Question about Canon NP 7130 Black and White Copier
Need to know where do i have to hang the 2 resources that are on the side door
Hello i have an NP 7130 canon copier and i had to open the side door because a paper sheet locked there. so when i openned the two resources that are on each side of the little door went out of the door, i just want to know where is th correct place to hang those resources , thanks
  • extraboots Apr 17, 2009
    yes i mean springs
    thank you
  • hinderschied May 11, 2010
    by saying resources, do you mean springs?
    Sniper:
  • 67 Answers
I believe the 2 springs hold your side door closed, alot of people use scotch tape to hold the door closed.
Anyway 1 goes on the left side and the other goes on the right side of the door. If you open the door and look down on the plastic frame, not part of the door, you'll see 2 holes on the left and 2 more on the right. The one end of the spring slide down thru the 1 hole and turn it 90 degrees and pull it up so it hooks on the plastic piece between the 2 hloes. Do the same for th other side. Now, the top end of the spring attaches to a plastic tab in line with the holes on the door, toward the top side. Some times those tabs break off.
If that's the case we'll have to get a little creative
Good Luck
Bob
Posted on Apr 17, 2009
How do I change the drum to a Canon NP 7130 Black and White copier?
Could be the drum or the fuser causing your problem. To replace drum you need to open the machine by hitting the gray release latch on eft ide of machine to clamshell it open. Inside you will see th toner cartridge/ dv unit on the far right and immediately to the eft of that is the drum unit. You need to release the dv unit by turning a lever before removing the drum unit. Should probably call a tech to do this for you so you dont scratch or damage the drum. Drum life on that model is about 30,000 prints. Whats the meter reading on that copier?
Jul 25, 2012 | Canon NP 7130 Black and White Copier
I need a service manual for an Canon np7130
I found a service manual for this model. If still need it let me know.
Apr 08, 2009 | Canon NP 7130 Black and White Copier
Copier canon NP 7130, the images don´t show
what actaully you need? if you need a manual is another issue but if you need your machine to work do this.
1.check the corona wires in corona units if broken replace if not
2.clean the corona units so that they will be free from discharging.
please vote me
Nov 14, 2008 | Canon NP 7130 Black and White Copier
Canon np 7130 copier
ur waste toner can is filled up. open & pure waste away, close and power.
Nov 10, 2008 | Canon NP 7130 Black and White Copier
Canon np 7130
first try to look for the drum if it scratch no matter the distance btn lines
then if the drum is ok. look and adjust the position of the lens to home position.
Aug 07, 2008 | Canon NP 7130 Black and White Copier
CANON NP 7130
This is your drum unit or transfer unit that must be replaced.In what area are you?
Jul 14, 2008 | Canon NP 7130 Black and White Copier
Replace drum
hi im jules_09.at the packaging of the drum has a instruction that will show you the process in replacing he drum or just open the front door of the copier the drum unit has a lock for you to lit up just a small lever or 2 lever.after that you can easily full out the drum.just remember just dont let the drum before be expose to light it is sensitve to mit.5minutes is enough time for it to be expose morethan that the drum becomes deffective
Nov 05, 2007 | Canon NP 7130 Black and White Copier
Error "E0" on a Canon NP 7130
E000 on a 7130 is a lockout error it needs to be reset. you need to remove the control panel remove the 2 screws that attach it to the body on the left and right sides open the **** shell and pull toward you. Flip up on the top of the unit with the circuit board facing you look for two metal jumpers labeled jp103 and jp104 short across the 2 with a small screw driver to enter service mode( can be verified by an "F" in the display) power down the copier reinstall the control panel and reboot. If the fixing assembly is good the error will be cleared
Oct 29, 2007 | Canon NP 7130 Black and White Copier
Canon NP 7130 Black and White Copier Logo
67 people viewed this question
old marine
old marine
