Question about Vacuums
Need to install a new power switch
Actually I bought a used vax vaccuum as the switch was not working i bought a switch when i open the the vacuum to my surprise the wiring from the old switch is been removed and by passed.
My problem is to figur out the wires and which terminal it goes in the switch. the switch (CHILY 7021) got 4 terminals numbered 1, 2, 4, 5.
no.3 and 6 are empty.
Thanking you.
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Wiring diagram
Check the cord to make sure you have continunity throw both leads, check them at the cord reel, there are 2 wires hooked up to it, if not then the cord is bad. Check the swith also, the next cause would be the speen control mounted on the motor, part #04416342, sells for around $85. If your motor checks ok, then it most likely the speed control, they go out quite often.
Posted on Jan 17, 2008
  • 583 Answers
SOURCE: wiring diagram
How to Repair a VacuumCleaner
http://home.howstuffworks.com/how-to-repair-small-appliances8.htm
Posted on Mar 03, 2009
SOURCE: Henry's motor burnt out
henry numatic: 2 white wires do these go opposite or side by side
Posted on Sep 05, 2009
  • 430 Answers
SOURCE: I have the new power on/off switch to replace the
Simply pair 1 each of the power head leads and motor leads on to one terminal and wire the cord as on previous switch.
Posted on Sep 09, 2009
Vax pet 6 wont switch on
I have had two Vax problems and both were a faulty on-off switch after very little work.
Another common problem with portable appliances is internal breaks in the power lead.
Using a multimeter it doesn't usually take long to check the obvious things - if you are competent to do so.
Aug 28, 2016 | Vax Vacuums
Why did my vax vaccuum cleaner cut out and overheat while under guarantee
Do not use this vacuum anymore. Get it back to place of purchase
and let them deal with it.
Regards,
Dennis
Aug 24, 2014 | Vacuums
Vax mach air reach suction problems
Thanks to N3FAR. It was very helpful, i have been callinv Vax and they are asking me to do all sorts of other things. Thanks you again
Dec 31, 2012 | Vacuums
My vax rapide xl ultimate v-027y brushes not working..new belt fitted and same problem
hello i have a vax rarid xl carpet cleaner when you switch power on just makes a buzzing noise can you help thanks
Jul 15, 2012 | VAX Appliances Vacuums
Vax rapid ultra brushes not turning
Dear Sir:
1) Test the power cord for defective wires, broker,or loose repair
2) Test the switch for open see the diagram
3) See if there are some open fuse.
4) See if the belt is broken, replace.
5)Test the input voltage motor.
God bless you
May 26, 2012 | VAX Appliances Agilty V123 Upright Wet...
Vax 2000 trips electrics
Try the reset drive belt brush button - you'll find it underneath the main power switch on the handle. Also check the brush isn't clogged, by the sole plate by tipping it over and undoing the screws on the bottom place where the beater bar is.
Apr 11, 2009 | VAX Appliances Vax X5 Bagless Upright...
There is no power, how do i open it up to get to the cord end inside, and then maybe the switch.
hi common fult with this one its usualy the power switch, pull off wheels (strainth required) unscrew the 4 torx screws and the two on top, pull apart housing you will see red button where power swich is, connected with two wires, its a in out switch if it does not stay in its kaput, ebay is the only place i found the switch.
tally hoooo
Apr 06, 2008 | Vacuums
No suction on carpet
make sure the brush is spinning and also make sure u there is not a clog right behind the canister when you detach it from the vacuum itself
Jan 18, 2008 | VAX Appliances Vax X5 Bagless Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
