Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Can't keep my engine running after shutting off the choke, I have cleaned the spark plug and it seems like it is flooding out
  • josh1111 May 11, 2010
    have you trieed adjusting the carb? how old is the saw? it may be internal engine damage.
  • charles raynor May 11, 2010
    When was the last time you took it to the saw shop for a tune-up and adjustment?
    Problem Solver:
  • 19 Answers
CHECK TO SEE IF YOUR GAS OIL MIXTURE IS CORRECT.
Posted on Apr 29, 2009
Won't start, gas out of exhaust
Sounds like its flooded : excess fuel / wet spark plug.
Empty tank / Clean and dry spark plug. test plug for spark before refitting. If strong spark refit plug / and see if fires when turn engine over.
If it does then refill tank with new clean fuel and attempt to start without choke to avoid flooding.
May 25, 2016 | Toro Garden
How do you start a 19th mtd riding mower
Put your left foot on the clutch pedal and push down all the way on the clutch. Move the throttle lever all the way to the top, this turns on the choke. Turn the key clockwise, to the right, to start the engine. Once the engine has started, move the throttle lever down to turn off the choke. You only need the choke when the engine is cold. If you use the choke while the engine is hot, you can flood the engine (too much gas) and this will fowl the spark plug. If you have flooded the engine, turn off the choke by lowering the throttle lever and try to start the engine a few times. If the engine doesn't start, then you may need to wait 20 to 30 minutes before trying to start the engine again. If the engine still does not start, then you can remove the spark plug to dry and to clean the spark plug. With the spark plug out, turn the key to the start position for 10 seconds, to push out excess fuel and fumes. Replace the spark plug and try starting the engine without turning on the choke.
Oct 08, 2014 | Garden
I got my mower out the other day it did fine till I engaged the electric pto, it then died and I cant get it started since then. It is getting spark and is getting fuel. It act like it is flooded , I have...
If the fuel is set too high and the choke is on it is easy to flood it. The solution is to open the choke and keep the throttle low for a few turns to air dry the spark plugs then back to choke to start it again
Oct 16, 2013 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Want keep running after several times of starting it
will it continue to run on choke? if it does you have an air leak, if not then you may have a faulty carburetor that isn't stopping the flow of fuel and it is flooding itself out
Jan 11, 2013 | Stihl GUIDE BAR 16 in STHIL CHAINS
I have gas in my oil and gas is pouring out the spark plug hole wats the cause of this?? sears crafsman lt 1000 briggs and straton intek,18 hp needle valve in carb seems ok,fuel solenoid working wat...
Gas in the spark plug chamber should mean it is flooded.trying to start it for too much time with the choke on will do this.when starting cold,engage choke.turn engine over till it tries to start.if you can't disengage the choke before it stalls,do not re-engage the choke.just keep turning the engine over,or pull starting,whichever you have,until the unit starts.it will.for now,if the sp.plg.hole has fuel in it,blast compressed air to clear it somewhat,re-install sp.plug,never overtightening,just snug,and try starting without the choke.hope this is useful.bart.i am a certified small engine mech.and remember when finished,let unit idle for 2 min. Or so and cool before shutting off.change oil religously every 50hrs.for units over 10hp.,every 25 hours for engines below that.they will last a long time.clean air filter after every two or three uses.never empty fuel when storing,use STA-BIL.
Sep 23, 2011 | Garden
I have a cr 125 2003 model , my bike was running and starting fine but today it cut out t, the spark plug is firing there is fuel coming threw but it is not firing up ,there apperes to be flooded as the...
HI, IF IT IS FLOODED, TURN OF THE FUEL AND OPEN THE THROTTLE FULLY AND KEEP AT THIS POSITION WITHOUT THE CHOKE,KICK REPEATINGLY AND IT MAY FIRE EVENTUALY,
RREMEMBER THAT THE CHOKE INITIALY FLOODS THE ENGINE FOR COLD STARTING, SO USING THE CHOKE WHEN ALLREADY FLOODED WILL WORSEN THINGS,
YOU COULD PROBABLY REMOVE THE EXHAUST TO DISPENSE THE FUEL QUICKER AND PUT IN A CLEAN PLUG, I WOULD DO THIS BEFORE I STRIP DOWN THE CARB TO SEE IF THE PROBLEM CLEARS, AS THE BIKE WAS PREVIOUSLY RUNNING IT SEEMS ODD TO START MAKING ADDJUSTMENTS
Feb 27, 2011 | 2003 Honda CR 125 R
I had this saw tuned up a few years ago and put it away. I added new fuel (40 to 1 mix) took out the spark plug and checked the gap.025 and didn't even have to clean it. I set the choke to full, made sure...
I don't know the plug number. Off the shelf chain saw plug from small engine repair shop will replace existing plug.
First of all, are you getting spark?
Take out plug. Put spark wire on plug. Hole plug by spark wire. Touch metal threads of spark plug to metal part of engine block. Metal to metal. Pull cord. Look for spark between metals. If there is no spark, then spark coil is bad.
Look at exhaust port. Is there anything that would stop the exhaust from escaping?
Can you get to fuel line running into carburetor? See if gas makes it all the way to the carburetor.
Can you get to the air filter? Is it dirty? Can you spray WD-40 directly into carburetor. A saw that has good exhaust, spark and compression will fire on WD-40.
If your engine can fire on WD-40, but will not stay running, then carburetor is suspect. Maybe gum out will work. Try to keep the engine going on WD-40 and see if that opens the carburetor.
If you can keep engine going on WD-40, that takes both hands ... use your third hand to move choke and throttle levers and see if the engine can start on its own.
Upvote if this information helps. Thanks for the feedback.
Oct 15, 2010 | McCulloch Garden
Honda engine will not start,,,new plug, new gas, new oil
Karcher Model G2650 OH with Honda 6.0 HP, GC 190 Engine. Engine won't start. New gas, has spark. Seems to flood instantly. Much gas in cylinder. Spark plug wet. Choke pulled out, power on. Oil OK. released pressure in line. Where can I down load a Honda Engine manual! Thank you !
Jul 06, 2010 | Karcher 2500 PSI Pressure Washer
I bought a used coleman powermate 5000 generator, I replaced the spark plug and fuel filter, it finally started up,it would only run in the "choke" position it ran about 10 minutes and then shut down, I...
What brand of engine & horsepower is it?Also about how long was it stored or last time it was run? The reason I ask is if it was stored with gas in it & a fuel stabilizer wasn't added to it,your primary jet is plugged in the carburetor(reason it will only run while choked).
Jan 07, 2010 | Coleman Powermate Powermate 5000W...
Motor will not start. Plug is igniting has spark. seems to be to much gas. mberko1481@aol.com
First thing to check would be your air filters make sure not blocked as this will act as the choke if blocked and will flood the engine,
If all is well remove plug and remove as much excess fuel as possible with compressed air etc, then reassemble and see if it will fire,(With full throttle and NO CHOKE) you may have to repeat this a couple of times...
Once you get the engine to fire it may geep running if the engine was just flooded otherwise if the engine floods again then you will most likely have a problem in your carby mabie a piece of rubbish under the needle valve holding it open causing the engine to flood and the carby will have to be cleaned and tank flushed
Good luck with it hope this helps!!!!
Kind regards
Brad
Dec 29, 2009 | Mi T M 13 Hp, Honda Ohv, Compressor, 3500...
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
259 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
