Question about Fujitsu Siemens Computers & Internet
My Fujitsu Siemens Scaleo P tower fails to boot up, sometimes shuts down after a few seconds, no output to monitor. Can you help My computer works fine untill one morning it shut down with no warning. Naturally I let the pc cool down because it is re known for over heating to quickly. A hour later I started it back up and a quick message was displayed say CPU Over heat then it shut down. I left it for a day and I turned it back on and within a few seconds the exact same thing happened. I clean out all the dust and removed the heat sink and the processor was boiling. I let it cool down again and started the pc back up and within the 7 seconds it was boiling. Any ideas I would really appreciate it.
  • 4 more comments
  • vining Apr 17, 2009
    I have a huge cooling block and a huge fan on top of the CPU. In total i have 3 fans 1 on the cpu another one on the HDD and another one on the casing to keep the whole PC cool
    No the CPU is Intel pentium 4HT
    It's a werid CPU. On a normal CPU the chip should have pins on it but on this pc the chips are on the motherboard instead! I checked it and one of the pins is a bit loose. Could this be the problem?
    The motherboard is an ASUS. I do not know where to find the model number is
  • Frank
    Frank May 11, 2010
    in that case. I do suspect that the CPU is the problem.
    is the CPU made by AMD by any chance?
  • Frank
    Frank May 11, 2010
    do you have a fan on top of the CPU? if not, I suggest you get one. if yes, then make sure the fan is running when yo turn on the machine. Make sure all of the fan power supply, case, and other fan if you have are all running.
Start it up with the side of and watch the fan if it starts up and then stop or it sops the sarts again slowy and see if you can feal fan draft quite alot and put a house fan in front of side of pc as im 100%sure your fan is not cooling it and if you dont change it it will bur out completly a house fan needs to be on a few seconds as it need to stay cool a while for it to work letme know or ring me on 07519084655 i av a friends and it does swich of after 30 mins but i can not get it to do it just fan stops or goes round slowly cannot feel fan at all but does come to screen u can aso disconect hard drive and start it up if it switches of still then u know its not hardrive you will still be able to get writing on black screen saying hardrive fail but if it stays o then u need hardrive good luck let me know the out come
Posted on Jul 03, 2009
    Genius:
  • 1,605 Answers
Pop the CPU, take a closer look athe chip and the socket, make sure there is nothing can create a short of creating any kind of heat. if you don't find anything there, I suggest a new CPU in order.
Posted on Apr 17, 2009
  • 1 more comment
  • Frank
    Frank Apr 17, 2009
    possible.
    what motherboard you have?
  • Frank
    Frank Apr 17, 2009
    make sure the fan is running and have a good contact with the CPU.
    if you are using the themo pad on the fan, clean off the pad form the CPU and fan and apply themo grease. they works better.
  • Frank
    Frank Apr 17, 2009
    try to install the CPU and put enough themo grease and make sure it is good and tight between the fan and the CPU.
    Like I say before, if that don't work then you need to get a new CPU.
How to remove the side panel from a Fujitsu-Siemens Scaleo Home PC?
Need the model number Chiara. Look on the back near the Windows product key, or up on the side of the computer tower. There are MANY versions of the Scaleo model series, and also case designs. Post back in a Comment. (Clarification and Comment options not available, at the moment. So I'll use a Solution box for that, and a Comment box for a Solution, lol!)
Nov 28, 2012 | Computers & Internet
My fujitsu scaleo p tower won't display anything on the monitor! The monitor works fine with other devices.... everything spins and all LEDs light up just no output to the monitor :/ any...
Have you tried putting the Graphics card in a Different slot? If you have and it is still not working most-likely it means that your video card has gone bad and needs replacing.
Jul 11, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Why wont my computor shut down ? If I shut it down it suts down and after about 5 seconds it restarts
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
SAFE MODE
At start up press F8 go2 SAFE MODE thn type at run chkdsk,chkdsk/f/r & thn restart pc
Else Repair XP
Else clean ram BY RUBBER
read here
http://pctells.blogspot.com/
http://mailerror.blogspot.com/
http://faqall.blogspot.com/
Feb 23, 2011 | Fujitsu Siemens SCALEO 700x...
