Question about Garmin StreetPilot c340 GPS Receiver
Can the horizontonal positioning be adjusted?
  • lynda377 Apr 17, 2009
    what exactly does cycling through that list do for me? am i looking for something in particular?
    none of those 3 solutions have done anything.
    It's clear from the time you start the StreetPilot that the screen is not centered. The word "Garmin" at the top left is only 1/2 visible. The bottom appears to have a "shadow" under the function buttons. The screen is 1/4" exactly too high. Any words at the top cannot be seen at all. Can I send you a picture of it?
  • 19,396 Answers
Do the following :
To Calibrate The Touch Screen:
1. Turn off GPS
2. Hold Power Button for 30 secs or so
3. Calibration screen will appear.
If that does not work, then the following may also be useful:
Perform a Hard Reset to Clear Your GPS:
1. Turn GPS off
2. Press and hold the bottom right hand corner of the screen
3. Turn the GPS on (and continue to hold the right hand corner)
4. A warning screen will appear and ask if you want to continue
This will erase all your custom data. This is excellent after buying a used unit or after moving to clear all your data.
Access the Debug/Diagnostic Pages:
1. Turn GPS on
2. Click View Map
3. Click the Speed section in the left lower corner
4. Press and Hold the Moving Avg box for several seconds
5. The Diagnostic Screen will appear.
6. Press Next to cycle through them all.
Here the user manual: StreetPilot c340
Posted on Apr 17, 2009
  • Ginko
    Ginko Apr 17, 2009
    Hi there.
    The original query 'can the horizontal positioning be adjusted?' is not very clear. I underatand the horizontal position was the screen calibration, in that case you do this:
    1. Turn off GPS
    If that is not what you meant, please help me to understand the problem.
    Many thanks.
  • Ginko
    Ginko Apr 17, 2009
    Yep, you can send a picture, but I think I understood the problem. The screen is completely out.
    There is a way to resize the screen using a third party program as resource Hacker available at http://www.angusj.com/resourcehacker/., But this probably wont solve the problem , but only mess up more the Garmin.
    The real problem is hardware, and there is no other way to fix this apart disassembling the Garmin.
    To start try reset to factory and calibration suggested in my other threads, so to exclude settings and system problems.
    If that does not work, then there is an internal problem.
    I believe on this Sat Nav the display is reflected by a mirror on top of the touck screen, in that case the mirror has moved.
    There is no setting to regulate alignment on a garmin. Here is the parts view.
    If the streetpilot is less than one year old call Garmin as soon as possible, if sat nav is older , call Garmin,.or ask a local repairer.
    Let me know if you need further clarification.
    Many thanks.
1999 chrysler 300M won't shift out of park. Pulled so ******* the shifter it broke.
possible internal locking pawl stuck fault or adjustment required
ADJUSTMENTS
sourced from another forum
The park interlock cable is part of the brake/shift lever interlock system. Correct cable adjustment is important to proper interlock operation. The gear shift and park lock cables must both be correctly adjusted in order to shift out of PARK.
ADJUSTMENT PROCEDURE
1. Remove floor console as necessary for access to the park lock cable.
2. Shift the transmission into the PARK position.
3. Turn ignition switch to LOCK position. Be sure ignition key cylinder is in the LOCK position. Cable will not adjust correctly in any other position.
NOTE: If the key will not turn to the LOCK position, pull up on the cable lock button and manually move the cable in and out until the key can be turned to the LOCK position.
4. Pull cable lock button up to release cable, if necessary.
5. Remove and discard the cable adjuster lock pin, if a new cable is being installed.
6. Ensure that the cable is free to self-adjust by pushing cable rearward and releasing.
7. Push lock button down until it snaps in place. The lock should be 1-2mm below the surface of the cylindrical portion of the cable
d5fad53b-454e-40de-8326-5998ee796fd6.jpg2010-09-06_193640_8-yevmkukx3b2zymzwvvrzuy4i-4-2.gif
Jan 16, 2017 | 1999 Chrysler 300M
GMC Yukon Seat Switch
You don't mention what year your Yukon is ? This could very well be a control Module problem .
I'll post how the power memory seat's work or are suppose to work !
Memory Seats Description and Operation
Battery voltage is supplied to the memory seat module through a 25 A circuit breaker. The memory seat module supplies the seat adjuster switch assembly with a battery positive reference voltage. While the seat adjuster switches are in an inactive state the switch contacts are closed to the adjuster switch common circuit. When a seat adjuster switch is pressed to an active state the switch contact is closed to the reference voltage circuit. Battery voltage on a switch signal circuit indicates to the memory seat module the switch status is active. Each seat adjuster motor is controlled by the memory seat module through 2 motor control circuits. While the seat adjuster motors are in an inactive state the motor control circuits are closed to ground circuit contacts within the memory seat module. The memory seat module operates the seat adjuster motors by switching one of a motors control circuits to battery voltage. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
Memory Set/Recall Operation
The seat adjuster motors are equipped with internal position sensors. The adjuster motor position sensors are monitored by the memory seat module and are used to determine the seat position when storing or recalling memory settings. The driver seat adjuster motors use potentiometer type position sensors. The position sensors are supplied with a 5 V reference and ground circuits from the memory seat module. The position sensor signal circuits return to an analog input within the memory seat module. During adjuster motor operation the position sensor provides a voltage change proportional to the change in revolution of the adjuster motor shaft. The memory seat module monitors the voltage from the position sensor signal circuits to determine the adjuster motor positions when storing or recalling memory seat position settings.
