works every time.
Nov 01, 2012 | Konica Minolta Office Equipment & Supplies
Biz Hub C250 - code error C2551
Ahhh, you must be the same Macdaniel I emailed for clarification a short while ago.
C2551 relates to the Cyan imaging unit, the machine thinks the toner level inside the Cyan imaging unit is low.
Opening and shutting the main front door is the reset procedure. However if this doesn't work you should try the following
Remove the Cyan imaging unit, give it a bit of a shake and then refit.
Experience tells me that the above only works on occasion and you will probably require a new imaging unit. They are available for around £250.
Please be aware that the fault could also be down to a circuit board being defective, but this is less common.
Regards
Taminol
May 22, 2009 | Konica Minolta bizhub C250 All-In-One...
To enter service mode on biz hub c 500 what is the key order?
Lost my access to add employee name to scan docs Biz 500/420
Jan 22, 2009 | Konica Minolta bizhub C250 All-In-One...
767 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
