Question about Intel Motherboard
Mother board no display
In my gigabyte board monitor is on. but could not display and no beeb sounds. how to solve it?
  • Intel Master
  • 5,660 Answers
Looks like the lights are on? Fans spin? Sounds like the harddrives spinning? The power supply is bad. has just enough power to light lights, and spin fans, but not enough for the processor. (No beep sounds, because BIOS hasn't done a memory count. It's not going to)
ALL the lights use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
The harddrive just sitting there spinning, uses about 5 watts.
Processors use 55 Watts to 125 Watts. Depends on the processor.
Not enough power to turn the processor on, the computer won't work. Computer isn't working there isn't anything to turn the monitor on. No Signal.
Posted on Apr 17, 2009
Come on screen but at that time when I press the menu all menu function come on screen but pc display not come. I change display cable & video board also but problem not solve.So, Pls. guide me. Thanks.
If again again display problem create then i suggest you change mother board and purchase own device supported mother board. If change mother board then display problem solved, but one step you change RAM may be your RAM device week and damage. So you first of all change RAM then finally change motherboard.
Thanks...
Oct 09, 2013 | LG 700M 17" CRT Monitor
My GA-VM900M Mother board gives a long beep after another when I switch it on. The monitor remains black and the power light stays on.
Hello here is the homepage:
http://www.gigabyte.com/products/product-page.aspx?pid=2581#dl
Drivers or the manual can be selected in download type.
A long beeb is a fault in a RAM module.
Try to insert a ram module you know is working.
Your mainboard use DDR 2 ram, up to 4 GB.
Another fault could be the power supply.
Blow also any dust out with compressed air before working on the mainboard and take antistatic precautions
Here is a list of beeb codes:
http://www.computerhope.com/beep.htm
Good luck
Jan 04, 2013 | Computers & Internet
MOTHERBOARD ON BUT NO DISPLAY
Is the monitor turn ON. Is the monitor still connected to the computer. The graphic card is bad or your monitor is bad or the mother board is bad. Check to see if the fan is working in bark of the computer of the power unit when the computer is turn on. If it is not working then your power unit is bad.
Mar 25, 2012 | Gigabyte Computers & Internet
CPU, Prossor fan are runnig well. mother board LED are working. I Remove RAM Then on the sys. but NO BEEB sounds. I Clear CMOS Battry. THEN NO Display in monitor.
Please remove the memory card and clean the pins with a rubber eraser from any stains that causes no display in the monitor.
Jan 27, 2010 | Asrock P4I45GV R5 Motherboard
Gigabyte GA-945GCMX-S2 Motherboard having display..
At first I thought your screen went black during the start up process. After seeing the bios screen. In which case I would've said it was a bios setting for the display. Then I realized that I think you mean that their is no display at all. When you push the power button. Only the monitor led light. So, it may be a problem with your RAM stick/s. You should make sure that they are properly seated in the mother board. If they are new, make sure they are compatible with that motherboard. If you can you should swap them out with known good ram sticks. You could also try installing a video card and see if you can get display to work through that one. Make sure your main power supply wire connector is pushed in all the way. Swap the power supply with a known good one if you can. If still can't get it to work you may want to take the motherboard out and inspect it for burns, cracks, and anything that doesn't look right. Maybe contact the manufacturer of the motherboard and ask them what you can check. hope this helps.
Sep 17, 2009 | Gigabyte GA-945GCMX-S2 Motherboard
Intel desktop board D845wN - no screen display
HI,
Switch on your computer and listen for a beeb sound.... if no beeb sound available then your Motherboard has a problem.
if beeb sound comes then switch off your computer and see for the loose contacts on motherboard.
eg. remove ram, clean ram socket and put back the ram
your problem may solved.
thanks
ehsan (md_ehsan_1@yahoo.co.in)
Jun 15, 2009 | Intel Desktop Board D845WN Motherboard
Gygabyte ga-81915 me mother board details
i have GA-81915ME Motherboard.i reinstalled my system with windows xp os now i am not able to get sound from my computer please tell any method to solve this problem
Dec 04, 2008 | Gigabyte GA-8I945P-G Motherboard
Gigabyte ga-8ld533 mother board problem
i have a problem with my mother bord 8ld533.my head phone is not working properly also its working with a small sound,alredy a have installed my sound driver..can you help me please...
Oct 31, 2008 | Gigabyte GA-8LD533 Motherboard
Intel Motherboard Logo
207 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
