The video cam picture is dark with a green tint. I tried to adjust the video settings through yahoo messanger, but they do very little. The people I chat with have clear bright video cams. I'm thinking EZCam111 is defective.
Same problem,but i alreagy solve it,just try to install another driver from different cam,i use A4TECH PK 635K,I TRIED intex cam driver,it work try it..100% work...hope it help
It will be best to contact either the authorized service center for Curtis, or any experienced service technician. Sounds like a back-light inverter fault. Gopakumar Gopalan Google
It is one of two things the picture tube is bad and the green emission is very low or the green gun is open, the second possibility is the video driver or output is shorted on the video board "plugged in the back of the picture tube"
tell her to properly set the webcam
1 tell her to install yahoo messanger and u also install it then create yahoo account both of u then log in with that account to yahoo messanger then plugin the webcam to see ur video then go to action menu on yahoo messanger and click on view my webcam then broadcast ur video. then properly configure ur audio as well as video settings in the yahoo messanger then u invite ur friend to view the cam she will be able to see u as well as u will be able to see her...... then enjoy ur big chatting hours... happy chatting
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
Fresh Contrast: Off
Noise Reduction: Medium
Gamma: Medium
Black Level: Low
Real Cinema: On
TruMotion: Low
Color Standard: HD (N/A w/HDMI)
White Balance: Warm
**Method: 10-Point IRE
10 IRE
**Red: 1
**Green: 2
**Blue: -16
20 IRE
**Red: -6
**Green: 0
**Blue: -7
30 IRE
**Red: -5
**Green: 0
**Blue: -4
40 IRE
**Red: -8
**Green: 0
**Blue: -4
50 IRE
**Red: -4
**Green: 4
**Blue: -4
60 IRE
**Red: -6
**Green: 6
**Blue: -5
70 IRE
**Red: -8
**Green: 3
**Blue: -10
80 IRE
**Red: -8
**Green: 7
**Blue: -16
90 IRE
**Red: -9
**Green: 5
**Blue: -18
100 IRE
**Red: -10
**Green: 4
**Blue: -9
Color Management System
Red Color: 0
Red Tint: 0
Green Color: 0
Green Tint: -15
Blue Color: 0
Blue Tint: 11
Yellow Color: 15
Yellow Tint: 2
Cyan Color: -15
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it. im isf certified those settings are right on the money straighter than a ruler
toni, you`ll need a tv tech for this problem, spark gaps need to be cleaned, crt sockets need to be cleaned and crt pins on all 3 crt`s need to be sanded, this is a common issue with this model set, good luck, BMW Rider
My had the same problem except mine has turned yellow tint. I paid 65 dollars for someone to come and look at it and they told me that is was the Blue tube went out. They qouted me 700.00 to fix it.
green tint & screen dark means that there is a problem in green video circuit.
1 check green video supply .
2 components in green video ckt.
3 adjustment in green video section.
4 check for signal to green video.
Most TVs of that caliber have a life expectancy of about ten years.. In 2009 we'll be passing into the HD era and that Tv won't work without a little help from an HD converter.
What you're describing sounds like some transistor problems on the crt board and possibly voltage regulation. Not too expensive for a reputable shop, but my best advice would be to get an estimate first.
If you need help finding a reputable shop contact NESDA, (National Electronic Service Dealer's Assn.) they should be able to direct you to a member's shop in your area. Its like going to the AMA to find a doctor.
If the cost is more than half the cost of buying new - get a new one...
Good Luck
Bill
The green gun in your picture tube is set a little too high.
If you are experienced in removing the back cover of TV's,etc., you may try to find the drive and/or bias controls either on the circuit board that plugs on to the neck of the picture tube or mounted on the main circuit board of your TV. These controls are usually labeled. If you can find them, locate the green bias or drive control and back it down a little while watching the picture through a mirror. A slight adjustment may correct your problem.tJIS IS CALLED GRAY SCALE ADJUSTMENT.
BE CAREFUL THERE ARE SOME HIGH VOLTAGE CIRCUITS NEARBY. WORK WITH ONE HAND AND USE AN INSULATED TOOL TO MAKE ADJUSTMENTS
I hope this may help you.AGAIN BE CAREFUL!!
Stargazer
