Question about Zanussi 24 in. DA6141 Built-in Dishwasher
What do I do with rinse aide - I inherited the d/washer but no manual. How much do I use and how often do I use it, also what else does the little reservoir in the door do?
  • 121 Answers
Fill the small reservoir with the rinse aid to the top
it keeps glasses from spotting
Posted on Apr 17, 2009
Some user manuals can be downloaded free of charge from the makers website.
Posted on Jun 29, 2009
2 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: rinse aid leaks into the dishwasher when the door is closed
sounds like acrack in ht eseal of hte dispensor itself, replacing the dispensor is the remedy
Posted on Nov 13, 2008
How much salt goes in dish washer
You don't put salt in a dishwasher unless you want to ruin it.
2. You ONLY use a detergent specifically for dishwasher use as the cleaning agent and you 3/4 fill the soap dispenser in the washer (normally fitted into the door on the inside) with the dishwasher powder.
3. If there is a separate small compartment in your dish washer for a "rinse aid" solution to be used, you can use a rinse aid product designed for dishwasher use only. If there is no rinse aid compartment (this is also normally fitted to the inside of the door - if fitted on your machine) then you cannot use a rinse aid in your washer.
4. Don't use any other product in the dish washer.
Jan 30, 2016 | Dishwashers
No receptacle for rinse agent
U can buy a soap with rinse agent in it already. I think one brand that offers this Finish. I don't know anyway of adding a receptacle to an older washer.
Apr 23, 2014 | Magic Chef Dishwashers
Unknown control panel symbols bosch dishwasher super silent
Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
Sanitize:
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
Jun 18, 2012 | Bosch 500 Series SHX55R55UC Fully...
Bosch dishwasher...streaks dishes, glasses and inside of washer. No change of detergent helps
Could be too much rinse aid....look at page 6 of the manual for models with rinse aid adjustment electronically or for models with manual setting , set the rinse aid dial to 2 and experiment. If not enough rinse aid causes problems too If set too low crank it up to 2 for manual models or factory setting electronically is 5 Good luck Model number would help Always state model number when posting enquiries. Bosh technician
Mar 01, 2011 | Dishwashers
My dishwasher is leaking huge amounts of foam to the floor. This is what happened before I ran the cycle: I had mistakenly poured detergent into the "Rinse Aid" slot in the inner side of the dishwasher...
OK.... The rinse aid dispenser holds enough rinse aid for a lot of washes and dispenses very little each time. So you may nedd to have the dispenser emptied by a technician. If you take the door liner off you can see the back of the dispenser and maybe you can work out how to empty it. Holding the actuator in manually could allow the rinse aid dispenser to run out. Then wipe the tank dry with a towel. Putting high fat milk in the machine while it is rinsing will neutralise the foam. Just one cup will do. Good Luck.....T.
Aug 01, 2010 | Dishwashers
Position for rinse aid
Pl refer the user manual. Rinse aid is not a day to day to fill. It has a different location. Open the door and see whether you get any box visible!
May 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
How to remove the drum from a kitchen aid washing machine
hello. Unplug the washer and use a vacuum cleaner to remove the little balls. J.
please rate my answer as very helpful. Thanks.
Mar 28, 2010 | KitchenAid KAWS700L Top Load Washer
I don't know where to put the Rinse Aid
It might seem silly, but you open the front load fully, so that's it's lying flat and then you pour the rinse aid over the holes in the near left hand corner (where you might otherwise think you have to open the trap door for the rinse). The rinse aid will flow quite neatly into the reservoir and hey presto, once it's full (you'll know it's full because it'll start to back up and overflow) you're back in business. No more annoying rinse aid light!
May 22, 2009 | Bosch Exxcel WFO 2465 Front Load Washer
Rinse aid leaks into the dishwasher when the door is closed
Nov 13, 2008 | Kenmore 24 in. 15652 Built-in Dishwasher
Zanussi 24 in. DA6141 Built-in Dishwasher Logo
231 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
