Question about Wanlida Group Malata 500 DVD Player
Video output setup
í have a huge problem with the malata (DAV 3600) video output. The scree was red so I went into the setup video output but I have not enough (time) signal to choose the second option cvbs - third one is maybe saved. I´m loosing my picture and signal after only 5-8 seconds. So how can I get my signal back.
thanks a lot and kinds regards form Europe
Valérie
2 Suggested Answers
SOURCE: malata ltd-1710 no video problem
So now I can't get the solution for free ...?
Posted on Apr 05, 2009
How to connect DAV-HDX265 to xbox 360 and TV
Your HDMI cable handles both audio and video. If you would like a "one" source output you need to have a reciever that has multiple inputs with one output. You would then put your audio out from your souce device (xbox, tuner,record player...etc.) to the input of the reciever. Every device should have a different input. From there you would just switch your input selection to what you would like to hear. Let me know if you need a bit more guidance and I will get more detailed. The RCA connection (Red and White) are your stereo leads or (left and right) You will need the yellow one for video..it is separate.
Jan 19, 2013 | Sony DAVHDX265 System
I am looking at connecting multiple components with DAV HDX275 Sony surround sound system. But it appears that there is only one red/white/yellow jack on the back of the unit. Any suggestions?
hi,
check one more time. your player DAV HD 275 have component video output. three sockets near the yellow, red, white sockets. Named Y, PB/CB, PR/CR.
remember on thing when you connect the component video, be sure to connect the red to red, green to green and blue to blue. if not you will not get the correct video. will become out of sync or black&white
ok
Jan 24, 2011 | Sony Audio Players & Recorders
I am usin the components port to connect my Sony home theatre DAV-DX250 to my TV Sony Wega, and it doesn ot work, I just get static. Any idea what the problem is? thanks in advacne
You need to turn On Progressive Scan mode in home theater system to get video output in component video out ports so tv can show its picture.
Progressive Scan mode can be turned On by going into setup menu of home theater, details are available in user manual.
Thanks.
Nov 29, 2010 | Sony DAV-DX250 System
I want to set up my dav-fr10w to 'interlace' option so i can play the dvd's on my tv, but it's set to 'progressive' right now and the instruction manual doesn't give the specific information to change it....
To cancel Progressive scan output or to change output to interlace signal format, follow these steps..
1- Select DVD by pressing Function button on unit.
2- While holding down |<< (review) button, press Function button on unit.
This will change output signal to interlace/ composite video output from yellow pin/ S-Video.
Hope this info will help you.
Thanks.
Feb 05, 2010 | Sony DAV-FR10W System
Hi,I can play a DVD disc on the system and get sound from the surround sound speakers but I can't get a picture on the tv,Sony Trinitron.The connetions are from the DAV S500:(DVD only)red and white cable...
First try with yellow video output of DAV-S500 in yellow video TV input to get its picture. (yellow output means composite video out)
Green-Blue-Red video output is component output that will be turn on when you switch the unit into Progressive picture mode, that option would be available in Menu of DAV-S500
Thanks.
Nov 29, 2009 | Sony DAV-S500 System
Connect cablebox/dvr to sony bravia
try yellow cable into the green y input.
http://en-americas-support.nintendo.com/app/answers/detail/a_id/3008/~/unable-to-locate-a-yellow-video-input-on-the-tv
The problem is that av output is going into component in
If the green port doesn't work I read on another forum that
you may be able to use a dvd recorder unit to take the av in and then it can re transmit the video to an output as component out on some dvd recorders.
Apr 29, 2017 | Sony BRAVIA® DAV-HDX576WF Theater System...
SONY DAV - S880 compact AV system
Sony.com may have a pdf downloadable manual available on line.
The standard way to connect Audio from a Receiver to a TV is to send a signal from the Tape outputs (RED & WHITE) on receiver via RCA cable to a Aux input (RED & WHITE) on the TV. Likewise, sending a Video signal from a receiver to a TV, is via a Co-Axial RCA cable , using a Video Out (YELLOW) on the receiver to a Aux Video Input (YELLOW) on the TV. An S-Video cable can also be used (in leu of yellow RCA cable) if available on both Receiver & TV.
Jun 10, 2008 | Sony DAV-S880 System
Malata DVP 892 hookup problems
I had the similar problem at first. You need to use another disc before you can configure the video output. Make sure you enable the HDMI output.
Apr 21, 2008 | Wanlida Group Wanlida/Malata Combination...
Sony DAV-SC5 not playing 5.1 through the optical input from sky/blu ray
The DAV supports Dolby Digital® DTS 5.1 audio. Make sure your blueray movie has 5.1 track and is outputting to the DAV.
Jan 26, 2008 | Sony DAV-SC5 System
Component Video Connection
what you have done is you are sending a component video signal from your system to your tv and the sound i assume comes through the 5.1 surrond speakers. The DVD's you play the sound would naturally come from the 5.1 surround speakers, unless your instruct the dvd player to send the sound to the tv in which case will only be played as stereo. you will need inputs on your dav system to take sound from your tv outputs or digital box by way of red and white phono leads or a digital/optical input if you have them; so as to play the sound from cable tv or sattelite tv through your 5.1 surround speakers.
Sep 04, 2007 | Sony DAV-SC5 System
Televison & Video Logo
43 people viewed this question
Top Wanlida Group Televison & Video Experts
Are you a Wanlida Group Televison and Video Expert? Answer questions, earn points and help others
