Question about Sebo X4 Bagged Upright Vacuum
Sanyo vacuum cleaner bag
I'm trying to take it apart to replace the bag, can't find the booklet and just want to clean! It'a sanyo 3 in 1 vacuum sweeper
  • Anonymous Mar 16, 2014
    I need to know how to open the bag compartment on a Sanyo sc-18 vacuum
We have the Sanyo Transfomax 3 in 1 vacuum and FINALLY found that one has to use a screwdriver at the edges of the "hand hold" just above the Sanyo name (between black and green parts), to pop open the cleaner in order to replace the bag or clean the filter.
What a miserable way to change a bag!
I know this is almost a year late...but I just found your request. Ta ta, Rita
Posted on Jun 13, 2008
  • linda pawlowski May 30, 2013
    thank you! i found that link and know how to open it!
  • 438 Answers
Greetings from GoVacuum,
Here's a link to the user manual for your vacuum cleaner. This will explain how to replace the bag, change the filter, and everything you need to know. You may print this .pdf file out so you can have it for future uses.
I hope this helps! Please let me know if you have any other questions about your machine. We are a good source for any parts that you might need.
Please feel free to email me if you have any questions, I really enjoy sharing my passion and knowledge for vacuum cleaners. I really don't mind answering any question you may have.
Here's the link;
http://sanyoservice.com/pdf/images/SC-180E.PDF
Chris Jones
GoVacuum.com
[email protected]
Posted on Oct 03, 2008
SOURCE:
How do i replace the on and off switch on a gen 3 kirby sweeper
fault will be cable not power switch, phone your local kirby enginere for fixing
Jul 31, 2012 | Kirby Ultimate G Bagged Upright Vacuum
Vacuum has no suction
I would say that the best way to improve suction with any vacuum is to clean all the filters, If it is a Bagged sweeper check for holes and possible replace the bag. Hope this helps some!
Good Luck and Best Wishes!
May 05, 2011 | Kenmore Vacuums
I have a fantom fm709k vacuum and apparently they do not make the bags for them anymore....what bag can be used in place of it...
Take the old bag and take it to a sweeper shop they can match it up but beware of them trying to sell you something you don't need.They will try and sell you a new sweeper cause the bags are no longer available ,let them know up front you just want to match it up and not interested in the new stuff.
Apr 05, 2011 | Vacuums
My vacuum stop suction
Usually, the tube leading from the sweeper head up into the bag gets plugged. Remove the bag and the bottom cover plate of the sweeper to check the air passage at the rear of the sweeper. Use a hooked wire to dig out any clogs and check the air tube coming into the bag for any clogs on that end. Take the vacuum outside without the bag and turn it on to make sure the air is moving freely (it's likely to be quite dusty for a moment or two). Don't allow the bag to fill completely to help prevent re-occurrence. Hope this helps!
Nov 21, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
I need to replace the belt I bought a new belt and I can't get the belt back on
On this page
http://www.totalvac.com/videos/kirby-vacuum-cleaners-videos.htm
there is a video at the bottom on changing belts on a Kirby
Sep 23, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Guinea pig bedding has blocked the sweeper hole
The base of the vacuum needs to come apart. You will need the service manual if this is not a common task for you. It may be possible to reach the vacuum hole if the roller is removed.
The service manual is here:
http://www.hoover.com/shop/searchresults.aspx?itemid=220964&filters=
Mar 22, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Bag came apart from hose
do you have the instruction manuel? .if you can't figure it out i would take it to a repair shop and i'm sure they will be happy to show you how to do it.
Mar 16, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
How to change a Hoover Elite sweeper belt
on the bottom there should be a few screws take them out and a cover should come off the belt is right there. hope this helps
Dec 18, 2007 | Hoover Elite U5061-900 Bagged Upright...
Twenty year old Electrolux canister swith stopped working
What switch? If the switch is inside the tank, open it from the underside with 3 screws.
Nov 30, 2007 | Electrolux Guardian Bagged Canister Vacuum
Sebo X4 Bagged Upright Vacuum Logo
334 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
