Question about Gateway MT3422 RTL Notebook
My laptop battery isn't charging
My laptop was charging fine until my puppy ate thru the charger while I was sleeping. I've replaced the charger and when plugged in, it tells me 0% available (plugged in, charging), but as soon as I unplug the charger, it dies.
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
I have an Acer 7736Z the battery isn't charging. The BIOS on the acer support website give me version 2.10 which doesn't seem to match the directions given from previous questions and solution
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/replacement-acer-aspire-7736-ac-adapter-19v-90watt.html
Nov 16, 2012 | Computers & Internet
Garmin reports low battery, turns off in 2 seconds even when connected to car battery
Check to make sure that the rear USB jack isn't loose. This is a common problem on ALL nuvi's that are charged by a USB jack only. If the jack is broken, the battery will not be charged. When you plug in the charger, the battery icon with green bars should go away. If you can still see it, your USB jack is broke and needs to be replaced. I've replaced these many times. More info can be found here:
http://www.sharc.net/gps_charger_repair.htm
Oct 08, 2012 | Garmin nuvi 250W GPS Receiver
My acer extensa 5620z does not charge nor works connected
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 25, 2012 | Acer Extensa 5620 Notebook PC
Why isn't my phone charging its pluged in and it
You can try to try a different charger,if it doest charge the battery,try to use your charger to a compatible phone. If it charge the second phone,that means that your charger is fine,it might be a battery issue. For sure,either the battery or the charger needs replacing.
Dec 07, 2011 | LG Cell Phones
Hi, i've had my Samsung genio touch for over a year now and i've had no problem untill now, the phone will not charge up, i've tried putting the charger in a different socket and taking the...
a possible battery or charger problem.
check if you can charge using a diff. charger,if you can?then the charger is the problem,replace it.
but if you can charge w/a diff. battery?replace the battery. :)
Sep 09, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Charger plugged in but battery isn't charging. laptop only comes on when plugged.
If you've been using that same laptop battery for a few years then it probably needs to be replaced. Batteries get old and stop working properly after a while. You'll have to go out and buy a new one.
May 10, 2011 | Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
The battery does not charge anymore ,the bios setting says idle
remove battery and reseat.
Use VOM (Volt-Ohm Meter) and phsically check to make sure the power supply is putting out advertised voltage (typically 19-20 VDC)
Make sure power supply recepticle (the female part on the laptop itself) has not been broken or reamed out such that contact is not being made.
When you plug power supply in, does the charging light on the laptop come on?
Mar 07, 2009 | Dell Latitude D600 Notebook
Won't Charge Any Battery--Even a New One
Check for loose solder connection in the power supply and the terminals that connects the battery to computer.
Sep 03, 2007 | Gateway 450ROG Notebook
Gateway MT3422 RTL Notebook Logo
408 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
