Question about Intel Asus P4S800 SiS 648FX 800MHz FSB DDR400 Socket 478 ATX Motherboard with 6 channel Audio, LAN, AGP 8X... (MB47ASP4S800)
My P4S800 (SiS 648FX) Series wont power on
I have this Asus Mobo with intel 2.8 ghzprocessor and 512 mb of memory and 128 video card that I got from my friend for free but when I try to open it up it doesn't turn on, I try checking the PSU but it's ok, I try to replace memory card with a new one but nothing works then I also try to replace my video card but still nothing. The board has an LED and it's turn on but my cpu fan isn't turning on, I try also shorting the pins off my power on button guessing it was busted by nothing either.what sims to be the problem...Hope you can help me here thanks very much
  • ultimitloozr May 11, 2010
    When you power it on, does the system beep at all? How did you go about checking the PSU? Are you sure that the power supply is connected to the montherboard properly? Have you tried booting up with only the memory and video card installed (no hard disks, floppy disks, modems, etc)? If the motherboard has built-in video, have you tried removing the add-in video card?
    Genius:
  • 1,066 Answers
I would suspect the processor
Posted on Jul 01, 2009
Acer aspire 5100 series bl51 video memory upgrade What is posible here?
This is a laptop. The video chip is on the motherboard. This machine cannot have a video card added.
Jul 26, 2014 | Acer Computers & Internet
Video card....
Most cheaper laptops do not include a full-blown graphics board with expensive dedicated graphics memory. Instead, system memory is shared between the CPU and the graphics subsystem.
How much memory actually is reserved for graphics purposes depends on the software you are running. The frame buffer (the memory used to store the pixels on your desktop) is only part of it - games, for example use a lot of memory to store textures and geometry data.
  • Minimum Graphics Memory: 128 MB
    The smallest memory size your system must reserve for CPU/Graphics sharing.
  • Maximum Graphics Memory: 1341 MB
    The largest chunk your system can configure for sharing.
From the DirectX report you can see, it currently uses 27 MB only.
Your laptop lacks the CPU and graphics power to run high demand games anyway, so 128 MB of shared memory should be sufficient. You can configure this to 256 or 512 MB in the BIOS configuration menu, but I doubt it will make any noticeable difference for you.
Feb 07, 2010 | Toshiba Satellite Laptop
My motherboard is IntelD845PESV. i use 512 mb DDR 1 RAm & 64 mb Nvidia Geforce 2 Mx/Mx 400 AGP card. Now, i want to upgrate the AGP and RAM . In the intel site maximum RAM supported by this...
Look in the BIOS, under the video ram settings. What is the largest RAM it can handle? 128? 256? 512? This will give you an indication as the size of video RAM that you can have on your card.
Hope this helps.
Nov 09, 2009 | Intel D845PESV Motherboard
What is the minimuim requirements on resident evil 5
Yeah maybe but it gonna be SLOW so I dont recommend it. you should have a better computer.
Resident Evil 5
Publisher: Capcom
Developer: Capcom
Minimum System Requirements
OS: Windows XP
Processor: AMD Athlon64 X2/Intel Pentium D series
Memory: 1 GB
Hard Drive: 8 GB Free
Video Memory: 256 MB (ATI Radeon HD 2400/NVIDIA GeForce 6800)
Sound Card: DirectX Compatible
DirectX: 9.0c
Keyboard and Mouse
DVD Rom Drive
Recommended System Requirements
OS: Windows Vista
Processor: AMD Phenom X4/Intel Core 2 Quad series
Memory: 2 GB
Video Memory: 512 MB (ATI Radeon HD 4800/NVIDIA GeForce 9800)
DirectX: 10
Keyboard and Mouse
DVD Rom Drive
Aug 17, 2009 | Intel DG31PR Motherboard
Loss of Ram in D102G intel Board
hello, you just have a shared memory with the on-board ati graphics, if it's on- board graphic card it shares the system memory-most are adjustable through the system bios-in 64,128,256 settings. and if you put more memory, in most cases it will automatic-raise the memory size of the graphics memory. i hope this helps you, all the best. if you need further assistance reply. don't forget to rate this solution.
Mar 25, 2009 | ASUS P4B533-VM Motherboard
Loud ring while trying to boot for first time with Asus P5Q3
Hi im josh in cebu phils. may i help you. i got the same problem last week when i bought intel board. the same problem you have a long loud beep in the first boot. it is a video card problem.if you are using video card having 128 mb or below it will beep and may damage the motherboard. but when it is higher 128 like 256 or 512 mb it is good. i solved this problem of mine. i hope the same you too. Good luck
Feb 15, 2009 | ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775...
Upgrade the shared graphic memory
there should be a setting in the bios to adjust the shared memory with video.
Feb 02, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Regarding upgradation of SDRAM
hi dear
there is always speed mismatch problem occur when we use low processor & high ram
so try to use 256 ram
also try to use 1 slot of 256 ram & 2 slots of 128 ram diffrently
& compare the speed
hope it will help to u
Jul 08, 2008 | ASUS SiS Chipset CUSI-FX Motherboard
Computers & Internet Logo
132 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
