Question about Evesham Axis PC Desktop
Remastering help ive got a virus that has attacked my registry and disabled me dvd drive and need to remaster it but since i cannot use the drive i was wondering if there is another way of doing it. my pc is a desktop which is put together by evesham technology.
  • lesj58 Apr 17, 2009
    i am using vista premium its an internal dvd drive and ive tried a system restore which didnt seem to do anything
  • Greg Margossian
    Greg Margossian May 11, 2010
    What operating system do you have? Have you tried doing a System Restore?
  • 1,959 Answers
If the virus hasn't been repaired, go here and run the free virus scan and repair. Afterwards, if the problem isn't resolved, post back here and I'll try to help. http://housecall.trendmicro.com/
Posted on Apr 17, 2009
Try to install the virus scanner into a thumb drive/flash drive that uses the USB port.
Error code CE - 3316 - 4 for The Last of Us Remastered
connection error 3316 u have to reset your ps4 controller . on the back there should be a small hole that u can insert a needle through then reset it then connect it through wire and it should work fine.
Jun 12, 2016 | Sony PlayStation 4
Tip
Enable the Registry Editor, Task Manager and Folder Options Disabled by Viru
Virus attack is common these days and we often come across the problems like Disabled Folder Options or like Task Manager and Regedit disabled by Administrator. These problems are nothing but virus activities. The virus has infected our system and stopping us from accessing these options.
Pressing keys Ctrl+Alt+Del opens up a dialog saying that “Task Manager has been disabled by your Administrator” whereas you are the Administrator yourself. It becomes very annoying when you think that you can fix this problem by going into the Registry Editor but it doesn’t show up. Even the Folder Options gets disabled.
This problem is generally caused by a virus named “Brontok” but don’t worry just use RRT (Remove Restrictions Tool) that can easily solve this problem. RRT is free and can successfully enable:
1. Folder Options
2. Regedit (Registry Editor)
3. Task Manager
4. Show Hidden Files option
The tool will come more useful if you use it in Safe Mode.
Download RRT
on Nov 17, 2008 | Microsoft Windows XP Professional With...
I need the unlock code to nancy drew secrets can kill remastered
I'm sorry but this is not a warez site....We can't give out activation keys or access codes.
Sep 08, 2012 | Her Interactive Nancy Drew: Trail of The...
Lost installation cd for windows xp
if that lost cd was genuine then try to activate your windows by calling the telephone service...and try to remaster an image from the os and then burn to a cd..!!
Oct 21, 2009 | Olympus VN-960PC
DVD plays OK on computer but not on Sony DVD player
It must not be compatible with you player.
Refer to your manual.
Robert
Oct 12, 2009 | Sony Televison & Video
I have windows xp a lot of times when I restart my computer a white screen comes up it wont re-boot at times it boots up with a white screen
sounds like its a software problem , however its wise to rule out if its a hardware problem, best thing to do is try to start it up in safemode , this is easily done by retarting comp and pressing F8. now if safe mode shows your desktop it is most likely software, save any file you dont want to loose and try remastering if your comp came with installation disc restart with disc inside . if not it probably has a partition you need to look in manual for the remastering solution to this , could be retart f11 or retart f8 , every comp is different , best advice is to google your model for remastering my computer. good luck
Aug 31, 2009 | HP Pavilion A720N PC Desktop
DVD-RW optical drive not working properly
The two symptoms could be attributed to a viral activity. Some viruses will disable your CD/dvd burner for the reasons you cannot make a backup copy with your important files.
I suggest, it is safer to scan your harddrive using another clean computer with a good antivirus and malware remover.
Even I too experienced that everytime when you access cmd,msconfig,task manager, sytem restore, registry editor there's some kind of counter. Until you reach the number of times you access that it will release its destructive job. For me it also block me of using USB, even floppy.
Commonly this is a Vundo activity. Many free antivirus can disinfect this. Disinfecting directly from its own hard drive. But the risk of your important files is the priority that is why I suggest to it using another computer. But it is your call.
I recommend Avira, malwarebytes antimalware. Install, update then scan. And still check your DVD burner for hardware defect.
I think this should be enough. Just ask again.
May 29, 2009 | Computers & Internet
Toshiba a200/205 series Hard disk is toshiba mk1246gsx need compatible driver for windows xp I need to convert my OS from vista to XP
Well... this is common on newer laptops. It is due to the fact your HDD is SATA (Serial ATA) and Windows XP CD does not have the drivers needed to recognize it. The solution I use is a bit High Tech: to remaster your Windows XP CD including the drivers needed. Or, just settle to live with Vista until January, when Windows 7 will be available to the public. If you are not faint of heart, google this: nLite; with this program you can remaster your XP CD. (You need a working PC with CD-RW to actually do the job).
Apr 14, 2009 | Toshiba Satellite A135-S2386 Notebook...
My task manager has been disabled due to virus attack. help me
There is a registry hack to enable or disable Windows NT TaskManager. The same registry hack applies to Windows 2000 and Windows XP. Hive: HKEY_CURRENT_USER
Key: Software\Microsoft\Windows\CurrentVersion\Policies\System
Type: REG_DWORD
Value: 1=Enablethis key, that is DISABLE TaskManager
Value: 0=Disablethis key, that is Don't Disable, Enable TaskManager
As part of the enhanced management available in Windows 2000 and Windows XP, rather than risking a registry change, as an administrator you can enable or disable Windows 2000 Pro or Windows XP Pro's TaskManager using Group Policy Editor. This can be applied to the local policy. Note: if you are trying to override your organizations group policy, you can't. As soon as you re-authenticate to the domain, the domain or OU Group Policy will rewrite the registry setting. But if the TaskManager was accidently disabled or you need to control this item for a set of standalone boxes this is for you:
  • Click Start
  • Click Run
  • Enter gpedit.msc in the Open box and click OK
  • In the Group Policy settings window
    • Select User Configuration
    • Select Administrative Templates
    • Select System
    • Select Ctrl+Alt+Delete options
    • Select Remove Task Manager
    • Double-click the Remove Task Manager option
And as I mentioned above, since the policy is Remove Task Manager, by disabling the policy, you are enabling the Task Manager.
Mar 23, 2009 | Internet Grisoft AVG Security Full...
Map drive disconnect
Hello Sunilshetty
Happy Holidays
A lot things arise from this particular problem, but, perhaps if you go into mapping properties, and see if disconec function is enable, you can change to disable. another way is assing a fixed letter for this drive.
good luck
Dec 13, 2007 | Audio Players & Recorders
Evesham Axis PC Desktop Logo
78 people viewed this question
Top Evesham Computers & Internet Experts
Lakshman P
Anwarul Haque
Anwarul Haque
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
