Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Craftsman 3 gal ari compressor low presure
The compressor builds to 120 lbs on the tank guage and on the regulator guage. When I try to put air in my tires 60lbs no air goes into the tires from the tank. I tried 3 different air chuch connections. I thought the regulator may have ben the issue but the regulator does show 120 LBS at max.
  • 490 Answers
Put a blower on the hose and see if air comes out
very possible there is a blockage in the hose or if you are using quick connects they may have failed
Posted on Apr 17, 2009
I have a 3 gal craftsman air compressor. Compressor runs but will not build more than 20 psi in tank reserve. Whats wrong?
if shuts down at 20 psi regulator is set wrong
it runs but only builds 20 psi, compressor is probably worn out
Oct 03, 2015 | Craftsman Air Tools & Compressors
Compressor runs and sounds ok, but it only manages to show 20 lbs. It will not build air pressure and continues to run.
check air tank drain valve located on bottom of tank, if it is not leaking try adjusting air pres regulator (large black knob close to air hose connection.) the knob when turned in will increase the tank air pressure, if knob wont turn check that lock ring on bottom of knob to make sure it is disengaged. also check for air leaks in all lines and connections
Apr 16, 2012 | Craftsman 1 hp Air Compressor, 4 gal. -...
I have a 3 gal 1 hp air compressor and it will only build pressure to 27 lbs.
If it makes hesitation sounds just before shutting off, you need to oil the compressor as per the manual. This is the most common problem.
If it is kicking on and off normally, you need to adjust the pressure relay. The instructions are under the cover.
May 14, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
Does not build air pressure above 30 lbs
have you turned up the knob on the regulator
turn it clockwise to increase pressure
Nov 09, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 30 Gal. 150 PSI Not building air over 45lbs
The compressor valve may have a faulty gasket or seal, and maybe leaking air internally. Or the compressor might be going downhill. You can try to replace the valve seal and see if that makes a difference, otherwise you need to replace the compressor.
Aug 27, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Tank will not build pressure beyond 25 lbs. Just runs
IS YOUR AIR FILTER CLOGGED. SOUNDS LIKE THE VALVES IN YOUR HEAD ARE NOT CLOSING ALL THE WAY. THEY ARE MOST LIKELY REED VALVES, THIN STRIPS OF METAL THAT OPEN AND CLOSE WHEN THE PISTON MOVES. MAKE SURE THEY ARE CLOSING ALL THE WAY (NOT CARBONED UP). DID YOU REMOVE THE HEAD AND DID YOU PUT BACK LIKE YOU FOUND IT - NOT TURNED OR FLIPPED OVER. SEE IF YOUR FINGER WILL GET SUCKED UP TO THE INTAKE HOLE.
Apr 12, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
326 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
