Question about Garmin StreetPilot C330 GPS Receiver
How do I remove the face plate from my C330 GPS?
I broke the volume control on my Garmin C330?
The face plate is removed by inserting your fingernail under the silver plate in the center top of faceplate.It pulls out quite easily. Rob
Posted on Sep 29, 2007
SOURCE:
How do I get my battery out of the gps
Since you're posting here, I'm assuming you have a C330.
Step 1 remove face plate.
Step 2, remove 4 screws.
Step 3, pull gently apart and take note of the antenna that's on the top of the garmin unit. It comes out easily so you must make note of it's orientation or you may never get the unit back together.
When apart, there are two screws holding the battery.
Battery plug must be cut and new battery spliced in.
Battery can be purchased on Ebay. If you can't find it, do a search for tom tom. They use the same battery.
Apr 15, 2009 | Garmin StreetPilot C330 GPS Receiver
Display image has shifted, difficult to use
ok, first you will have to unplug the power and usb cables to remove external power. Secondly, place your thumbnail in the groove located under the Garmin logo on the face plate and gently pull off the face plate. Next, press the reset button for three seconds. Finally, connect the c330 to a power source using the power cable. the c330 should automatically turn back on and operate normally.
Please rate my response and have a wonderful nite.
Mar 10, 2009 | Garmin StreetPilot C330 GPS Receiver
My Street Pilot C330 will not navigate pass the where to/view map screen Screen seems to be frozen
I have a c340 and instructions say: if your unit locks up. press the power button to turn off the unit, then press again to turn unit back on. If this does not help, reset by the following: place your thumb nail in the groove located under the Garmin logo on the face plate, gently pull off the face plate, press the reset button, turn the unit back on and it should operate normally
Dec 27, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 gps will not turn on
try this just worked for mine
1.Under the face plate by the Garmin Logo.Use your thumbnail to remove the plate.
2.Press the reset button.
Information located on page 28 of the owners manual if you need a diagram.
Nov 14, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 gps
reset button under thin band on face plate. mine did the same thing
Jun 25, 2008 | Garmin StreetPilot C330 GPS Receiver
Frozen screen
Resetting Your c330
If your unit locks up, press the Power button to turn off the unit, then press again to turn the unit back on. If this does not help, reset your C330.
1. Place your thumb nail in the groove located under the Garmin logo on the face plate.
2. Gently pull off the face plate.
3. Press the Reset button.
4. Turn the unit back on; it will operate normally
Apr 04, 2008 | Garmin StreetPilot C330 GPS Receiver
Dropped the system everything working but will allow me to go to the map screen
Did you try to reset the unit? Place you thumbnail in the groove located under the Garmin logo on the face plate. Gently pull off the face plate. Press the reset button. Turn the unit back on and see if it works - Of course replace the face plate carefully. Good luck! Dr. Know
Dec 20, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Battery
Pop the face plate off with your thumb nail right uner the Garmin logo. On the right side you will see a reset button. Depress it for 2 seconds. Replace face plate and power back on.
Nov 23, 2007 | Garmin StreetPilot C330 GPS Receiver
C330 will not turn on.
I had this problem once. Try plugging it into the USB for power. Remove the face plate - there's an indention underneath on the top side to get your finger nail underneath to pull it out. One you get the face plate off,there's a small button on the right side of the screen. You can try pressing that to see if it turns on.
Aug 27, 2007 | Garmin StreetPilot C330 GPS Receiver
GARMIN STREET PILOT C330
take off the front face plate. hit the reset button on the right. charge it. I've got a 320. Same thing happened. On the 320 if you look closely there is a fingernail shaped indent on the inside of the square colored face plate. just pull the face plate towards you and it will come off with very little effort.
Feb 20, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
160 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