I can't find a driver for my grafique cart of siemens fujitsu scaleo 600 thank's for help :)
on this page
http://ts.fujitsu.com/support/downloads.html
type scaleo 600 for searh
you will be redirected to drivers download page
Feb 22, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
No sound on my pc!
step 1: check with the speakers on another computer to ensure the speakers are working fine.
1. Insert the CD-ROM titled 'Fujitsu Technology Solutions Drivers & Utilities CD' that came with the computer into the DVD tray and close it.
2. The Drivers & Utilities CD will start automatically.
3. Click on 'Driver Installation' option.
4. Click on INSTALL.
5. After the installation process the computer will automatically re-start. If not, for safety reasons (to not misinform/corrupt the information on the registry) restart the machine manually (Start Menu - Shut Down).
If you receive a message saying 'Found New Hardware Wizard' during the Drivers installation (Automatic recommended), ignore it and leave the Drivers & Utility CD to finish the installation. The D+U Setup is will detect the computer's hardware (it will not detect the drivers of any external devices you may have) and install the drivers needed. After you re-boot the machine you may get the Found New Hardware Wizard again, this will be your Monitor being detected, follow the on-screen instructions to install it properly (if you have a driver's disk, provided with your monitor or any other external device that you have connected, use this when prompted)
Jul 01, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
I have a problem with my fujitsu siemens scaleo p, when i turn it on, only the orange light turns on, it sounds like the computer is doing something, but nothing on the screen, maybe it´s on...
Might as well try to access it thru safe mode with networking if it s working fine , if not try to connect an external monitor / or better yet if you can access safemode with networking try to disable some of the start-up programs thru msconfig.
ERNZ
Feb 08, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Ich habe keinen Audiotreiber mehr auf meinem Computer Fujitsu Siemens Scaleo 600
The German download page is found here
Fill in the field: Bitte geben Sie die Serien-/Identnummer des Gerätes oder den Produktnamen ein: "Scaleo 600"
Then open Audio, look up in the manual of your Scaleo 600 wich audio
chipset your motherboard has onboard to download the the correct drivers.
Note: Use the Fiujitsu Siemens site with Internet Explorer because it does not work very well with Firefox and next time putt your question here in English, you'll get more help in this way.
Succes.
Jan 08, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
I also have a Fujitsu-Scaleo P, yesterday I had the same problem exactly as described here. The issue is that the CPU fan does not work anymore. It is easy to replace, only four Phillips screws to be removed. I simply don't know if the new fan replacement can be bought alone, or if the air duct will be in the replacement kit, along with the aluminum block. It is a Cooler Master Model made by Protechnic Electric model MGT 9212ZR-W25. If it wasn't that the problem, when the computer is still cold, try to boot it, press DEL which will bring up the BIOS Setup Menu, and you can see if the Fan still works: in one of its menus shows the Fan RPMs and CPU Core Temperature. Good luck.
Mar 31, 2008 | Computers & Internet
Onboard Sound Drivers and Video Controllers
Hi EsteG, found all your drivers for your SCALEO 800, these are also used for the SCALEO 800Si 2410 Silent+. They call it the 800 series, for XP. Click the link below.
http://support.fujitsu-siemens.com/com/support/downloads.html
Because it's the whole 800 series you'll need your manual to pick the correct Audio driver as noted in your manual. To narrow down the ammount of drivers in each area. There should be a sticker on the PC that has the serial No# . Enter that number on this link below. (Siemens Fujitsu) does not make this easy.
If I can be of more service, just ask.
Good Luck & Kind Regards.
Mike
Mar 25, 2008 | Siemens Fujitsu SCALEO 800Si 2410 Silent+...
Monitor Acer Problem
I agree it isn?t the monitor but I would suspect the video card you are connecting it to or the PC itself. Generally if a monitor doesn?t detect a video signal it will go into hibernation mode, typically displaying a no signal warning and changing the LED color from green to amber. When you start the computer is anything displaying at all? Are you sure the PC is powering up and booting?
Jul 22, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
928 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
