FixYa.com
Tags:
Garmin GPSMAP 60CS GPS Receiver
Garmin gpsmap 60csx won't acquire satellites (by 6 users)
posted by burn on Sep 17, 2007
I just bought this gps unit 4 days ago and it was working fine. I turned it on today and it won't acquire any satellites. It's my understanding that if this occurs some sort of menu should open up but it does not. Any help would be greatly appreciated!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by willow73, posted on Apr 29, 2008
csx was working perfectly then for no apparent reason the second time I use it, it never acquire sats... ??
csx was working perfectly then for no apparent reason next time I use it, never acquire sats ??
Comment by Guest, posted on Apr 07, 2008
I have been using my 60csx for a couple of months, then this weekend, it does not aquire satellites. The date and time are stuck on 1 apr 08. replaced batteries. turned on for several hours. Took batteries out. for several hours, and tried to reset. No luck
Comment by Guest, posted on Mar 22, 2008
csx was working perfectly then for no apparent reason it stopped aquiring sats completly ??
Comment by Guest, posted on Dec 18, 2007
Same problem, initially it would acquire reception, I have downloaded the Mapsource topo maps and it will not pick up reception again.
Best Solution
posted on Sep 24, 2007
Helpful (85)
lee-roy77
Rank:Apprentice Apprentice
Rating: 92%, 16 votes
Go to the Garmin Web site's home page, avoid staring to long at the hot chick and click on "On The Trail" .. "Mapping Handhelds" .. scroll down to the second row far right and click on the 60CSx. You will then see the 60CSx page, look to the right and click on "Updates & Dowdloads", on doing so you will now see four downloads to choose from. The one you will need is "GPS Chipset Type G Ver. 2.90 as of Nov 27, 2006" if you follow this you shouldn't have any problems. If however you do i'll keep an eye on this page and try to help, this is my first GPS and also had the same issue.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
willow73
Rating: 0%, 0 votes
csx was working perfectly then for no apparent reason the second time I use it, never acquire sats ..??
The first time my csx was working perfectly then for no apparent reason next time I use it, never acquire sats ??
I already downloaded the latest software version but the problem remains, I change the batteries, change fisical location, etc, etc.
Do I need return the GPS to the store (Best Buy) or ther is something I don´t know...
Can you Help with these GPS Devices problems?
Trackback on saved tracks is...
Trackback on saved tracks is... Answer This...
GPSMAP 60CSx
On the map page I selected Stop... Answer This...
Garmin 60c screen moving
When my garmin 60c is turned on... Answer This...
Garmin 60cx or 60csx
I am looking to purchase one of... Answer This...
Always 0 max/min elev and totl...
Always 0 max/min elev and totl... Answer This...
Repair Service
Find GPS Device Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
