Question about Western Digital My Book Home Edition 500 GB USB Hard Drive
WD 500gb external HD shuts down when plugged into USB port
The hard drive runs fine when it's not plugged into the USB port. Once I plug it into the computer it shuts down. I had this problem before but I plugged it into a different computer and it would work. I've tried it on 3 different computers now with the same results....it shuts down. Help please!
  • 19,396 Answers
Try a replacement USB cable first. If that does not fix the problem, then the USB to SATA adapter board is faulty, in that case you will need to take out the internal disk to replace the external enclosure.
see
YouTube - How To: Take Apart A Western Digital My Book Enclosure
If unit is under warranty see : WD Support > Warranty Services > End User > Warranty Policy.
Note any SATA external enclosure willl work wthe same with the internal WD HD.
Posted on Apr 17, 2009
I have the Western Digital fire wire 500GB. Once it's plugged in it shuts off after about 7 seconds. I see a light flicker inside and it goes out too.
all external HD need power to run. is this running on AC, USB or Firewire........ if USB or Firewire is your computer compatible with the HD power needs if it is compatible
and if this is straight out the box, return it is defective........
Apr 10, 2011 | Western Digital Computers & Internet
My Transcend 500GB is not working on my Dell Inspiron 1464 Windows 7 Home Basic But other USB devices like pendrive etc works fine. Also My Transcend 500 GB works fine on other machine has Windows 7...
The chances are that the portable drive is drawing more current fom the USB port then the port can supply. The current limitations on the USB ports are controlled electronically and if anything is connectedthat attempts to draw more power then the port can safely supply, the port is shut down.
You may have to use a USB power injector which you plug into the laptop and then plug the drive into that.
Mar 08, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
I bought the Western Digital Elements External hard drive-500GB and it worked fine with my computer. I took it to my brother's house to download some data and his computer DOES NOT RECOGNIZE it when it's...
HI, YOU MAY WANT TO TRY, REMOVE SECURITY FROM WITHIN THE SMARTWARE, THEN AND AS ALWAYS, MAKE SURE THAT THE DRIVE, WHEN BEING CONNECTED/DISCONNECTED, THAT THE PC IS COMPLETELY SHUTDOWN.............. I HOPE THIS HELPS.........JEFFXC
Jan 25, 2011 | Western Digital Elements powered by WD 320...
I have a WD 500GB External Hard Drive. It has
That could even be a USB problem, I have the same one, my issue turn out to be just power. You are not the first one to have that problem. Replace the USB cord and see if that affects anything.
Mar 25, 2010 | Western Digital My Book Essential 500GB...
I have 500GB SimpleDrive USB 2.0 External Hard Drive, but currently i am facing some problems with it. When i plug it in to my computer, the computer says that unknown device. and it also does not come to...
I would unplug the external drive then shut down your computer. Plug the drive in(be sure the USB port is in good working order.)Turn the computer on. If it does not recognize the drive search online for tech support for that particular drive. Install any drivers or software. Be sure to find out if the drive is compatible with your operating software. Make sure all connectors are seating firmly and correctly. Make sure that everything is plugged in where it should be plugged in.
Feb 15, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
Hard drive will not turn on, light blinks
sounds like the powerboard bit is knackered on the case try taking the drive out the case and buying a hd caddy sata 2 usb
Jan 01, 2010 | Western Digital 500GB ELEMENTS 500 GB USB...
Connecting WD Passport external HD with Belkin N+ router
I had this same issue. Found it to be a sequencing issue. Plug the USB into the router with the power off to the HDD. Power on the HDD and you should be able to get to it fine. Also make sure you have the latest firmware on the router.
Nov 27, 2009 | Computers & Internet
WD 500Gb HDD not showing up in my computer, etc
Maybe the best thing to do is,
1) Remove WD External while pc is switched off
2) Reboot into windows
3) Doenload Ccleaner > http://www.homepc-security.co.uk/Downloads%20&%20Tutorials.html Then install.
4) Make sure you have Cleaner highlighted on the left near the top. Then put cheque marks in all boxes except, Windows Size/Location Cache, User assist History & Wipe Free Space then click Run Cleaner. Once you have repeated the step of running Run Cleaner till nothing else appears, then select the Registery cleanerthen click Scan For Issues and delete all that you find there also. Turn off pc, remove power cord then push the on button to discharge the pc, then plug in the WD Hard drive via a diffrent usb port, and boot up pc. I hope this works for you.
Jul 27, 2009 | Western Digital My Book Essential Edition...
WD elements 500GB -
Had the same thing .... called them and they gave me a RMA for a new drive .....
Jul 22, 2009 | Western Digital Elements powered by WD 320...
WD My Book 500g HD error. Turns off when USB is plugged in
Check the USB port on your computer. It's very likely that the problem is there. On my computer USB ports stop working sometimes and the HD does exactly that. HOwever, when i restart the computer, everything works fine.
Mar 30, 2008 | Western Digital My Book Premium ES...
Western Digital My Book Home Edition 500 GB USB Hard Drive Logo
515 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
