Question about Car Audio & Video
JVC KD-S656R Unit won't power up
I'm trying to fit a JVC KD-S656R unit to my wife's Rover 214 but can't get the unit to switch on. Its wired as below, 1st is from unit, 2nd from wiring block: Yellow (battery) wire to lilac wire Red wire (accessory terminal) to green with white stripe wire Black (ground) wire to black wire Blue with white stripe wire (power aerial) to nothing Help please? Martin.
simplemitch
  • 752 Answers
SOURCE: Wiring Problems
You didn't cut the plastic connectors off the factory wiring, did you? One is gray and one black.... if not, just get to a stereo shop and buy a wiring kit for your car and all colors will match. They're about $10. If you DID..... well..... we have a LOT of work to do....
Posted on Sep 11, 2007
  • 4102 Answers
SOURCE: re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Posted on Apr 21, 2008
  • 14 Answers
SOURCE: DEH-P80MP need wiring/color description
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/103539332INSTALLATION%20MANUAL%20DEH-P80MP.pdf
Installation guide for your model with wiring diagram.
Hope this helps.
Posted on Dec 25, 2008
rteemon
  • 578 Answers
SOURCE: wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Posted on Jun 25, 2009
Raditronic
  • 196 Answers
SOURCE: jvc unit
check down the radio. down the radio is the diagram chart.
Posted on Apr 28, 2010
How can i save my settings on jvc kd-r446 ? every time i shut down my settings is reset
if it is resetting oon shut down , you dont have your memory wire connected to a full time power wire . full time power wire is a wire that has power even when car is off.. this is what saves your memory on the head unit.memory wire is usually yellow.
Feb 26, 2014 | JVC Car Audio & Video
Jvc kd bt11
hi vicki, firstly check out the power wiring to your unit. yellow wire to the battery +12v(direct live) and the red one to the ignition switch(vehicle start switched live). also try resetting your unit. if all these donot work then check out your local installer before handing the unit in for repairs. good luck. cheers.
Sep 06, 2013 | Car Audio & Video
I bought a JVC KD-R620 and I can't get To power on without having the ignition wire(red) and the battery wire(yellow) connected. And it won't save my settings either..I don't have a blown fuse...
Ok, just so I get this right. You want this unit to power up, without hooking the 2 power wires??? Red is constant power, yellow is switched power. Did you use a wiring harness to hook the radio up or did you hard wire it? I alway recommend a harness. This would make the install easier. If the unit works witht them wired, use it.
Sep 03, 2011 | JVC Car Audio & Video
Why does my jvc kd-r526 reset to factory default everytime i turn it off
Try connecting the yellow wire to a constant power source. That is, a source that still has power when the key is turned off. The yellow wire controls the memory of the radio.
Jun 02, 2011 | JVC KD-R800 Car CD/ MP3 Player
I have a jvc kd-shx701 car stereo , what way round do i connect the wires so i have no memory loss in my land rover discovery tdi.
yellow wire from the head unit should be connected to a +12 volts at all times as to not to lose memory.
Mar 13, 2010 | JVC KD-SHX701 CD Player
Radio wiring
The JVC unit has a RED wire, it sounds like this is connected to a power source that is ON with ignition...this is OK. Your unit also has a YELLOW wire, and it sounds like this also connected to a power source that is ON with ignition.....NOT OK....this wire needs to be connected to a power source that is On all the time.
Mar 12, 2009 | Car Audio & Video
Jvc kd-sc500 cd car stereo
CHECK TO SEE THAT THE BLACK WIRE IS AT A CLEAN GROUND.....AND YELLOW AND RED ARE POWER..
Jul 21, 2008 | JVC KD-SC500 CD Player
Instlling kd-avx1
You can download the manual direct from jvc on their website, all instructions and drawings are present
Apr 29, 2008 | JVC KD-AVX1 Car DVD Player
Car audio
Can't really help without seeing the item - but I know it is very difficult to fit a 'different' radio to cars nowadays as they are all 'cutom-built' just to fit their vehicle.
What do you mean ' the wiring is too large at rear of unit ' ?#
Is this the radio itself you mean - what wiring is at the rear of the JVC KD G431?
Mar 11, 2008 | Audio Players & Recorders
Car Audio & Video Logo
152 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
