Question about Irons
I try to get steam every time i press the steam button i hear the pump going but no steam.I changed the anti scale cartidge and ive cant get steam since Russell hobbs xpress steam 14369
  • druceyboy Apr 26, 2009
    it sounds like the iron is going disperse the steam but nothing happens!!!! I have changed the cartridge & it doesnt change a thing, the steam button just continues to flash & the beeping noise drive me CRAZY!!!!!!!
The pump is not priming make sure the tank is full of water
Posted on Aug 30, 2009
Hi guys. I have a Hoover ironspeed IS21-1 steam generator iron. I love this iron it's the best steam generator I've ever had but now once it's heated up and I go to use it as soon as I press the button...
Try unplugging everything that is using that circuit because it's possible that you have too many items plugged up. Also try other outlet.
Jan 14, 2015 | Irons
The steam button is producing no steam, how to fix it?
have u descale it .I use pure white vinegar in the iron switch on the hottish setting then keep pressing the stream button. But getting rid of the lime scale is a lot harder.
May 16, 2014 | Rowenta Irons
I have a swan steam generator iron .s14030n .i have read manual and the steam only works if i keep pressing pump .should the steam come through all the time .when switched to steam .i have done the pu
MINE IS LIKE THAT. PRESS FOR STEAM WHICH CONTINUES FOR A SHORT WHILE. BUT IT IS A PAIN AND TGHERE IS NO WAY I HAVE FOUND ROUNBD IT EXCEPT A SPRAY BOTTLE WITH WATER!
Jan 28, 2013 | Irons
Water leaking from iron can you answer me third time ive asked now
see this steps and fix it. God bless you
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Oct 15, 2012 | Frigidaire Fcl212/H 2200W Steam Spray Iron...
I have an bosch sensixx b5 iron and the calc clean sign keeps flashing what can i do .i have lost theinstuctions
Here you have how to solve this issue. It has been obtained from the device's manual.
2. calc'n clean The "calc'n clean" function helps to remove scale particles from the steam dispenser. The iron includes a system to warn when the dispenser needs periodically cleaning. When the "calc 'n clean" symbol lights up on the navigation display the dispenser needs cleaning. Fill the water tank. Plug in the iron and select the temperature setting . After the necessary warm-up period, unplug the iron and hold it over a sink. Position the steam regulator to the "calc'n clean" position and keep it in this position. Gently shake the iron. Boiling water and steam will come out, removing any scale or deposits that might be there. When the iron stops dripping, position the regulator to the position. For improved descaling, heat up the iron again fully and press the steam button several times in quick succession. Then wait until the remaining water has evaporated from the soleplate of the iron. Once it has been cleaned, the cleaning warning must be cancelled on the navigation display. To do this, simply press and hold the on/set navigation key for more than 5 seconds, with the iron plugged in. If you do not do this, the cleaning icon will remain lit. 3. anti-calc The "anti-calc" cartridge has been designed to reduce the build-up of scale produced during steam ironing, helping to extend the useful life of your iron. Nevertheless the "anti-calc" cartridge cannot remove all of the scale that is produced naturally over time.
Jan 25, 2011 | Bosch Irons
Russell Hobbs Steamglide 2200 - no steam
Same with mine! What you have to do is keep taking the water cannister off and pushing back on until its lined up correctley. Also have the whole unit at the same height as the ironing board, that should do it! Can you help with filters? I cant find them anywhere.
Mar 23, 2009 | Irons
Cant get anti calc cartridges for my steam generator
I had to order mine direct from Breville. If you go to their website and contact them with the model of the iron then they will give you details of price and postage.
Aug 25, 2008 | Irons
Insufficient steam
Try a commercial De-Scaler.
If your in a hard-water area. the iron will be heavilly scaled-up.
If there is a steam surge button, on the iron. Face it downwards and push the button several times.
Mike @ Compurepair.
Feb 18, 2008 | Tefal Aquaspeed 170 Iron
Irons Logo
463 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
