Question about Motorola Mobility RAZR V3
Unidentified ringtone When i try to set a certain ringtone for a person, not all the ringtones i have will show up. But a blank space does, when i click to listen to it-it sounds like a ring tone with no words. I have no idea where it came from, but since its invisibly there, i cannot delete it. Since its been there, my bluetooth hasn't worked either. I need to know how to get rid of this ringtone.
    Brigadier General:
  • 7,752 Answers
Master clear and reset the phone if that does not work have the phone's firmware reflash.
Posted on Feb 17, 2008
6ya staff
SOURCE:
Rigton
get it from here : http://www.ventones.com
it is supported by tmobile phones also
to set new rington :
Find the song you want to use as a ringtone -- look in Music on your widgets menu.
Press and hold the song and a menu will pop up. Select "Use as ringtone."
You can do this with multiple songs and they will show up in your list of ringtones. You can then set them for personal ringtones, etc.
Mar 04, 2011 | Motorola Mobility CLIQ Cell Phone
Tip
How to Edit Ringtone to iPhone 4
AVS Ringtone Maker is a powerful ringtones maker to editor and creator. It is a program which will help you to make a bright and short ringtone from your favourite MP3 musical composition to your iPhone.
This Ringtone Maker supports available interface and tech-support in English, French, German, Spanish and Italian. So no matter where you are from, you can use this software to edit ringtone to iPhone, either. Meanwhile, it supports all iPhone types including iPhone 4.
Tired of buying iPhone ringtones from iTunes? Well, here's your solution. You can completely edit your personal ringtone to your iPhone by following the guide below.
OK, no time to waste. Let's find the fast and safe way to edit ringtone to iPhone 4 together. Find something useful for editing ringtone to iPhone 4 now.
Guide:How to Edit Ringtone to iPhone 4
Steps as follows shows how to edit ringtone to iPhone 4 with the AVS Ringtone Maker.
Step 1: Install and run the software to input the file.
Step 2: Pick the songs you want to edit and listen to it before you create your personal ringtone.
begin to edit your ringtone to iphone 4
Step 3: Trim, cut out the needed part, and delete the unnecessary parts, then click the "Save" buttom.
save the ringtone that you have converted just now
That's all.
With this smart iPhone ringtone converter, you can get edit iphone 4 ringtones easily and quickly. You can make and transfer personal iPhone ringtone just in a few minutes. Come and have a try now!
Connected information : iphone ringtone blackberry ringtone mp3 ringtone music converter
on Jul 15, 2010 | Computers & Internet
How do I assign a ringtone to a person when the ringtone is sitting in my message inbox?
click on the message inbox ,then go the ringtones then stroll down o sound .selected ringtones you want,then it will gave you a option to set a ringtone for this person ..click on set as ringtones and that will allow you ringtones you assign for the person
May 20, 2010 | Samsung SYNC SGH-A707 Cellular Phone
Ringtones
First Make sure your contacts are saved to the phone as to now im sure they are saved to your sim card... Then pull up the person and go to edit scroll down to "Custom ring tone" and hit the ring tone you want and hit done..
May 05, 2009 | Samsung BlackJack II Smartphone
I just got an LG Vu, trouble w/ ring tones
Go to 'Options' down in the bottom right corner and select 'Set As'. There, another window should pop up and have the options 'Ringtone' and "Ringtone ID'. Ringtone ID should allow you to set it for a certain contact.
Mar 10, 2009 | LG Vu CU920 Cellular Phone
Setting up ringtones for specific callers on a krazr k1
go into the phone book find the person you want to set the ringtone for click on there name and scroll down it should show ringtone click on that and find the ringtone you want to set as for that person as for other peoples ringtones do the same thing
Jan 17, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Ringtones
You need to go into groups and for each group select a ringtone for that group . Then the other ringtone you selected on settings will ring when a person who you do not have in a group will be used .
Hope i helped xD
x
Oct 14, 2008 | LG KG800 Cellular Phone
How do I set a ringtone for a certain person?
When you save a ringtone, I've found that mine only show up when saved under 'My Documents', no subfolders. So save it there, and then go to 'Contacts'. Select your contact and push 'Menu' > 'Edit'. Scroll way down and you'll see 'Custom Ringtone'. Your ringtone should be in that list.
;D
Jul 16, 2008 | Pantech Duo Smartphone
Ringtone problem
You settings are not activated so please refer your phone user manual do the steps by step then it will work fine
1) First save the specific number
2) Select the ring tone
3) Assign the this ring tone for that number
This information help to you othere wise refer your phone user manuals
Jun 11, 2008 | LG VX8300 Cellular Phone
Assigning downloaded ringtones Razr V3a
Before you can assign a ringtone to a contact, you must first go to "settings" and then to "ring styles". Click on "Detail" and go down to "Ringer IDs". Make sure it says "On". After that, you should be able to assign a ringtone to a contact by editing the contact details. (Custom ringtones are at the bottom of the list instead of at the top.) Hope that helps.
May 30, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
