Question about Canon ImageRUNNER 1670F Copier
Fax vereification Is there a feature on the Canon 1670F to verify fax was transmitted on the screen (like some machines where the screen reads "1 page sent OK", NOT with a printed report.
There is the fact that you don't receive an error report. "no news is good news"
Posted on Apr 18, 2009
Brother FAX-8070P memory shows full and does not send all pages at one time?
This message means the memory capacity of the unit has been exceeded. The amount of memory used depends on the amount or type of data on the documents being faxed or copied.
  1. If you get an "Out of Memory" message while scanning the first page of a fax, press Stop/Exit to cancel scanning.
  2. If you get an "Out of Memory" message while scanning a subsequent page, you can either press Fax Start to transmit the pages that were scanned so far or press Stop/Exit to cancel the operation.
When Fax Storage is set to On, a copy of all received faxes are stored in the memory, thus using up a % of the memory available for other functions.
The Fax Storage feature is utilized for Fax Forwarding, Fax Paging and Remote Retrieval. If you do not need these features, verify Fax Storage is set to Off by doing the following:
  1. Press the Menu/Set key.
  2. Press the arrow key until FAX appears on the LCD. Then, press Menu/Set.
  3. Press the arrow key until REMOTE FAX OPT appears and then press Menu/Set.
  4. Pressthe arrow key until FAX STORAGE and then press Menu/Set.
  5. Check the setting. The display will read ON or OFF. If the setting is ON, press the arrow key until the display reads OFF.
  6. Press Menu/Set.
  7. If you have faxes stored in the memory, you will receive a message that reads Erase all fax? 1. Yes 2. No. If you want to erase all the faxes in the memory without printing them out, press 1 (Yes) and then press Stop/Exit.
Note
    If you would like to reprint the saved faxes, press 2 (No), press Stop/Exit and continue to the following steps for instructions on how to print stored faxes.
If you do need the features that require Fax Storage to be On, the stored faxes will need to be erased or printed to remove them from the memory and to allow additional memory to be available. Follow these steps to print the stored faxes:
  2. Press the arrow key until FAX appears on the LCD and press Menu/Set.
  4. Press the arrow key until PRINT FAX or PRINT DOCUMENT appears and press Menu/Set.
  5. Press Fax Start.
  6. After printing is finished, press Stop/Exit.
Jun 06, 2011 | Brother FAX-8070P Plain Paper Laser
Is there a way to verify fax was sent? we used to have a canon that put a dot on faxes when sent
You can mostly, go into the user fax settings and have the fax print a transactoin report for each fax sent. The default setting is to only print a report when a fax is not set... You may have to do some botton pushing... Good Luck...
Dec 01, 2009 | Canon ImageRUNNER 1670F Copier
Automatically receive a confirmation page after sending fax
please ser send my experties your machine model then i shall help you
Aug 05, 2009 | Canon ImageRUNNER 1670F Copier
Fax transmission verification
Like Sandman said, the fact you DON'T get an error repport is your confirmation.
Apr 17, 2009 | Canon FAX-L350 Plain Paper Laser
Replacement drum for a fax image model 1670F.
hello
did you take the cartridge out?
if so you must separate the two things drum and toner.
Oct 21, 2008 | Canon ImageRUNNER 1670F Copier
I HAVE A PANASONIC FAX kx-FPG376 IT WONT SEND FAX MAKES COPIES AND RECIEVES FAXES
I dont know how we got disconnected but here is the instructions
Adjust the width of the document guides (1)
to fit the actual size of the document.
2 Insert the document (up to 10 pages) FACE
DOWN (2) until a single beep is heard and
the unit grasps the document.
L If the document guides are not adjusted
to fit the document, re-adjust them.
3 If necessary, press {A} or {B} repeatedly to
select the desired resolution.
4 Press {DIGITAL SP-PHONE}.
5 Dial the fax number.
6 When a fax tone is heard:
Press {FAX/START}.
When the other party answers your call:
Ask them to press their start button. When
the fax tone is heard, press {FAX/START
To redial the last number
1. Press {REDIAL/PAUSE}.
2. Press {SET}.
L If the line is busy, the unit will automatically
redial the number up to 2 times.
L To cancel redialing, press {STOP}.
To send more than 10 pages at a time
Insert the first 10 pages of the document. Add
the other pages (up to 10 at a time) before the
last page feeds into the unit.
Pre-dialing a fax number
You can dial the fax number first before inserting
the document. This is convenient if you need to
refer to the document for the other party’s fax
number.
1. Enter the fax number.
2. Insert the document.
3. Press {FAX/START}.
Sending from memory (Quick scan feature)
You can scan the document into memory before
sending it. To use this feature, activate feature
#34 (page 62).
1. Insert the document.
2. Enter the fax number.
L The document will be fed into the unit and
scanned into memory. The unit will then
transmit the data. If the document exceeds
the memory capacity, transmission will be
canceled and this feature will be turned OFF
automatically. You must transmit the entire
document manually.
L This feature cannot be used if {DIGITAL SPPHONE},
{TALK} or {SP-PHONE} is
pressed.
To stop transmission
Press {STOP}.
Aug 27, 2008 | Panasonic Office Equipment & Supplies
Memory full
1. Fax Storage may be set to On. When Fax Storage is set to On, a copy of all received faxes are stored in the memory, thus using up a % of the memory available for other functions. The Fax Storage feature is utilized for Fax Forwarding, Fax Paging and Remote Retrieval. If you do not need these features, Fax Storage should be set to Off. Verify Fax Storage is set to Off by doing the following:
a. Press FUNCTION, 8 (Remote Fax Opt), then 2 (Fax Storage).
b. Check the setting. The display will read On or Off.
c. If the setting is On, press the left or right navigation key (arrows) until the display reads Off.
d. Press SET and then STOP/EXIT.
e. If you have faxes stored in the memory, you will receive a message that reads Erase all fax 1. Yes 2. No. This means you have faxes saved in the memory. If you do not want to reprint the saved faxes, press 1 (Yes) and then STOP/EXIT. After pressing 1 (Yes), all fax data is erased and Fax Storage is turned off.
Hope this helps!
May 20, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Fax question
You want a TX (transmit) Report. You can have the report printed after each fax is transmitted, including the first page of the fax sent if desired. Follow these steps to turn on the report.
1. Press Menu button
2. Use (left or right) arrows to FAX SETTINGS, press Set button
3. Use arrows to REPORT SETTINGS, press Set button
4. Use arrows to TX REPORT (may be there already), press Set button
5. Use arrows to OUTPUT YES, press Set button
6. If screen says REPORT WITH TX IMAGE, press Set button
7. Use arrows to ON or OFF, as desired, press Set button
8. Press Stop/Reset to exit the menu
May 05, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Canon Image runner 1670F will NOT receive faxes
scroll through menu and look for powersave options using keypad and display
Jan 15, 2008 | Canon ImageRUNNER 1670F Copier
Ricoh RF800 Fax Machine Manual
What model of fax machine is it?
Aug 28, 2007 | Office Equipment & Supplies
Canon ImageRUNNER 1670F Copier Logo
142 people viewed this question
old marine
old marine
