Question about Emerson Smartset Clock Radio
How do i get rid of the static in my model CKS2235B radio? The original literature which i no longer have indicated that the power cord is an antena. There is no one position that works with that approach. If there is no solution please let me know so that I can dispose of the radio and get one that is not aggravating to listen to.
  • tmcgrath Apr 20, 2009
    is the manual for this model of radio available and does it address trouble shooting static?
    President:
  • 814 Answers
You will have to place the radio away from any noise sources. Like television,lamps, fans, other stereo equipment,refrigerators. These all cause noise on the a/c line current. This is the source of noise. You can try using a/c line filter/surge protectors to stop the line noise interference. Plug the radio into this and place it near a window so it can easily find the signal source.You can also look on line for more information on how to limit noise interference on a/c line connections. I hope this information help you with your problem.
Posted on Jun 12, 2009
  • stoneheaded Jun 14, 2009
    The A/C line cord is the FM Antenna. The AM Antenna is located on the back of the Clock/Radio inside the case. You have to remove the Clock/Radio from any source of external noise.
I just put up new led shop lights in my garage. Now my radio is full static. What can I do to get rid of the static.
Try using a ferromagnetic device on the radio cord. They are small circular magnets that help reduce noise or prevent noise from being transmitted to other devices.
Check the GROUNDING ability of the lighting circuit, whereby noise is being transferred along the power lines and such the conduction is being picked up by your radio. Try to connect the radio to a power line that is not associated with the same electrical panel that your existing garage lights are being powered by.
Feb 03, 2018 | Building Materials
The radio only plays the local station with a lot of static. this happened with the radio that was in the truck when i bought it. i checked the antena, changed the screw in part of the antena. i put in my...
There is interferance in th esytem that is causing this effect. If the noise is coming while in motion then the noise is induced from the electrics of the vehicle.
Check or add a 0.47mfd/100Volt capacitor which is a clip type to the power into the set. If not use a DC/DC isolator or even a inductance coil with a capacitor , one you can salvage from an old set.
Make sure the antennae is good and the local reception is strong.If not the static might dominate.
Sep 17, 2010 | Car Audio & Video
Radio has a static sound
bad speakers or antena lose
Jul 30, 2010 | 2004 Chevrolet Impala
The radio in my 2003 Cadillac CTS goes to static after after minu
Something to do with the reception or antena system..
Or the tuner in the radio is failing..
Rate well ;o)
Jul 22, 2009 | 2003 Cadillac CTS
Static on hand set
in order to remove the static from the machine you need to take the battery out from the machine and there should be no power to it from the power cord also then hold the power button for atleast 2 minutes and then put the battery in the machine and then power it on and you can connect the power cord also then it will work .
Mar 25, 2009 | Acer Aspire 5100 Notebook
Missing power cord/adaptor
You just need to go to Radio shack, and get a DC9V Adapter at 500mA and the correct polarity of (-) on the outside and (+) in the center. Original was a AHEAD AC Adapter Model ADB-0900500
Good Luck
Mar 14, 2009 | Cycling
Radio all static
check ground on alternator
Feb 07, 2009 | 2003 Hyundai Accent
Radio in, radio out
#1 Check you antena cord it may just have come unplugged, or it could be the tuner in the cd player went out too. but id checl antena first!
Jul 30, 2008 | Jensen MP5610 CD Player
Emerson Smartset Clock Radio Logo
241 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
