Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
HOW DO YOU SCAN?
HOW DO I SCAN A DOCUMENT ON MY EPSON DX4400
  • 1,959 Answers
You need some sort of photo editing program such as MS Paint or Paint Shop or any other imaging software. Open the program and click on Import. It will ask you which device or which TWAIN device you'd like to import from. Click on your scanner and you should be able to start scanning.
Posted on Apr 17, 2009
  • 28 Answers
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takiqq24
Posted on Sep 04, 2009
Where can I download a manual for Epson DX4400 Printer
Epson DX4400 Reference Guide
Setup Sheet
Basic Operation Guide
From the above links you can download the required document (in Acrobat pdf Format)
Hope it helps! Good Luck!
CreativeTECH
Apr 06, 2011 | Office Equipment & Supplies
Instructions for scanning on epson cx4300/cx5500/dx4400
Scanning the Document
Place the original on the glass.
1) Open the document cover and place your original face-down on the glass, in the upper left corner. Move your original about 1/10 inch away from the top and left edges so all of it will be copied. 2) Close the cover gently so you don't move the original . Caution : Never open the document beyond where it stops and do not place heavy objects on top of the CX4600. If you need to copy or scan a thick or large document, you can remove the document cover. Just open it and pull it straight up. If you need to press the document flat while you copy or scan it, do not press too hard and be careful not to move it. Caution : Do not use excessive force on the document cover, and do not twist it diagonally. You may damage the document cover. When you are done, replace the document cover by inserting the tabs back into the slots. Copying a document. 1) Load paper. 2) Press copy button until you see the desired number of copiesin the Copy window You can select up to 9 copies at a time. 3) Press the paper type button to select PLain Paper. The light indicates which type is selected. 4) Press the paper size button to select Letter. 5) If you want your copies automatically reduced or enlarged to fit the loaded paper size, press the Fit to Page button. 6) To make color copy, press the Start Color button To make black and white copy, press Start B&W button. The ON light flashes and after a moment the CX4600 starts printing. If you need to stop copying at any time, just press the Stop button. Do no pull out paper that is printing, it will eject automatically to the output tray. Hope this helps. Please rate my response. Thanks Have a good day.
Nov 25, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Downloading Epson Stylus DX4400 user manual, how
http :// www.epson.com.sg download site for drivers and so on
Oct 07, 2009 | Epson Stylus CX4800 All-In-One InkJet...
How to scan on an Epson Stylus DX4400
To scan an image into your PC you need to use a piece of software called the Epson Scan Utility. This
comes on the installation CD with the printer but if you don't have the CD it can be downloaded from
Epson Support. For Europe:
http://esupport.epson-europe.com/SupportHome.aspx?lng=en-GB&data=0ccCGROWIYM58zV3pqc84YT0DcLI1RrpNUFXBv2
99cYU003D
Or US:
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes
Once it is installed it will put an icon on the desktop, or (if you have Windows) a folder in the Start
menu. Turn the printer on and start the Epson Scan utility (it doesn't work if the printer is off), it
can be used in 3 modes: Fully Auto, Home Use or proffessional. Fully auto is the simplest, just click
on the scan button. For the others be brave and experiment!
Please take a moment to rate this solution, thanks.
Apr 09, 2009 | Epson Office Equipment & Supplies
Scanning on an epson dx4400
To scan a picture into your PC you will need the Epson Scan program installed on the PC. This program comes on the CD with the printer, but if you don't have the CD it can be downloaded from Epson:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=lkuCfcvA9cxyWBIk5wgudexhHWUK6Mnk&tc=6#19
It may already be installed, if you have Windows go to the Start menu and look for Epson Scan Utility. Turn the printer on and place your photo on the glass under the scanner cover. Click on Epson scan and you can choose 3 methods. Fully automatic, home mode or proffessional mode. fully automatic is the simplest method, simply click on the scan button. For the others be brave and experiment!
Hope this helps, please take a moment to rate this solution. Thanks.
Mar 31, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I have lost installation cd to install my epson printer
You can download drivers from link below, follow the instructions on the Epson website:
Epson Stylus DX4400 : Drivers & Software
Mar 27, 2009 | Epson Office Equipment & Supplies
My epson DX4400 prints apparent nonsense instead of the document. Also it doesn't spool through until you cancel the print job it prints the same stuff over and over in the top corner.
When printer prints a set of character that has nothing to do with the docuument, instead of the current document, then there is a logical problem.
This is usually due to a corrupted driver software, only in exceptional occasions you have a printer with a faulty control board.
To start unplug printer USB, empty the printer cue from control panel, replace USB cable, and test a different USB socket.
If that did not help, then download and reinstall printer driver software from the link below:
If reinstalling the software dod not work, and all the above did not help, then the printer is faulty.
Mar 12, 2009 | Epson Office Equipment & Supplies
How to install a epson dx4400 all in one printer with out set up disc
any usb device requires the correct driver.
need the disk.
download it from the site.
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX4400/Drivers-Support?supportLandingPage=true
Dec 01, 2008 | Office Equipment & Supplies
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
222 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