The memory recall switch assembly on the driver door provides inputs to the driver door lock/window switch. Battery voltage is supplied to the memory recall switch assembly from the driver door lock/window switch. When a RCL 1, RCL 2, or EXIT switch is pressed, the switch contacts close the appropriate switch signal circuit to the battery voltage supply circuit within the memory recall switch assembly. When the driver door lock/window switch receives active switch signals from the memory recall switch assembly, the appropriate commands are sent to the memory seat module using the GMLAN Serial Data circuit. The Body Control Module software version determines the personalization features available.
Memory seat recall operation is allowed only with the transmission selector lever in the PARK position while the ignition is on. The transmission selector lever position data is provided to the memory seat module by a message through the GMLAN Serial Data circuit.
There are somethings listed you are not familiar with , like GMLAN Serial Data circuit ,maybe Body Control Module software etc... GMLAN is a communincation network that the computers on the vehicle uses to share information , transmit commons etc... you can google it to read about it .
There are DTC'S - diagnostic trouble codes that can set in the module in control . Do you know what DTC'S are .
DTC Descriptors
DTC B1825 01: Driver Seat Recline Position Sensor Circuit Short to Battery
DTC B1825 06: Driver Seat Recline Position Sensor Circuit Short to Ground or Open
DTC B1825 5A: Driver Seat Recline Position Sensor Circuit Plausibility Failure
DTC B1850 01: Driver Seat Lumbar Horizontal Position Sensor Circuit Short to Battery
DTC B1850 06: Driver Seat Lumbar Horizontal Position Sensor Circuit Short to Ground or Open
DTC B1850 5A: Driver Seat Lumbar Horizontal Position Sensor Circuit Plausibility Failure
DTC B1860 01: Driver Seat Lumbar Vertical Position Sensor Circuit Short to Battery
DTC B1860 06: Driver Seat Lumbar Vertical Position Sensor Circuit Short to Ground or Open
DTC B1860 5A: Driver Seat Lumbar Vertical Position Sensor Circuit Plausibility Failure
DTC B2355 01: Driver Seat Front Vertical Position Sensor Circuit Short to Battery
DTC B2355 06: Driver Seat Front Vertical Position Sensor Circuit Short to Ground or Open
DTC B2355 5A: Driver Seat Front Vertical Position Sensor Circuit Plausibility Failure
DTC B2365 01: Driver Seat Rear Vertical Position Sensor Circuit Short to Battery
DTC B2365 06: Driver Seat Rear Vertical Position Sensor Circuit Short to Ground or Open
DTC B2365 5A: Driver Seat Rear Vertical Position Sensor Circuit Plausibility Failure
DTC B2375 01: Driver Seat Assembly Horizontal Position Sensor Circuit Short to Battery
DTC B2375 06: Driver Seat Assembly Horizontal Position Sensor Circuit Short to Ground or Open
DTC B2375 5A: Driver Seat Assembly Horizontal Position Sensor Circuit Plausibility Failure
5) Memory Seat Module is under the front of the driver seat , you could look under an see if all the connectors are fully seated.
The best diagnostic step would be to hook up the factory scan tool an see what the computer is seeing as far as inputs from the switch an outputs it's sending . I wouldn't suggest you take the seat apart an try testing electrical inputs etc.... unless you very familiar with automotive electrical systems an circuits .
Mar 06, 2017 | GMC Cars & Trucks
I have a craftsman garage door opener. Model number 4184315 7D When I close the garage door it will automaticly open by it's self. There is nothing obstructing the sensor that prevents the door from...
There are two sets of adjustments. Down position and down force, If the travel is set to far in the down position the max down force setting will trip and the door goes back up.
Adjust he down position until a slight gap is visible in the down position. Adjust slight steps until no gap is visible.
If return trips increase the down force slightly . Position adjustments are on the side, down force blue knobs on back. Note adjustment positions before beginning so if you get confused you can start over.
Hope this helps?
Jun 23, 2017 | Kitchen Ranges
I have a Mossimo analog watch with date & time with no knowledge of how to adjust those
your watch crown has 3 positions. the normal position, the second position and the third position. just pull it to adjust. the 2nd position is for date adjustment, and the third position is for time then if your done with that steps just push the crown to normal position.
Jul 09, 2011 | Watches
I own a 1990 Mazda MX5 and the headlights need adjusting - how do you adjust them please. The housing is flush with the bonnet so no need to adjust this just the aim.
After taking off the covers which suround the head lamps. There are two screws 1 in the 6 0`clock position to adjust the up and down position and one in the 9 0`clock position to adjust side to side position
Feb 14, 2011 | 1990 Mazda MX-5
How do i repair shifting cable from cosole to trans.?
