Question about ASUS motherboard P5S-MX SE LGA775 SiS671FX Dual core / Core2 Duo PCI-E integrated VGA micro ATX P5... (4719543152454)
Computer is not functioning
When i press the power button the cpu fan turns a split second only, then it stop. i am wondering if it is my power supply or mother board is faulty, but the lead in the motherboard is lighting, so its a sign that my power supply is giving power to the mother board, that's what i think. can some one please help me.
  • ultimitloozr May 11, 2010
    The LED is probably indicating that you are getting +5V to the motherboard. The PSU may be having issues with the +12V rail. Have you added any hardware to the system lately? If so, have you exceeded the +12V rating of the PSU? Many of the fast graphics cards **** a lot of juice from the +12V rail and you may need to get a bigger PSU to support the card. There is also a large drain on iit, especially during startup, when the drives attempt to spin up and if you have multiple internal hard drives attempting to start at the same time, it can cause the same type of problem.
    Scholar:
  • 83 Answers
H!
Please check the lock of your processor. If it is tight or loose. If it is loose then it is the one causing the mother board no to function properly. You must tighten it to make it stable. After checking and it is not the reason for the malfunctioning of the system. Try to remove your CMOS battery and then clean, and remove also your memory card in the mother board and clean. Return it after cleaning and then close the CPU and turn it on. During the booting process strike the delete key to enter into bios set up. Adjust the time/ date settings to your current time. Press F10 then enter. wait for the CPU to process.
Please post any comment if it was solve so that I can give you more option if it does not solve your problem.
jonags3
Posted on May 16, 2009
Will not power up. Replaced bad power supply(burned circuit board inside PSU) but still does not power up, PSU is ok. When power on button is pushed CPU fan turns for about 1/2 second but nothing else....
Sounds to me like when the power supply went out it allowed a surge to hit the mother board and you will have to replace it also .Look at the mother board and see if there is a green LED light showing if it is you are getting power to it and you have capacitors blown if not recheck you connections from the power supply and MB if they are all tight and correct then just figure on replacing the mother board
Sep 01, 2011 | Biostar M7VKB Motherboard
Gateway Desktop GM5626: Would not power-up, replaced Power Supply; Then Mother Board beep once when trying to turn-on; replaced Mother Board; Mother Board lights on, but when I try to turn on the CPU...
some powersuplay comes with 2 extra connectors a 4pin based switch connector and a alternate power supply for the fan...you must to be sure if it is comatible......check the model and search on google for compatibility ...
May 31, 2011 | Computers & Internet
Cpu fan problem
If you plugged the replacement fan into the power supply instead of the "male plug on the mother board" you will get that error message. You need to find a fan that has the female plug for the mother board. It solved my problem.
Paul C.
Apr 22, 2010 | Nuvico NVDV3-16000N
No power,power supply seems ok,green light on mother board on. when pluged in the fan runs for a couple seconds and turns off.power button has no effect.
sounds like a mother board issue,
start with pulling out all ram chips and re try,,
then try pulling all cards out like old modem and also cdroms.
if ever thing but power is unpluged its a bad mother board or CPU chip
Mar 12, 2010 | E-Machines T3958 (827103050974) PC Desktop
The purple light is flashing in the front and tries to start and won't turn on. disconnected power cord and held button in for thirty seconds still have same issue what could it be?
This can be a faulty power supply or a damaged mother board. here's how you can confirm.
When pressing the power button, inspect the cooling fan that is located on the back of the power unit where the power cord plugs in. if the fan starts then stops immediately, this will confirm a damaged power supply.
Now, if the fan continues to operate but, the CPU doesn't start to power up and load the OS, thsi will confirm a mother board issue. replace the mother board in this case.
Jun 21, 2009 | E-Machines T6216 (827103077834) PC Desktop
Power supply Ok.But CPU fans started with seconds It's stop.
sounds to me like your mainboard is bad, i bet if you closely inspect the capacitors around the cpu one or more is bulged out or leaking
Feb 15, 2009 | Asrock P4S61 Motherboard
Curly one
Hi
there is way to find out
First ,disconnect all power cable and data cable from hdd,fdd,and remove all pci devices.
Now you have to check your pc mother board not touch to your pc case.
Second, check heat sink on cpu is mount properly check ram also.
now check on button if it is ok push it to on.
if now occouring same problem.
change cpu and check
if the problem is not solved you mother board is faulty.
Jul 30, 2008 | Dell OptiPlex GX520 PC Desktop
Power of
This happens because your CPU is overheating, open your PC and blow any dust off the openings and CPU/Power supply fans, if you think one of the fans is not working... replace it.
Jan 24, 2008 | Computers & Internet
Power supply and CPU fan problem
you dint mention the mother board u are using in some motherboards jumber setting can power up the system check the jumber setting in the mother board near ur front pannel pins in ur motherboard
Oct 21, 2007 | Biostar K8M800-M7A Motherboard
ASUS motherboard P5S-MX SE LGA775 SiS671FX Dual core / Core2 Duo PCI-E integrated VGA micro ATX P5... (4719543152454) Logo
168 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
