Question about Symbol MC9060 Portable Terminal
Windows Mobile Device connection problems to SQL
Is there a setting that needs changed to allow for a Windows Mobile Device to connect to a MSSQL Server.
  • 415 Answers
Nope. you just connect your mobile device with active sync.
then to connect use this conenction string
Data Source = YourServerIP,1433; Initial Catalog=YourDatabase; uid=YourUsername; password=YourPassword
1433 is the port number of sql. You can change this if you like
Posted on Dec 30, 2009
How to connect my MSSQL server through VPN by using PPTP
192.168.1.X is a local ip address ,, i trust that thhe vpn is in seperate places and is done with the wan ip over an internet connection?????
OK maybe the problem isnt on your side but the main office building,, when connecting , have someone looked for repeated attemps to connect by observing the fire wall,, if it appears to be blocked byu the firewall simply diasable any and try it out.. If it works then all you need to do is set the firewall correctly..
I was reading the ip address in your original post and those are local address,s are you certin the VPN is correct ???? did you use the correct STATIC IP ADDRESS ASSIGNED BY YOUR ISP??
Jan 20, 2008 | Cyberguard SG300 (00852503000366) Firewall
Tip
Reset sql sa password directly and efficiently
A few days ago, I had a painful experience that I lost SA password on my MS SQL Server database, and I almost took the whole weekend to look for an efficient way to reset SA password. I asked friends, searched on Internet and even bought some book.... Fortunately, I finally got a SQL server password recovery software and it instantly reset SA password without data loss. And I also got a couple of good solutions for sql sa password reset to save your weekend in case you have lost or forgot MS SQL Server passwords (SA password!).
Option 1 : Use MS SQL Server Password Unlocker to Recover/Reset SA Password
The most direct, efficient way to reset SA password is to take use of the third part utility - SQL server password recovery software. Just two steps:
Step 1: Access to master.mdf file, which is default at C:\Program Files\Microsoft SQL Server\MSSQL\Data\master.mdf
Step 2: Select SA password and reset SA password
So, Reset SA password successfully!
Option 2 : Recover or Reset SA Password with Other SQL Server Login
If there is any other SQL Server Login that is a member of sysadmin role, you can log in using that account and reset SA password of SQL Server. Reset sql sa password as described here :
SQL SERVER - Reset Password of SA Login Using Management Studio.
Login into SQL Server using Windows Authentication.
In Object Explorer, open Security folder, open Logins folder. Right Click on
SA account and go to Properties.
Reset SA password, and confirm it. Click OK.
Make sure to restart the SQL Server and all its services and test new password by log into system using SA login and new password.
Option 3 : Recover or Reset SA Password with Windows Login that is a member of Windows Admin Group
If there is any other Windows Login that is a member of Windows Admin Group, log in using that account. Start SQL Server in Single User Mode as described followings :
SQL SERVER - Start SQL Server Instance in Single User Mode.
There are certain situation when user wants to start SQL Server Engine in "single user" mode from the start up.
To start SQL Server in single user mode is very simple procedure as displayed below.
Go to SQL Server Configuration Manager and click on SQL Server 2005 Services. Click on desired SQL Server instance and right click go to properties. On the Advance table enter param '-m;' before existing params in Startup Parameters box.
Make sure that you entered semi-comma after -m. Once that is completed, restart SQL Server services to take this in effect. Once this is done, now you will be only able to connect SQL Server using sqlcmd.
on Oct 05, 2010 | Computers & Internet
SQL Error515 on employee clock in
hi luke,
sounds like you accidentally changed the settings on time management. this could be a little difficult to fix and may require looking directly at database settings. If you want my help,
sysadmin@ccybernet.com
Feel free to email me with more details if need be.
May 06, 2014 | Pc America Restaurant Pro Express
I get ''SQLDUMPER LIbrary failed initialization'' when i start the computer
SQLDUMPER is an accessory for Microsoft SQL Server that will allow you to track down problems with MSSQL. There's no need for it on your system if you're not using SQL Server.
Using Control Panel, select [Add or Remove Programs], then select the [Microsoft SQL Server] program and click on the remove button.
If you want to reinstall it, you can go to MSDN.microsoft.com and get a new copy, but if you're not using it and no programs you are using are, there's no reason to have it.
May 26, 2011 | Microsoft Windows XP Professional for PC
Error installing MS Office pro 2007 with BCM
Uninstall from control panel the following:
Microsoft SQL Server native client
Microsoft SQL Server Setup Support files
Microsoft SQL Server VSS writer
Move directory C:\Program Files\Microsoft SQL Server\MSSQL.1 to another location for possible use. Delete everything under Microsoft SQL Server in c:\Program Files
Reinstall
Jan 10, 2010 | Microsoft Office Professional 2007 Full...
Microsoft Money etc. Sync Problem with iPAQ hx2495b
IT WAS COZ OF UR WINDOWS SO U SHOUL CHANGE UR WINDOS BECOZ UR DRIVER NOT SUPPORT IN UR VISTA WINDOWS SO CHANGE IT
Dec 02, 2008 | Dell Axim X51v Pocket PC
Hibernate configuration with windows authentication
When you login to your database (download the management tool) right click on server name->properties->security.
There you can choose mixed authentication.
Sep 05, 2008 | Computers & Internet
MSSQL Related Problems
Please see link below http://www.php.net/function.mssql-connect
Basic tutorial in connection PHP Language to MS SQL Server.
Please rate me SOLVED.
Nov 22, 2007 | Microsoft SQL Server Standard Edition for...
Pocket LOOX T830 conection problems
Microsoft has just released a mobile device center upgrade which is more stable and allows more types of files to be sychcronized. Also, if you are using windows live onecare, check that the firewall allows Microsoft Mobile Device Center access through it as the mobile device makes a network connection to your PC
May 05, 2007 | Fujitsu Siemens Pocket LOOX T830...
Symbol MC9060 Portable Terminal Logo
227 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
