Question about Frigidaire AEQ6000ES Electric Dryer
Won't Start Just bought a new Frigidaire Washer(ATFB6000) and Dryer(AEQB6000ES0), the washer works great but I can't get the dryer to turn on. When I plug the dryer in the Drying,Cool Down, and Extended tumble LEDS lights flash non stop. When I turn the selection knob the LEDS to the left don't even light up. I have bought a new power cord and new breaker(panel box) and have replaced them, still getting the same results with the flashing lights. If I had to guess, I think it is the electronic contol board, in which case I would have to call a repair shop to fix. I have tried everything that I can think of. Any ideas of what the problem would be? Thanks for your time.... Steve
  • Steven Crickman Sep 19, 2007
    The wiring is hooked up correctly. A service tech came out, turns out to be the Electronic control board, took the dryer back and they gave me another.
    Thanks for your help
    Steve
  • 725 Answers
Do you have the power cord correctly hooked up and have the correct voltage ? is the white wire in the middle? you should have 120 volt with red-white . 120 black- white and 240 black-red... careful with electricity it can hurt and kill you. let me know if you fix this one...krazytech
Posted on Sep 18, 2007
SOURCE:
I have a stackable frigadare w/dryer. Washer works great but the button to start the dryer just hums. Belt is ok.
It seems like this dryer need new dryer motor
In order to be sure ,take belt off and try to start dryer ,if dryer still humms it is motor problem for sure,
Jun 04, 2014 | Frigidaire Washing Machines
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Jan 08, 2013 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire gallery series electric dryer/washer. Dryer won't start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 10, 2011 | Frigidaire Dryers
GE Spacemaker Washer/Dryer wont start only washer or only dryer
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
Feb 09, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
Frigidaire washer dryer combo
scoobymom196,
You said, The dryer tries to start but fails!
Huuum: At your service!
It sounds like a bad electrical switch in the dryers start button!
I am sorry to tell you that you need hands on service to remedy this situation.
If only I was there I could help you!
How old is the appliance? if it is old it may not be cost effective to spend good money into bad!
New appliance are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
You will be fine
Bless You huuum
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Sep 07, 2008 | Frigidaire FEX831CS Top Load Stacked...
Water won't work but dryer does
Mine did the same thing and it ended up being an overloaded older breaker in the electric box. It would allow the dryer to work, but the washer was too much for it to operate. Had the breaker replaced with a new one and it works fine. Hope this helps!
Jun 14, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire GLEH1642DS1
Check the door switch on the dryer to make sure the leads are all on.Check your thermal fuse .Its likely that its one or the other.
May 20, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Dryers Logo
239 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
