Question about Fantom Vacums FM760 Twister 500DX Bagless Upright Cyclonic Vacuum
My vacuum cleaner stop working
It has always work right, today i got a party and dont want start again. thankyou...
0 characters
1 Points
The vacuum cleaner that we just purchased about a month ago will not start today. I have no idea why. Help!
Plug another item into the wall socket and see if it works. If it does, plug the vacuum cleaner in and see if it works. If it doesn't take it back for replacement.
Apr 26, 2016 | Vacuums
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
My Dyson DC07 vacuum started to run slower after being on for a little while and then would run normally again. I have switched on today and it has just stopped. When I push the start button, on...
The motor running slower was the motor starting to burn out. The "almost start" is the brushes making intermittent contact with the armature in the motor.
Your machine needs a new motor Pam.
Jan 18, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
No water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
May 18, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a Bissell Pro Heat 2X carpet cleaner and the brushes spin, then stop. I turn it off and when I re-start, the brushes do not spin until I push foreward. The it spins and stops again. Both belts are...
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Jul 14, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Vacuum pick up stopped
I noticed a flap covering the filter and this hindered the air flow. I made sure it wasn't covered and, Wa-La, it works perfectly again.
Thanks anyway.
Dec 22, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Power head stops and starts
Sounds like there is definately something stuck inside it. You;ll need to dismantle the floor head carefully using a screwdriver. Make sure your machine is switched off though if it is a power head and not an air turbine turbo head. Once inside check the main roller brush as well as the side caps as these can become clogged. Also check the main dirt channel leading to the pipes of the vacuum.
Dont forget to rate, thanks.
May 25, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Hi i've had the same problem Put a phial of Kal stop into 1000 or 1500ml of water into the tank, let it heat up and it should break down the limescale of the solenoid. It's worked for me. Have a good evening;-)
Dec 10, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Majestic filter queen canister vacuum cleaner
It will work again if you press the reset button which is the little (really little) button right on the back of the part that suctions.
Apr 13, 2007 | Filter Queen Cheetah II Ash - MU305...
Fantom Vacums FM760 Twister 500DX Bagless Upright Cyclonic Vacuum Logo
51 people viewed this question
Top Fantom Vacums Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
