Deck top got pack up for new house and dose'nt won;t to cotackme on green light flashes in the back but no power to the s
Just moved boxed up the pc hooked it up at the new house green flashing light on the back of unit but no power to the stack please advise .. fuse breaker... thanks
  • bass0566 Apr 17, 2009
    packed up pc worked great got to new house won;t boot up green light flashin in the back but no power to the stack ......help
  • Barry Parks May 11, 2010
    What make and model computer is it?
  • 27 Answers
Prob:no power to mainboard
solution: Take cover off the side of unit find memory modules and reseat the mem sticks also find power harness usually clear or white w/ plug goin to main board unplug and reseat try to power up!
Posted on Aug 02, 2009
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
I have a Gateway 310 XL H desk top PC. After the storm, Isaac, It won't power on. The red and green lights come on, the red goes off after a short time. The monitor flashes a manfacture logo then
The system is powered up if green light on, the hard disk is powered up if red-light on for a few seconds then goes off, but I assume it's not loading up after that. You have no output to video.
Try holding f2 or f4 to load default bios when turning on. If that doesnt work then That would point to me that there is a problem with either:
1) processor burnt out, or needs refitting following a knock to the case causing a bad connection.
2) ram burnt out or not correctly installed. Try refitting the ram or using a different combination of ram.
3. Bios chip burnt out. Sometimes you can literally see the chip is slightly melted.
4. Other motherboard fault, look for melted chip or damaged component.
5. Psu faulty or not connected properly. Check connections, or bench test with another psu.
Have you moved the pc recently? Sometimes dust builds up under processor or along ram, and when moving pc giving it a slight knock can cause bad connection. If dusty, remove clean and re install.
Hope it helps.
Sep 05, 2012 | Gateway 310 S PC Desktop
Power supply flashes green and no lights on laptop
Remove battery pack, press and hold power button for 5 seconds, then put battery pack back in and restart pc. This should take care of it. A bad memory stick can cause problems like this as well.
Nov 12, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Canon ip4300 service error b200 green and orange light keep flashing ink toner won`t move
Try this:
Pull the power cord out of the back of the printer.
Then move the printhead to the center and pull out the ink and the printhead. Clean the printhead and examine the bottom for burned areas.
With the printhead still out, close the cover and plug the power in and turn the power on. If your printer isn't damaged, it should go through all diagnostics and give you a solic green light. This means you probably need a new printhead.
Apr 17, 2009 | Office Equipment & Supplies
Sony Bravia KDL-46Z4100 Standby light flashing 13 times
This sounds like a power source problem! (faulty transformer) I would pack it up and take it back for a new one!
This is a problem you can not fix yourself unless your a pro!
Please rate my response!
Jan 15, 2009 | Sony BRAVIA KDL-40V3000 Television
Lines across my screen
That is possible, If you want, see if the problem goes away by shutting off the power to that circuit. "Patio Lights" Or Deck Lights and see if problem goes away. Or you can move set to another area in the home and see if problem goes away. Are you using a cable box by the way? Let me know if this helped you . Have a good afternoon. Jay
Jan 15, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Moved and now my comuter wont do anything
Try reseating the memory.  I have moved computers and 9 times out of ten the memory came loose.  So just take out the sticks make sure they're not too dusty then put them back in.
Oct 16, 2007 | Compaq Presario 5000 PC Desktop
Xbox 360 wireless controller
You must sync the 360 with your controller. Turn on your 360 and your controller. Push the little black button on the front of your console, then hold the little tiny button on the top of your controller for a few seconds. This should sync them.
May 19, 2007 | Microsoft MS Xbox 360 Common Controller...
Computers & Internet Logo
238 people viewed this question
David Payne
David Payne
