Question about Sony CDX-T69 6-Disc CD Changer
Cds stuck in sony cdxt69
The cd holder in my Sony cdx-t69 will not eject when the eject button is pushed.
  • red56chevy Oct 07, 2007
    Did not work on this, one of the arms was jammed, a friend took the cd apart and got the cd's out, but now the cd cartridge will not lock into the deck, and the deck makes the same sounds it did when it was jammed.
    Genius:
  • 1,153 Answers
Take power away for 5min then plug back up. Hit reset with pen head.
Posted on Sep 17, 2007
SOURCE:
Does the sony cdx -gt25 work with the sony cdx t69
To connect T69 with head unit GT25,bus cable connecting port is required through which you can connect cd-changer with your head unit.As GT25 has no bus port,it does't work.
Nov 01, 2012 | Sony Car Audio & Video
PLEASE HELP!! Sony CDX T69 CD Changer not recognised by my car.
I would inspect the harness to your unit and see if any wires are not connected..A fully connected harness ensures all functions are working as intended and if any wire that is supposed to be hooked up and isn't then there would be your issue..
Aug 21, 2017 | Sony CDX-T69 6-Disc CD Changer
I think I put the magizine in backwards, I have pressed the eject button several times, but it does not eject. How do I get ti out?
It's almost impossible to insert the cartridge wrong, as it is keyed. If it went in without forcing it and your heard or felt a click as it latched, it is in correctly. More likely, the changer has lost power or malfunctioned. try unplugging the power connector for a few seconds to reset it. When you plug it back in, you should hear the motors inside whir. If not, you have no power going to it.
Jul 03, 2011 | Sony CDX-T69 6-Disc CD Changer
How do you eject the magazine
Press and Slide Front half cover as shown in below image and you will see eject button there to eject magazine.
May 04, 2009 | Sony CDX-T69 6-Disc CD Changer
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
CDX changer has power but doesn't want to eject after flat battery
i resolved this myself in the end.
I unplugged the audio & power cables whilst the stereo and engine was running.
Then plugged back in.
I turned the engine off and stereo off as well.
I then unplugged audio and power again from the back of the CDX, left it unplugged for 10 minutes whilst the engine was still off.
I then plugged the leads back in and turned the engine on. the stereo recognised the CDX, but stayed on displaying "CD Checking". I switched to radio for 20 seconds, turned back to CDX and it selected CD 1 and has been good ever since.
I'm rather pleased with myself!
Steve
May 13, 2008 | Sony CDX-T69 6-Disc CD Changer
Cdx t69
VIEW THE LINK BELOW
http://www.fixya.com/support/t589604-cdx_changer_power_but_doesnt_want_eject
Apr 21, 2008 | Sony CDX-T69 6-Disc CD Changer
Sony CD interchanger CDX - T69 (how to reset?)
This would invalidate the warranty and you may break it but I have just had to do one:
1. Remove 4 black screws
2. Unclick the front panel - yes it is clicked on but may appear to be screwed
3. Take off black lid
4. Pop the cradled player from the 4 dampers and unhook from the 2 springs
5. Remove the ribbon connector - do this by slipping/clicking the brown holder very slightly and then the ribbon comes out easily
6. Now using a suitable tool push the stuck CD back into the magazine
7. Click the magazine out - there is a white piece of plastic what when moved does the eject.
8. Do the above in reverse.
The trick to get the grey horizontal/vertical discs back on is to set them passed horizontal one notch on and click them on at the end - turning one notch anti-clockwise to lock them.
Feb 09, 2008 | Sony CDX-T69 6-Disc CD Changer
Sony CDX-T69 6-Disc CD Changer Logo
1,293 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Mike Duncan
Mike Duncan
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
