Question about IBM ThinkPad T30 2366 Notebook
IBM Thinkpad will not turn on wireless connection
Got error that operating system was not found - then one that hard drive wasn't there. Replaced hard drive and reinstalled XP, but the wireless connection is nowhere. Have wireless network in my house that should be detected automatically. How do I get to it?
1st go to MY COMPUTER, RH CLICK-PROPERTIES,HARDWARE TAB, DEVICE MANAGER,NETWORK DEVICES. CLICK ON THE + TO OPEN THE INSTALLED
NETWORK CARDS. YOU SHOULD MOST LIKELY HAVE 2 LISTINGS 1- YOUR ETHERNET PORT
2-YOUR WIFI CARD. THERE SHOULD NOT BE AN EXCLAMATION POINT OR A QUESTION MARK, EITHER INDICATING A PROBLEM. IF YOU DO HAVE EITHER LOOK AT THE DRIVERS 1ST AND THE ACTUAL HARDWARE 2ND. IF BY CHANCE YOU DONT SEE YOUR WIFI CARD
THEN TRY REMOVING IT AND REINSTALLING IT. TURN ON YOU COMPUTER AND SEE IF
XP RECONIZES IT "NEW HARDWARE FOUND". YOU HAVE TO SUPPLY A DRIVER FOR IT AS
WELL. GOOD LUCK
Posted on May 07, 2009
    Problem Solver:
  • 11 Answers
IBM is a different beast all together. You need the driverse if you can't find it on the IBM website try going to the Intell website and looking up the card its self.
Posted on Feb 12, 2010
Operating system not found
I would suggest you may have a hard drive error. A replacement drive will need the OS to be installed. you may be able to recover your old drive with a USB harddrive adapter and lead.
Nov 30, 2013 | IBM ThinkPad 240X Notebook
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Jan 13, 2013 | IBM ThinkPad T40 2373 Notebook
My IBM T20 Notebook is given me this message -PXE-E61: Media test failure, check cable- and then say -Operating System Not Found- ---- What do I do?
The error message PXE-E61 is Network card that try to conect this is because hard drive failure or Operating System
check on the bios if you can see the hard drive if you see the drive it could be the OS
hope it will help
Nov 02, 2010 | IBM ThinkPad T20 2647 Notebook
Have an older T23 IBM Thinkpad. Was running Malwarebyts which I just loaded on the system due to a problem at work and wonted to make sure i was ok at home. System ran for aprox 32 min and apeard to lock...
This is a possibility, the T23 is a very old laptop.
Normal 0 Check the BIOS to see if the hard disk is detected, if not open then re-seat the hard drive.
If the BIOS does not detect this hard drive, then the hard drive is probably faulty.
If it was me, I would not waste my time and money trying to get a new hard drive for this ThinkPad.
Disk drive manufacturers do not make small capacity hard drive anymore and the current range of hard drives won't work in your ThinkPad because the BIOS cannot support these hard drives.
Oct 02, 2010 | IBM ThinkPad T40 2373 Notebook
My IBM T30 laptop it says the operating system not found when i reformatting the hard disk is not detect Molla
It would appear your hard drive has died and will need to be replaced prior reinstalling your Operating system
Jul 21, 2010 | IBM ThinkPad T30 2366 Notebook
My IBM Think Pad T30 showin working on AC with out powering..
If it's not finding the operating system, and you'va ran the recovery cd, then the problem is going to be that the hard drive has failed and will need replaced. In order to double check and make sure it's the hard drive, run the recovery or operating system disc, and reformat the hard drive. If the hard drive will not format, then it's bad.
Aug 31, 2008 | IBM ThinkPad T23 2647 Notebook
My ibm wont start up??????
The problem is going to be with either the operating system or the hard drive, and you will need an operating system disc in order to solve this problem. After acquiring an operating system disc you can try an operating system repair. If the repair doesn't take, then try to reformat the drive (NTFS) and install a fresh version of the operating system. If you have any problems during or after the format and fresh install, then the hard drive has failed and needs replaced. A hard drive failure is the most common with this type of problem, but occasionally the operating system will glitch and cause it. Either way you will need an operating system disc if you plan on fixing this yourself.
Jul 23, 2008 | IBM ThinkPad T21 Notebook
Ibm thinkpad t20 notebook
Bad connection from your hard drive to the laptops motherboard. ftp://ftp.software.ibm.com/pc/pccbbs/mobiles_pdf/62p9631.pdf page 63 tells you how to remove the hard drive - I would take it out, clean the connections with rubbing alchohol, and FIRMLY put it back and see if it will come up then.
Apr 02, 2008 | IBM ThinkPad R51 Notebook
Ibm thinkpad 390
This issue showed that the harddrive is not found. Try to fixed hardware connecting from harddrive and the board.
did you see hard drive detected in the bios at start? if your are sure that the connection cable is firmly fixed and the hard drive still not detected by the bios. so there is a problem with your harddrive. you should/may replace that.On the other hand if in case your hard drive is detected and still thesame problem encountered. then, you should reinstall your operating system by inserting the original operating system recovery/ windows bootable installation disc to refresh the state of your system.
any problem srising this solution please notify me.
Jan 23, 2008 | IBM ThinkPad 390 E Notebook
Operating system not found, hard disk not found message showing in IBMT20
On my ThinkPad Notebook Windows 7, I have got "operating system not found" error, to fix problem, Windows Boot Genius helped me finally!
Dec 26, 2007 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T30 2366 Notebook Logo
1,332 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
