Question about Samsung DVD-R130 DVD Recorder
Hi there. I have the SAMSUNG DVD-VR336 combo. Im using the Verbatim 6 speed DVD-RW 4.7 gig DVD Discs. While its Initializing, it gets to about 25% and says " Cannot intialise because of Error Detection". Ive tried about 3 discs and they are all the same error. Regards Julian
  • julian269 Apr 17, 2009
    Hi there, as I wrote, I have tried 3 differant new discs and they all have the same error
    Brigadier General:
  • 8,619 Answers
Hi!
Please turn off your DVD player/combo and unplug it from the wall socket for 10-15 mins. Then try and insert a different DVD. If it still does not help then try and reset your Samsung DVD Combo.
Please see this link for downloading the manual for your DVD Combo---
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 17, 2009
  • 1,170 Answers
If ADIP reading fails, the disc is defective, because it's the very first stuff on the disc. Try changing the Disc. It may not be with the writer.
Hope I helped with the repair of your problem.
An Accept from you is how I get paid.
And a positive feed back tells me how I did with the repair.
Arjun
  • 10,515 Answers
Hi julian269,
  This is a DVD recorder problem. The disc is absolutely  fine.     There is no hard and fast fix for the same. We can use basic fixes....
1. Use a lense cleaner.I hope if there would be any dust particles or any clogs, that would be taken off.
2. If not, open the player ( Make sure its not in warranty ), there is a lense just below the plastic panel. Take a soft cloth ( i would prefer cotton ), just try to clean that. Again, close the  flap and than try to use that.
 I hope this would fix your problem, unless sorry to be bearer of bad news, you need to change lense. I would recommend you than to check what would be the price of the orginal lense ( local lense would extend the life upto one year on an average )..........
Also, check if you can grab  a used lense on ebay... ( In working condition )....
http://www.ebay.com
On comapring all options, its your decision to make a repair or purchase a new one ( That would a good idea, keeping in mind it would not create any problem in the next couple of years atleast )......
I hope my solution would be able to guide you in a proper direction.
Thanks for using fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Help quetion
Which brand of DVD-R disc did you use? What error did you get? What is your video source? Most TVs don't give video output. The tuner on the WV20V6 is an NTSC (analog) tuner. Thus you need to use a set-top box (OTA digital-to-analog converter, cable or satellite box) with the recording "channel" set to video input 1 for most channels or analog cable input to the recorder.
Verbatim DVD-R 8x, Maxell DVD-R 8X/16X and JVC DVD-R 2X have been tested and proven to work by the manufacturer. A number of DVD+R and DVD+RW or DVD-RW have been tested as well.
I've found that you have to test each batch of DVDs. Different manufacturing plants can lead to bad discs from a previously good brand.
The manual for the WV20V6 is available from Funai Corp (who manufacture the recorder for SV2000). The direct link is http://www.funai-corp.com/support/om/WV20V6.pdf . See page 25 of the PDF for tested optical discs. No CD-Rs will work.
I hope this helps. Please add a comment with more information about your situation for additional support.
Jun 22, 2013 | Funai WV20V6 SV2000 DVD Recorder and VCR...
When trying to record a home video VHS to DVD this is what I get. E-4 54040990 Cannot record on this disc. The disc is brand new.
Have you've tried cleaning the laser with a cleaning disc?
Failing this it may be worth removing the cover and cleaning the lens directly with a QTip and some lens cleaning fluid. Only use a drop and then wipe off with a clean dry QTip.
The other option is that you are using an incompatible format of blank DVDs. I've heard of people having problems using DVD-R & DVD-RW and although it is lised as being suitable for all types of recordable DVDs I belive you're best using DVD+R & DVD+RW.
