Pc won't power up,already tried a new power supply
  • msteins Apr 19, 2009
    no lights
    yes it is on
    nothing shows up
    no beep codes
  • charles raynor May 11, 2010
    Do any lights come on when you try to boot?
    Is there a switch on your new power supply, and is it in the on position?
    Is there anything at all that shows up on your monitor when you try to boot?
    Are you getting any beep codes?
  • 62 Answers
Ok, While I realize you have a new power supply, and assuming it is still installed, pull the main connector from the motherboard and jump across from the green wire to one of the black wires next to it just long enough to see if the PS fan starts.If it does, then check all the wires from the MB to the front panel of your box.
If all are in their proper place, reset your bios by removing the battery for 20 minutes.
If still no joy, make sure all your memory sticks are well seated, along with all your PCI/AGP/PCI-E cards and cables for your hard drives.
If you still can't power up, replace your MB
Posted on Apr 19, 2009
If you put the motherboard in - make sure there is no dead short from case to pcb from any metal standoffs / supports in any position OTHER than a mounting hole.
see if get bios beeps with no memory in - can try same by removing video card - if you get error beeps, memory or vidcard need a closer check for spec, seating etc
Posted on Feb 03, 2010
Compaq Presario CQ60 won't turn on
If you already replaced the motherboard then try replacing the power cord. If you meant you replaced the cord already, the it might be your motherboard is bad.
May 15, 2012 | Compaq Presario CQ60-220US PC Laptop
My PC power supply crashed, burnt resistors, Powerman IW-P250A3-1 20 pin plug to motherboard, bought new power source, but the old power source had a white cable to the 20 pin plug which was -5vdc 0.3amp....
For your system to boot up properly, you need an identical power supply for your system. Most likely the reason why your system won't boot up right now is because you purchased a different power supply and it is lacking something(which is the other pin).
Regards
Sep 14, 2011 | Computers & Internet
I went to turn on my Samsung a little bit ago, which was working earlier today, and now it won't turn on and is making a clicking noise. The noise does not stop until 10 seconds after I unplug it...
The tv power supply board it got short and already dead some how,tv have clicking noises mean ur tv power supply board are not stable and not regulating high voltages to the rest of the tv other boards.The tv power supply board that the board where the a/c power cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
No power
HERE'S THE ANSWER TO YOUR PROBLEM:
The main reason why your TV won't turn on is because of its power supply board. This power supply board are composed of capacitors that are the responsible for the proper supply of current to your TV. If one or many of these capacitors are already burned out or "dead" your TV won't turn on at all. Here's what you've got to do:
1. Open your TV or let somebody do it, much better a technician.
2. Check the Power Supply Board.
3. Check the capacitors. Remove the "dead" ones and replaced it with "new" ones. You can buy capacitors to the nearest hardware in your town, or to your service provider.
I would suggest you to do it with a presence of a TV technician, so that you will be guided properly. Thanks for your question. I hope it helps....
Jul 21, 2011 | Televison & Video
The PC is dead, no fans run or anything. It will not power up so I bought a new power supply and installed it but still the same issue? It does have 120 vac power into the power supply.
maybe your CPU is busted.try to replaced a new processor and test it.or double check the setting of the power on *********** board switch,maybe you inserted wrong.
Jul 11, 2011 | Computers & Internet
Dear sir! my dell optiplex gx 150 won't start when i press the power button but power supply will be start and pc can't give any beep ?
try to remove the power cable on that product and then hold the power button for 8 secs. Reinsert back the power cable and press the power button. If it won't turn on, then the power supply is the main cause of trouble. Contact dell right away for repair...
Jun 22, 2011 | Dell OptiPlex GX280 PC Desktop
Storm knocked power off late yesterday afternoon....back on this morning. PC won't power up....small green light on back flashing. Modem, router, etc. all back up and running, but PC won't turn...
The first thing to try is to cycle the power. To do this, unplug the power cord from the back of the PC and press and hold down the power button on the PC for 5 seconds. This will completely drain any "stuck" power in the components. Now plug the power back into the PC and try booting. If it still does not come back on after this, then you may be dealing with a blown power supply. You can buy replacement power supplies from your local PC shop for about $50 for a 400watt.
To protect your devices in the future, make sure you have a good surge protector and / or a UPS (uninterrupted power supply).
Regards, Chris
May 25, 2011 | HP Pavilion a350n PC Desktop
When I start my computer it runs for 5 seconds and turns off tried a new power supply but same thing happens
Welcome to FixYa
If you already replaced the power supply of the system then the next most logical step is to replace the motherboard. Power problems with computers is usually caused by a defective power supply or motherboard.
Hope this helps
May 02, 2011 | Compaq Presario S4110CL PC Desktop
When i power on the PC no beep, no image, led inside PC lights ON OFF green light Please help me (my PC is HP- P4SD motherboard)
when PC cannot boot there is probably failure on installation RAM, VGA (external), or Power Supply. in your case (no beep) maybe it is your power supply don't have enough power to boot or its already damaged. try to another power supply with higher voltage (watt), or change with the new ones. hope this useful, regard riyan.
Mar 30, 2011 | Intel P4 System Configurator (P4SDRAM1) PC...
System doesn't boot up
Hi..
Try to use a new power supply, the power supply can not reach the voltage that have some components of the power supply are faulty already you need to replace the power supply.
Regards
ICmanServer
Aug 01, 2009 | Dell Dimension 4550 PC Desktop
Computers & Internet Logo
215 people viewed this question
David Payne
David Payne
