Question about Sony KP-61V90 61" Rear Projection Television
IR pickup on the bottom of the screen cabinet
My name is matt and the last two questions about the remote are from me, I dont know how to find the IR pickup on the bottom of the screen cabinet I do not see a sensor anywhere unless the power light dubbles as a sensor as well unless in it inside the tv in which case where to I start to take it a part at, any help if you can you have been very helpfull, thanks
    Genius:
  • 1,153 Answers
Yes the infrared sensor is located inside the set usually up front. You can tell its the IR because it will have a wire harness plugged into it. And a small sensor board maybe a small canister also. You may have to go in throu back, if you cant get in behind speaker cover.
Posted on Sep 17, 2007
SOURCE:
New battery did not help. Could a reboot on the remote in the cabinet help?
Presuming that the IR codes for the 0~9 numbers are captured correctly, then problems like this are usually down to either insufficient time between key presses, which can be solved by adding a small macro delay to each key; or the device being controlled is receiving multiple IR streams either directly from the hand unit and the IR emitters, or there's a blaster in the cabinet that's bouncing IR in multiple paths.
Did you have the system installed professionally or is this a DIY job?
Sep 04, 2014 | Universal Remote Control MX-3000 LCD...
I have no picture on my tv, even when the cable is plugged in. I do not have the orginal remote
Hi, my name is Cheri Torres and I work on the DISH Internet Response Team. I came across your post recently and would like to help. We have a few different codes for each of our different models of remotes. I will list here for you the best codes for each of our different models or remotes and, the instructions for addressing your remote to your TV. I hope you find this information useful and if you have any further questions or concerns feel free to ask.
Remote models Remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 569, 632, 733, 694, 569, 846.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 632, 522, 624, 846.
4.0 and 4.4 IR/UHF remotes - codes 632, 569, 733, 694.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 733, 632, 694, 756. 569.
20.0, 20.1 IR and 21.0 21.1 IR/UHF remotes - codes 632, 733, 756, 846, 679, 694.
Instructions for addressing the remote to the TV
1. Press and hold down the TV button until all the lights on the remote are lit.
2. Enter the 3 digit code for your remote.
3. Press the pound(#) button once.
4. Test the functionality of your TV.
Cheri Torres
DISH L.L.C.
[email protected]
Jan 22, 2012 | Symphonic WF20D4 TV
What is the three digit code for DISH on a Sylvania LC195SLX
Hi, my name is Cheri Torres and I work with DISH Network Customer service. We have a few different codes for each of our different models of remotes. I will list here for you the best codes for each of our more popular models of remotes and the instructions for addressing the remote to the TV. I hope this information helps and if you have any other questions please let me know!
Remotes models Remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 632, 569, 566, 671, 733, 515, 568, 764.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 632, 569, 566, 536, 733, 672, 660.
4.0 and 4.4 IR/UHF remotes - codes 733, 569, 566, 632, 764, 664.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 733, 569, 566, 654, 672, 632, 764.
20.0 IR and 21.0 IR/UHF remotes - codes 733, 672, 777, 566, 764, 527.
1. Press and hold down the TV mode button until all the mode buttons light up red.
2. Enter the 3 digit code using the keypad.
4. Test the functionality of the TV.
Oct 17, 2011 | Sylvania LC195SLX LCD TV
I need code for remote to programme dish network on one remote
Hi, my name is Cheri Torres and I am with DISH Network Customer Service. Each of our different models of remotes have a few different codes that it could work with. I will list here for you the best codes for the more popular models of remotes that we have as well as the instructions for addressing the remote to your VIZIO TV. I hope you find this information useful and if you have any further questions let me know. :)
Remote model #'s Remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 505, 165, 671, 627, 520, 758, 766.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 627, 505, 506, 006, 457, 520.
4.0 and 4.4 IR/UHF remotes - codes 505, 627, 766, 864, 593.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 627, 505, 678, 458, 825, 758, 520, 766.
20.0 IR and 21.0 IR/UHF remotes - codes 505, 598, 627, 523, 520, 720.
  1. Turn the Television On.
  2. Press and hold the TV mode button until all the other mode buttons light up red.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button once.
    Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Sep 08, 2011 | Vizio 42 in. LCD TV
Have a magnvox TV will my dish network remote work with it I am on cox cable all so dont know my code ??
I see you needed some help programming your remote, dgosch406, which I'd be happy to help with! Let me know the model of the receiver you have, which can be found on the front panel in the bottom left corner. Try the following codes for your Magnovox TV: 566, 770, 723, 506, 677, 724, 729, 762, and 610. If you have questions, I'll look forward to hearing from you!
Hope that helps!
Jul 30, 2011 | DISH Network IR Remote Control
I just purchased two remotes on line. One is a 3.0IR 119946. The other is a 4.0 IR 132577. The 3.0 IR works fine on my model 2700 receiver but the 4.0 IR won't work is there any was to program the 4.0 IR...
Hi, my name is Cheri Torres with DISH Network customer service I came across your post and wanted to see if I could help. The 4.0 IR/UHF remote should be able to work fine with the 2700 receiver and you should be able to address it the same way you did the 3.0IR remote. One thing you are going to want to make sure of is that the 4.0 remote is set up for IR instead of UHF, you can insure this by inserting the green TV1 tab into the front of the remote. Once you have the green TV1 tab in you can try to readdress your remote again. I would like to list here for you the instructions for addressing the remote to the receiver just in case you need them. :) I hope you find this information useful and if you have any further questions feel free to post back here or email me at [email protected]
Instructions for addressing remote to receiver
  1. Go to System Info screen. In order to do this you will want to take out your smart card from the front left side of the receiver.
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button
  5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Jan 19, 2011 | DISH Network IR Remote Control
I need code for vizio HDTV model P42HDe
Hey there, my name is Cheri Torres with DISH Networkcustomer service. I came across your post and wanted to see if I could help.DISH Network remotes have a few different codes for the different models of IRand IR/UHF remotes that we have. The model number you will need to look for isgoing to be on the back of your DISH remote at the top, usually listed as a twoto three digit number with a decimal point. I will list here for you a varietyof codes for our more common remotes and also the instructions for addressingyour remote to your TV. For the 3.0, 3.1, and 3.2 IR remotes the best codes forVIZIO are 505 and 627. The 5.0, 5.2, 5.3 and 5.4 IR remotes the codes are 506,505, and 627. For the 4.0, 6.0, 6.2, 6.3, and 6.4 IR/UHF remotes the best codesare 505, 520, and 627. The last codes you can try for 20.0 and 21.0 IR andIR/UHF remotes the codes are 505, 598, and 627. I hope you find these codes andinstructions useful and if you have any further questions or concerns feel freeto post back here or email me at [email protected]
Instructions for addressing your DISH remote to your TV.
  2. Press and Hold the TV mode button down until all the mode lights light up at the top of the remote.
  4. Press the pound(#) button once. Note: The LED will flash three times.
Jan 09, 2011 | DISH Network IR Remote Control
Remote for tv in closed cabinet
i don't know about the dip switch, but the ir receiver board in this mitsu is located in front of the mirror behind the screens
May 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My remote
There is an IR pickup on the bottom of the screen cabinet. It's most likely broken.
May 31, 2007 | Sony KP-61V90 61" Rear Projection...
Thick multicoloured stripes accross the screen
Some condesator gone bad.. remote control IR eye needs 5V voltage but now it's not there so i think you need to replace bad condesator.
May 30, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
Sony KP-61V90 61" Rear Projection Television Logo
125 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
