Question about Aironet BR500
How to reset to factory default a Cisco Aironet 340 (AIR-BRI342)
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal; other programs are similar.
  3. In the Connection Description window, enter a name and select an icon for the connection and click OK.
  4. In the Connect To window, select the port to which the cable is connected and click OK.
    1. In the Port Settings window, enter the following settings:
    2. 9600 baud
    • 8 data bits
    • No parity
    • 1 stop bit, and
    • Xon/Xoff flow control
    1. Click OK and press Enter.
    2. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    3. When the bridge or AP reboots and the Main Menu screen reappears, typ
    4. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
    5. Open a terminal-emulation program on your computer.
    6. In the Connection Description window, enter a name and select an icon for the connection and click OK.
    7. In the Connect To window, select the port to which the cable is connected and click OK.
    8. In the Port Settings window, enter the following settings:
      • 9600 baud
      • 8 data bits
      • No parity
      • 1 stop bit, and
    9. Click OK and press Enter.
    10. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    11. When the bridge or AP reboots and the Main Menu screen reappears, type 2 to select Reset and press Enter.
    12. Type yes and press Enter to confirm the command.
      Note: The Reset command is valid for only two minutes immediately after the bridge or AP reboots. If you do not enter and confirm the Reset command during that two minutes, reboot the bridge or AP again.
    13. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.e 2 to select Reset and press Enter.
    14. Type yes and press Enter to confirm the command.
    15. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.
    Posted on Apr 18, 2009
    Can get router to work
    The Cisco Aironet 1200 access point provides secure wireless connection to your network. Cisco's wireless access design meet the needs of a small to medium size business.
    This unit provides secure network access for laptops or Wi-Fi capable portable devices, which you upgrade at any time as your business grows.
    A beneficial feature of the Cisco Aironet 1200 is its ability for the administrator to reset the access point remotely.
    This resetting process works through your internet browser.
    Log on to the System Configuration page by entering your Cisco Airnet 1200 IP address in your browsers web address text box.
    Enter your user and password information from the pop up menu.
    Click on the "Setup" button from the summary status page.
    Select the "Cisco Services" setup option and click on "Manage System Configuration."
    Click on "Reset All System Factory Defaults" to reset the router.
    The Cisco Aironet 1200 will be restored to factory defaults.
    http://www.cisco.com/en/US/products/hw/wireless/ps430/index.htmlCisco Aironet 1200 Series
    Configaration Cisco Aironet 1200 Serieshttp://www.cisco.com/en/US/docs/wireless/access_point/1200/vxworks/configuration/guide/bkscgc10.html - wp1016665
    May 07, 2014 | Linksys Cisco Aironet 1200 Wireless Access...
    Reset cisco aironet 350 adapter
    Try Putty and a 9pin male to RJ45 RS232 serial console cable.
    the instructions are in the link provided here:
    http://wirelesslanprofessionals.com/wp-content/uploads/2010/01/Password-Recovery-on-Cisco-APs.pdf
    Jun 30, 2017 | Computers & Internet
    I cannot find the default ip address for Cisco AIR-AP1242AG-E-K9. can anyone help?
    Hi, The Access Point does NOT have a default ip address
    below is quick setup guide to the Access Point
    http://www.cisco.com/en/US/docs/wireless/access_point/1240/quick/guide/ap1240qs.html#wp41082
    May 30, 2011 | Cisco Aironet 1242AG (AIR-AP1242AG-E-K9)...
    Reset my Cisco AIR-AP1242AG-N-K9 but still can't access the control panel using a console calbe and laptop. Using Cisco Cisco as user name and password. Note when typing the password nothing appears in...
    Hmmm..., I assume you are using Windows..... Try just going to the Network, see if you router shows up if so.... Click on it... It should ask for a pin type in the pin that usually can be found on the bottom of your router... If not reset to factory defaults and in your broswer type in your IP address, do not use autoconfiguration.... On all Linksys routers the default username is admin (with the password left empty) from there you can set your password and configure your router for use.... Hope this helps ;)
    Jan 05, 2011 | Cisco Aironet® 1242AG (AIR-AP1242AG-N-K9)...
    Default username & password after hard reset
    Username:[none]
    Password:Cisco or
    :root
    :Cisco or
    :Cisco
    :Cisco
    Try from above 3 then you can access cisco router.
    Let me know if you need further assistance.
    Thanks for using FixYa.
    Feb 01, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
    Can't connect to my Cisco Aironet 350 wireless Access Point
    Did you setup and configure your Cisco aironet 350 directly from your laptop? I would verify the IP configuration on your laptop and make sure that your Default Gateway and subnet mask and DNS are set correctly. Give it a static address on the same subnet and see if it can see the router. Hope that helps!
    Cheers!
    J the Guru
    Sep 09, 2017 | Cisco Aironet 350 Series Wireless...
    Drivers four air-lmc drivers
    Official page: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=268438196
    You might have to signup at cisco to be able to download the software. It's done in a few minutes though.
    Hope that helps!
    Jun 06, 2009 | Cisco Aironet 340 Wireless Adapter
    How to reset Cisco Aironet 340 Wireless bridge?
    Aironet 340 Series Bridge For Software Version 8.65 or Later If you forget the password that allows you to configure the 340 bridge through the console port, you must completely reset the configuration. Complete these steps in order to delete the current configuration and return all settings to the factory defaults:
    1. Use a straight-through cable with 9-pin male to 9-pin female connectors in order to connect the COM 1 or COM 2 port on your computer to the RS-232 port on the bridge.
      For more information, refer to the Cabling Guide for Console and AUX Ports.
      Note: These instructions describe HyperTeminal. Other programs are similar.
    3. Enter a name in the Connection Description window.
    4. Select an icon for the connection.
    5. Click OK.
    6. In the Connect To window, use the Connect using pull-down menu in order to select the port where the cable is connected.
    7. Click OK.
    8. In the Port Settings window, make these selections:
      • Bits per second (baud): 9600
      • Data bits: 8
      • Parity: None
      • Stop bits: 1
      • Flow Control: None
    9. Click OK.
    10. In the Connection Description window, enter a name and select an icon for the connection.
    11. Click OK.
    12. Press Enter.
    13. When the Main Menu screen appears, reboot the bridge.
      Turn the unit off and then back on.
    14. When the bridge reboots and the Main Menu screen reappears, enter 2 in order to choose Reset.
    15. Press Enter.
    16. Enter Yes.
    17. Press Enter in order to confirm the command.
    18. After the bridge reboots and the Express Setup screen appears, reconfigure the bridge with the terminal emulator or an Internet browser.
    see this link 340 Wireless Bridge
    Jul 22, 2008 | Cisco Aironet 340 Wireless Bridge
    Aironet BR500 Logo
    1,149 people viewed this question
    Top Aironet Computers & Internet Experts
    David Payne
    David Payne
    Are you an Aironet Computer and Internet Expert? Answer questions, earn points and help others