Welcome to FixYa.com
REMOVAL
1. Remove air cleaner and air intake hose assembly.
2. Remove center dash trim panel.
3. Remove center console cup holder assembly.
4. Remove floor console assembly.
5. Remove console side panels.
6. Remove Transmission Control Module ftMJ bracket.
1. Remove TCM.
8. Remove shifter cable from transaxle operating lever by removing nut and clip.
9. Remove shifter cable from shifter lever assembly by removing clip.
10. Remove shifter cable from shifter lever mechanism.
11. Remove cable from firewall grommet by removing grommet assembly nuts.
12. Remove gearshift cable from vehicle.
ADJUSTMENT
Lift and rotate the gearshift hand lever into the park (F9 gate position and remove the ignition
key. This confirms the shift lever is in the gated park (F9 position.
After confirming the park gate position. turn the ignition switch . If the starter will operate. the
park gate position is correct. Move the shift lever into the neutral (NJ position. If the starter
will operate in this position, the linkage is properly adjusted. If the starter fails to operate in
either position, linkage adjustment is required.
1. Park the vehicle on level ground and set the parking brake.
2. Place the gearshift lever in park (F9 gate position and remove key.
3. Loosen the cable adjustment screw at the transaxle operating lever.
4. Pull the transaxle operating lever fully forward to the park detent position.
5. Release the park brake, then rock the vehicle to assure it is in park lock. Reset the park
brake.
6. Tighten the cable adjustment screw to 8 Nm (10 inch Ibs.J. Gearshift cable should now be
properly adjusted.
1. Check adjustment by usinq the precedinq procedure.
Thank you for Using FixYa.com
Kind Regards, Lee
Your Master Technician FixYa Expert
Jan 31, 2011 | 1997 Chrysler Sebring
How to installing brake shoes on back ?
First you have to compress the parking brake cable spring and attach the parking brake lever.
Clean and lubricate the brake backing plate.
Use silicon Brake Caliper Grease and Dielectric Compound.
Then,
install the rear brake shoes and linings:
1) position the rear brake shoes and linings
2) position the parking brake lever
3) install the brake shoe hold-down spring pins and the brake shoe hold-down springs.
Install the parking brake strut
1. install the parkig brake link spring on the parking brake strut
2. install the parking brake strut
3. Install the brake shoe anchor ping guide plate.
Install the short brake shoe retracting spring
1. Place the brake shoe adjusting lever cable over the anchor pin, with crimped side in
2. Install the short brake shoe retracting spring
Note: Make sure the brake shoe adjusting lever cable is positioned in the cable guide groove
Install the long brake shoe retracting
1. install the cable guide
2. position the brake shoe adjusting lever cable in the cable guide groove
3. install the long brake shoe retracting spring
Note: to prevent incorrect installation, teh socket of each brake adjuster screw is stamped R or L
Assemble the brake adjuster screw assembly.
1. apply silicone brake caliper grease and dielectric compound
2. install the brake adjuster screw into the brake show adjusting screw nut to the end of the threads and then loosen one half turn
3. install the brake shoe adjusting screw socket on the brake shoe adjusting screw nut.
Install the brake adjuster screw assembly
1. Position the brake adjuster screw assembly
2. Install the brake shoe adjusting screw spring
3. Position the brake shoe adjusting lever cable
4. Position the adjusting lever return spring and the brake shoe adjusting lever
5. Hook the brake shoe adjusting lever cable to the brake shoe adjusting lever.
Test the operation of the automatic self-adjuster
1. Pull the brake shoe adjusting lever cable and check that the brake shoe adjusting lever rotates the brake shoe adjuster assembly
2. Release the brake shoe adjusting lever cable and check that the brake shoe adjusting lever advances to the next notch on the brake shoe adjusting screw nut.
Adjust the brakes.
Install the brake drum.
Thats it
Sep 10, 2010 | 1998 Ford Ranger SuperCab
No action when I pull the stem out to adjust time
There may be more than one "out" position.
Typically there are three positions 1) home 2) 1st adjusting position, 3) 2nd adjusting position.
If you haven't got the instructions, you can get a download from their web site, (Rolex.com). You go to the bottom of the screen and there is a menu. Select "downloads" and you will see a list of downloads, choose yours.
Feb 08, 2010 | Rolex Submariner 16618 Wristwatch
Problem with display, need help finding what the problem is
I have the same problem with my monitor and it did not happen until windows update started installing a driver---before that my monitor was working fine. (It was on automatic update) I think it is because the new driver sets the monitor at 100hertz and the syncmaster works best at 60 hertz ( I think).
Since I am unable to see anything on the monitor I do not know how to reset this though. I do think if I could get it working at a lower refresh rate then it would work again---damn automatic updates anyway.
I took my puter back to an earlier date before it had upgraded but my monitor still has the line thing going on. Hope someone has some suggestions for this.
Oct 06, 2007 | Samsung SyncMaster 172N 17" LCD Monitor
Garmin StreetPilot c340 GPS Receiver Logo
32 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
