Question about Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore UltraWash QuietGuard 4 making horrible buzzing/grinding noise when the motor is running - it starts as soon as the tub is full of water and begins washing - and remains until the wash/rinse cycle is over and drying starts. Help!
  • longk Apr 18, 2009
    Thanks so much for the suggestion - my husband and I looked all through it and couldn't find anything out of the ordinary under or around the sprayer arm... any other suggestions? Thanks in advance!!!
  • luaPnoR Apr 19, 2009
    I had/have a similar noise problem intermittently, and had Sears service out this week. He came in, started the machine on a short cycle (not what I use) heard nothing, walked back out to his van, smoked a cigarette, came back in and said,"It's the pump. To replace it would cost $500, so you might as well just use it until it 'dies', then get a new dishwasher." Then he plunked down a 75 Dollar 'service' bill!!!....Some help
  • 121 Answers
You have a peace of glass or plastic stuck in bottom
Posted on Apr 17, 2009
  • lojacksdad
    lojacksdad Apr 18, 2009
    hello
    the only other place things get stuck is under the strainer mat at the bottom that will take a couple of screws to get out if you feel brave then look around the disc in the middle that is called the impeller
    any farther than that is down in the lower impeller kit will be required
We have a water remains in the bottom of the dishwasher Kennmore Quiet Guard 4
What could be the problem?
Posted on May 30, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
How do I remove the motor pump on a Kenmore Ultrawash - QuietGuard "Deluxe"?
You may be able to find a solution with this video. Be sure to check the comments ... your problem seems very common.
Dec 29, 2012 | Kenmore Dishwashers
Kenmore Ultrawash Quietguard Deluxe Problem
kenmore washers nothing but problems, my washer says clean and will not do any cycles...... less that 2 years old
Oct 21, 2009 | Kenmore Dishwashers
Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Can hear motor running but nothing happens in dishwasher
Hi, you need to test voltage to the water inlet valve. If you are getting voltage (120V) replace the valve. If you are not getting voltage check the water level switch located in the front corner of the tub.
If I can assist you any further with parts or part #'s, please let me know.
Thanks
Vic
May 16, 2009 | Dishwashers
Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Feb 05, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Nov 18, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Nov 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Quietguard Plus/Ultrawash - Kenmore
drain hose may be partially clogged or kinked up. ensure that the hose is not bent up thus restricting the flow of water out.
Nov 26, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
Noisy dishwasher
i have aloud buzzing nose and humming what is the problem
Oct 29, 2007 | Dishwashers
Kenmore 24 in. 15689 Built-in Dishwasher Logo
1,624 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
