Question about Sony KDF-50E2000 50" HDTV
Sony KDF-50E2000 no picture and no sound flashing green standby
I have a KDF-50E2000 and the other night the picture and sound went out and the standby light kept flashing. I unplugged it and let it sit for five minutes then it worked fine for the night. Then again the next morning it worked for about ten minutes and went out and started flashing. For some reason I hit the channel button and it stopped flashing like it was warming up and came back on. The screen this time when it came back on was going dim then back to normal a few times, and then came back to normal after 20 seconds. Does anyone have any idea what might be going on with it? Thanks!
  • Anonymous May 06, 2009
    red lamp light flashes on my kdf50e3000
  • Sony Master
  • 19,396 Answers
In your case that looks like a faulty power board, a faulty inverter or an overheating problem on LCD controller board. All this three faults will cause same symptoms as yours.
When TV does not start, and sometimes you hear a clicking noise, that means that the TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 17, 2009
  • 10,594 Answers
Please replace Lamp in TV. Symptoms shows that Lamp is weak and should be replaced.
Buy original Sony lamp and avoid aftermarket or compatible lamps.
The unit Turn on and off by herself and flashes green light repeatedly.
You have a bad power supply. Its going to need to go to a real sony repair center.
Mar 15, 2016 | Sony KDF-50E2000 50" HDTV
I have the KDF-50E2000 Sony I have replaced the bulb and I have a solid green light which isnt blinking though could the replacement bulb be the issue
So you do have a picture? Albeit dark blue? Then its the source and/or video connection that is probably the problem
Mar 18, 2014 | Sony KDF-50E2000 50" HDTV
I have a sony tv model kdf-50e2000,and it has a problem with the picture going blank,the only light that on or flashes is the green (POWER) light. when turning the set on the green light blinks as it...
You tv used lamp XL-2400 or also known as F93087500. It is very common for this bulb to fail and have the exact symptom you are experiencing. I cant count how many times I have seen it.. Replace the lamp with either the exact Sony or an OEM and you will be back in business..
Good Luck!!
Dec 28, 2010 | Sony KDF-50E2000 50" HDTV
Sony kdf 50e standby light flashing 2 pulses
If your tv is Sony KDF-50E2000 model then 2 times standby light shows problem of over temperature in tv. Check temp sensor in tv.
If model number is different, let me know complete model number written on label at rear of tv to help you out.
Thanks.
May 14, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Picture and sound shut off, blinking green standby
MY SONY PROJECTION TV WENT BLANK WITH NO SOUND GREEN LIGHT WAS ON WHATS WRONG
Oct 14, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Wega kdf-50E2000 Keeps turning off and on
Before you replace the lamp I recommend trying to clean/dust the lamp component and lamp plug in area. I had the same problem and was able to resolve it by simply blowing the dust off the lamp components and fan. Use a can of high pressure air to get into the cracks and crevices.
Jun 04, 2009 | Sony KDF-50E2000 50" HDTV
No picture no sound on my sony kdf-50e2000 tv
BECAUSE ON THESE SETS IF THE LAMP DOES NOT LIGHT THEY SHUT DOWN.
May 19, 2009 | Sony KDF-50E2000 50" HDTV
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
Sony KDF-50E2000 50" HDTV Logo
676 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