The Manual states
Recordable disc
• We strongly recommend for good recording quality:
SONY DVD+RW 4x, MAXELL DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, TDK DVD+R 4x/8x/16x,
MAXELL DVD-RW 4x, MAXELL DVD-R 8x/16x
• Discs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+RW 4x VERBATIM DVD+R 8x
VERBATIM DVD-RW x VERBATIM DVD-R 8x JVC DVD-RW 4x MAXELL DVD-R 16x
May 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Toshiba D-VR16SB Gets error code: e4 54037380
This DVD combo will only read DVD-RW and DVD-R format discs the manual says that Verbatim DVD-RW 2X are the best to use also TDK DVD-R
Apr 25, 2010 | Televison & Video
Won't work with the same kind of discs i've used before
I not sure as to which type of Discs that you are refering to (ie DVD+R or DVD+RW). This player will only recognize 4x (max) DVD+RW and 8x (max) DVR+R discs. If the DVD+R Disc is 16x, the DVD recorder will not recognize it once you start to record. The player will read the blank Disc and give the impression that it will record on it. I have noticed that when a 16x speed Disc is in the Drive, The recordable hours for the disc seems to double. The normal 6 Hour recording length comes up as 12 Hours when you hit the info button. Since the 8x Speed (max) discs are not available any longer, I found it best to use the DVD+RW 4x Discs and make it compatible. I then copy the compatible DVD+RW disc to a 16X DVD+R disc using my computer DVD burner. The DVD+RW disc can then be erased so that it can be reused.
Nov 23, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Samsung dvd rw with octo edge dvd rom says burning failed for dual layer disc
I will presume that you do not have a combo DVD.
If you have a "combo" drive, it doesn't burn any DVDs.
First, has the burner ever burned dual-layer DVD's successfully?
Radio Shack has a laser cleaner ($13). Read & follow the directions. It is an audio CD with a row of brushes. No chemicals involved.
Recommendation:
Use Verbatim DVD's, they are the best. Samsung is also a top brand.
Oct 02, 2009 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
I'm unable to find DVD discs that will record in my machine. I was using Maxell DVD+RW 4x but am not able to find them. If it says "up to 4x" it will not work. If I buy Memorex 4x, they won't work. I saved...
I have found that the DVD recorder in this unit will not recognize a DVR+R disc greater than 8X speed. Therfore 16X discs are not an option. Like you already know, it likes DVD+RW 45X speed discs but it is selective. I have been using Maxell DVD+RW 4x and have found that Verbatim DVD+RW 4X and Sony DVD+RW 4X work just as well.
Jul 04, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Rca DVD/VCR COMBO SAYS NO DISK INSERTED WHEN IT IS
open your vcr and locate the lens.then get cotton budds and clean the lens manually.
Sep 02, 2008 | RCA DRC8300N DVD Recorder/VCR
Problems with dvd reading
I HAD THE SAME PROBLEM WITH MY LG DVD RECORDER NOT EXCEPTING CERTAIN RECORDABLE DISCS . NO GUARANEES BUT TRY GOING TO YOUR SETUP MENU AND RE-SET THE ORIGINAL FACTORY SETTINGS FOR THE RECORDER THEN PUT A DVD CLEANER DISC IN YOUR RECORDER TAKES ABOUT TWO MINS TO CLEAN UNIT THEN TRY A BRAND THAT DOES WORK IN YOUR RECORDER OTHER THAN VERBATIM OR MAXEL . RECORD SOMETHING THEN EJECT IT . NOW TRY ONE OF YOUR MAXEL OR VIBATIM DISCS AND SEE IF IT WILL READ THIS TIME FOR RECORDING . GOOD LUCK . BEST REGARDS , blc7772001
Jul 21, 2007 | Cyberhome CH-DVR1500 DVD Recorder
Loading DVD-RW discs
My recorder has stopped accepting NEW DVD-RW discs and ejects them.
There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording
I have tried several different DVD-RW makes. Puzzling??
Nov 03, 2006 | Pioneer DVR-5100H DVD Recorder
Problems recording DVD-R 16X
Try this download page to update your firmware from 25/10/05, so if you bought your writer before this date maybe this will work, otherwise buy 8x discs. http://sony.storagesupport.com/dvdrw/firmware.htm#710 The faster the discs are burned the more chance of errors there are, you should write at slower speeds for better quality.
Oct 27, 2006 | Sony DRU-710A DVD±RW Dual Layer...
Samsung DVD-R130 DVD Recorder Logo
151 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
