Question about Samsung SC-148 CD-ROM Drive
My samsung cd rom sc 148c is not working i am getting this message under properities Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) i have windows xp please help
  • tabatha_1719 Apr 19, 2009
    i can only get the erroe to come up under device manager the cd player isnt even in my computer i tryed uninstalling and reinstalling but that didnt work i also tryed updateing it that didnt work eather
  • Philip Mikaelian
    Philip Mikaelian May 11, 2010
    Is it listed in My Computer? Or you only able to see it in a device manager?
  • 107 Answers
If it's not a SATA drive try to set your IDE Controller in Device Manager to use DMA mode not the PIO. If it won't help try to find updated firmware for your drive and install it. Read Carefully Installation Manual Before! If it won't help that's a sign that your PC wants you to upgrade it with DVD/RW instead.
Good Luck!
Posted on Apr 19, 2009
Re: Samsung CD-Rom SC-148C in Dell Dimension 2350 Cannot eject/open tray to CD-Rom - I have tried ejecting tray while re-booting from setup to see if its a software problem of some kind. I've...
  1. Turn off the power to the computer.
  2. Insert a steel rod (about 1.3 mm in diameter) into the emergency eject hole and push hard. (A stiff paper clip may be used).
  3. The disc tray is ejected a short distance. Pull it all the way open by hand. roadfox_2.jpg
Jun 01, 2011 | Samsung SC-148 CD-ROM Drive
Hi, The DVD/CD Rom Icon has dissapeared on My Computer. When I go to control panel - device manager and click on the dvd/cd rom drive icon I get the following message in the genaral...
You will need to re-install the driver. Right click the device in device manager and select properties. Navigate to the driver section and uninstall all existing drivers. (It may *not* give you the option to do that, depending on how corrupted the driver is, but it should.)
Reboot the PC.
Upon reboot, Windows should find the new device and install generic drivers. It will probably ask you to reboot a second time.
Apr 07, 2011 | LG GSA H62N Super-Multi - Disk drive - DVD...
My samsung cd-rom sc-148c drive is not working. It is not listed in "My Computer". I have uninstalled and reinstalled it but that does not work.
Is the CD-ROM drive on a separate cable on the second IDE controller on the desktop motherboard? Then the jumper setting can be set to Master or Slave if no other drive is connector to this cable.
If the CD-ROM is also on the first IDE controller and IDE cable as the hard drive then the jumper setting on the CD-ROM must be set to SLAVE because the hard drive would be jumpered as MASTER.
Check the BIOS setting to see if the CD-ROM drive is detected.
If the CD-ROM still does not work after you checked and configured the CD-ROM drive, then is is faulty and needs to be replaced.
Dec 16, 2009 | Samsung SC-148 CD-ROM Drive
My samsung cd-rom sc-148c on a dell pc does not open anymore. The indicaterlight does not work too. What to do?
It sounds as if either the power cable on the back of the drive has come loose, check first before going further, if that is still connected then the most likely scenario is that the drive died. You can pick up cd or dvd burner at any computer store for around $30 max. Hope this helps.
Apr 23, 2009 | Samsung SC-148 CD-ROM Drive
Have a Dell 667Mhz 64mbit ram pc w/windows 98 on
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Mar 29, 2009 | Samsung SC-148 CD-ROM Drive
CD ROM not working
from microsofts site:
Code 10 loadTOCNode(2, 'moreinformation'); If the device has a "FailReasonString" value in its hardware key, that string is displayed as the error message. The driver or enumerator places this registry string value there. If there is no "FailReasonString" in the hardware key, the following generic error message is displayed:
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
Try upgrading the device drivers for this device.
Solution button: Update Driver
To resolve this error code, make sure the device is connected to the computer correctly. For example, make sure all cables are plugged in fully and that all adapter cards are properly seated. Follow the suggested solution button and update the device driver. It may be possible to remove the device and redetect it using the Add New Hardware wizard
Dec 26, 2007 | Acer Aspire™ T180 PC Desktop
Dvd cd-rom
Which OS you are used.if You used windows 98 then boot up your pc with bootable windows 98 cd,it loads cd rom driver automatically.
Oct 07, 2007 | LG CRN 8245B (CRN-8245B) Internal 24x...
Samsung SC-148 CD-ROM Drive Logo
1,159 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
