Washing machine stopped at the spin point and I cannot get it to spin
    Problem Solver:
  • 5 Answers
The front of the machine would have to come off. check to see if the belt between the motor and the drum. if it's just the belt it can replaced If there 's a problem with the motor or transmission it would be to costly to repair.
Posted on Apr 17, 2009
Brand new Bravos. Why doesn't it do the final spin?
NO ITS NOT UR DOOR SWITCH IF IT WAS IT WOULDNT SPIN ON ANY CYCLE. I SUSPECT U HAVE A TIMER THAT IS STICKING AND THE POINTS HAVE BURNED OR SEIZED
May 26, 2015 | Maytag Washing Machines
Kenmore top load washing machine stops cycle wont drain water
Amber, you probably have a broken lid switch. They will not let the machine go into drain and spin because it thinks that the lid is open.
Aug 13, 2014 | Washing Machines
I have an lg 5kg washing machine WD-80264NP which stops after washing for while.it doesn't spin. what could be the problem?
Ur timer switch for washing/spinning is broken, there are contact points on that timer switch, the part of SPiNNiNG is not functioning!
Let a technician check on that, and might as well replace it!
Nov 29, 2010 | LG Washing Machines
WHY DOES MY SPEED QUEEN MACHINE HAS STOPPED WRING MY CLOTHING DRY, AND WATER REMAINS IN WASHER
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 16, 2010 | Washing Machines
Kenmore Series 70 Washing Machine Cycle stops at the point it would spin and drain. I am guessing it is possibly a bad lid switch.
My guess is that you are probably correct!!
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 22, 2010 | Kenmore 24032\24036 Top Load Washer
Will not spin, therefore will not drain
Hey Joe,
Let’s check to see if the wash basket will rotate CCW in Spin Only Cycle with no clothes in the wash basket
1. Open the lid and rotate the wash basket by hand Counter Clockwise, CCW. The wash basket should rotate freely with no restriction. The wash basket will not rotate Clockwise, CW by hand.
2. Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. Raise the top of the machine to observe the wash basket and tumbler action described in step 3. (See page 33 of the Service Manual for putty knife insertion point).
3. With the top raised start a Spin Only cycle with no clothes in the wash basket, observe the wash basket it should begin to rotate CCW does it?. Watch the tumblers, they should not rotate in spin cycle (maybe ½ turn at the start of spin cycle and that’s all). If the tumblers rotate while the wash basket is rotating you have a clutch malfunction. If the basket does spin CCW and the tumblers are rotating then you have a broken clutch spring. Let do those checks and observations and see what the next troubleshooting steps will be. Rich
Apr 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Spin mode does not work
Dear "FixYa,"
I have fixed the problem with my washer.
I started clothes washing machine with one load of clothes.
Wash and rinse process completed, as it came to spin,
Machine stop, only I heard was running motor. I opened
machine and found coupler is cracked (broken) and was
unable to rotate the gear.
I replaced new coupler and machine started to work normal.
Thank you
Kanu
Apr 18, 2009 | Whirlpool Washing Machines
Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
May 10, 2007 | Whirlpool AWM6120 Front Load Washer
Washer will not pass wash cycle...Will not Drain
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
Nov 08, 2006 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
