Question about Panasonic PT-47WX42 47" Rear Projection Television
Power problem? Today for the first time I have experienced a problem where I try to turn the tv on, I hear the click inside of the 'switch' then moments later it just clicks again. I get no power. It doesn't even try to come on. I've tried other outlets and have tried other things in the same outlets, so it's not a blown outlet. Any ideas?
  • 2 more comments
  • jonnycat47 Nov 21, 2007
    it clicks on, then clicks off, the red power light starts blinking and you have to unplug it to turn light off.
  • kentrombough Dec 04, 2007
    same problem, help!
  • Anonymous Dec 17, 2007
    TV shutsa off and then the red light blinks three times
  • Kenart Feb 16, 2008
    I have the same problem. Picture went black. When I try to turn the TV on the red light blinks 3 times, that's it.
It was a fuse. Ordered a new one and it fixed the problem.
Posted on Dec 17, 2007
    Sergeant:
    Champion:
  • 375 Answers
Possible power supply or deflection fault ,call a service shop for an estimate cost of repair.
Posted on Dec 16, 2007
TV turned off by itself today, It initially makes a clicking noise, the green power light flashes and goes out after 2-3s hear 2nd click and nothing happens. No red blink lights, nothing.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 25, 2016 | Panasonic Viera TH-42PZ80U Plasma TV
When I try to turn on my Samsung LN-T4042H LCD HDTV it is now constantly clicking in a continuous loop and will not immediately turn on. It started out small- a few clicks yesterday morning. Today it...
There is a problem with the power supply in your TV. The regulator switch is causing teh clicking sound you hear. In order to fix it, you will need to replace the power supply. This is done by taking off the back cover of the TV, locating the power supply which is usually a yellow board that will have many high voltage capicators on it and replacing it with a new one.
Nov 06, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Tv will not turn on
its a clicking of switching relay. cannot power on due to power supply failure.
May 30, 2009 | Sony KP-48S70 48" Rear Projection...
TV will not turn on.
hello..i think you have very big problems inside on you're TV you need a Electronics Technician to see inside the real problem.my tips is located in Power Supply Regulator..Can i know what kind TV Model???thanks
Apr 23, 2009 | Televison & Video
Akia 27 inch tv wont turn on
Power packs can be repaired, and most time it is simply capacitors. I don't charge an arm and a leg
Mar 26, 2009 | Akai LCT2715 27 in. LCD Television
Sudden power failure
my swisstec tv had exactly the same problem this week march 30th and the 12 month warranty expired.....i went to skymediauk online and extended my warranty ..free for 3 months they collected it,fixed it and returned it in 46 hours
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
Lg 32lcd2d (tv won't turn on)
It is most likely the power supply. If you see domed caps change them using a higher voltage cap. If it's 1000uf at 15vdc put in a 1000uf at 25 or 35 vdc. If this helps let me know.
Sep 27, 2008 | LG 32LX1D 32 in. LCD Television
LG 32lcd2d
Sounds like your cable is off or your not on chan 3 . Can you go to setup and find cable , air ect ? And see if that does anything ? Check all your coaz and hdmi and make sure they are tight as well
Jun 25, 2017 | LG 32LX1D 32 in. LCD Television
TV Will Not Turn On
Good Day;
If you don't hear the relay click suspect Q003. No power suspect Q912, Q914 & I901. Good Luck, big IRISH.
Sep 19, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
KV 27S65 Sony Trinitron 27"
So far you have done all you can and you have done everything right. The fact that the TV turned off by itself and then turned back on by itself suggests that one or more solder joints have come loose inside the set. A qualified tech should find this easy to fix, and Sony sets are always worth repairing, so it is now time to have the set serviced by a tech experienced in Sony standard sets.
Sep 01, 2007 | Sony KV-36XBR400 36" TV
Panasonic PT-47WX42 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
