Question about Whirlpool Duet GHW9150P Front Load Washer
Washer takes forever to complete cycle
Sometimes will display sudslock. Have been using He detergent and have been using less than the recomended amount, so I don't know what is up. Any ideas?
  • khallstrom Apr 17, 2009
    I took the bottom panel off as I found out there is a sheet down there. It mentioned that there is a pump filter. I found it and opened it up. The thing was full of "stuff". I emptied it and things are better.
    One note, be sure all the water is out before you unscrew that thing, or you'll get wet. Thanks
    Problem Solver:
  • 9 Answers
SOUNDS LIKE YOU ARE STILL PUTTING TO MUCH DETERGENT IN IT. TRY CUTTING IT BACK A LITTLE MORE!! MINE DID THE SAME THING, THE SUDS LITE LIT UP AND AFTER ABOUT 5-10 MINUTES IT RESOLVED ITSELF WHICH IT IS SUPPOSE TO DO. I CUT BACK AND HAVE HAD NO PROBLEM SINCE
Posted on Apr 17, 2009
Am I using the wrong kind of detergent?
Could be. The instruction manual could provide guidance. Sometimes manufacturers are very specific about what to use and how to use it.
Aug 22, 2015 | GE WSXH208A Front Load Washer
I have a maytage neptune washer mah8700a that displays "suds". It runs several additional rinse cycles before completing the wash. Have switched to tide and run much less soap. Tried an empty load on
Are you using detergent that is rated for HE (high-efficiency) washers? They are manufactured to require less per load and produce fewer suds. Conventional detergents in HE washers will result in over-sudsing.
Dec 22, 2014 | Neptune Washing Machines
Every other wash sd code come on
The SD error code is caused by using the wrong detergent or excessive amounts of detergent.
To correct the issue: Make sure to use HE detergent. Note: Using Non - HE Detergent will cause oversudsing and can damage the washer. Do not use too much detergent.
Note: If using HE 2x - 5x concentrate detergent, reduce the amount being used. The washer will try to run a mini-clean out cycle using cold water and a 5 minute pause to clear the suds. If this cycle does not clear the display and complete the cycle the clothing may need to be rinsed by hand and then rewashed without detergent.
Feb 18, 2013 | Maytag Bravos MTW6600T Top Load Washer
My washer stops in the middle of the cycle and displays F-1 and after I have to set it on the rinse / drain cycle to complete. Today for the first time it also displayed 5d at the end of the cycle.
5d or Sd means too much detergent was used. Try the following
Run the unit through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Jun 29, 2010 | Kenmore HE2 Plus Front Load Washer
Oe error code, cleaned filter, checked hose
You might be using too much detergent and causing a sudslock condition. The machine uses very little water and any amount over a teaspoon of HE will simply cause the machine to lock down. An OE error means it took longer than 10 minutes to drain the tub. IF the machine is trying to correct a sud problem it will continually toss in more water till sudslock is corrected. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
Jun 04, 2010 | LG WM2277H Front Load Washer
Soap suds on the door at the end of a wash cycle. Miele E526
With all modern front loading washers, you might find that the amount of detergent you need is much less than what is recommended by the detergent makers!
First, be sure you're using the He (High Efficiency) detergent and try using only 2 or 3 tablespoons of detergent. If you've heavily stained clothes, be sure to pre-treat them rather than adding more detergent. That should also help with the extra soap left in the clothes after a complete wash cycle.
Give this a try and adjust the detergent as needed to get the best results for your situation.
Hope you find this Very Helpful and best regard!
Sep 22, 2009 | Miele Novotronic Premier 500 Front Load...
Washer has timing issue, says it will wash for 45 minutes and wash for 1 hour and 15 minutes.
try using less detergent. I found the more i detergent I used the longer it took for the cycle to complete.
Mar 28, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My washer is flashing sud...what do i do?
SUD mean you may have put too much soap in the load. (I'm a technician and I did the same thing this weekend "OOPS") I ran out of HE Detergent and used some I had laying around.
The washer will go through a cycle to get rid of the excess suds. When the cycle completes, just remember to use less detergent OR a high efficiency (HE) Detergent.
If you did not use a different amount or brand of detergent, let me know. Also, if the cycle does not complete, let me know.
Feb 23, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
69 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
