SOURCE: maintenance tank almost full
I opened up my tank under some water flushed everything out of it, put in some sponge, then get a chip re-setter (off ebay for less than £5.00) reset the chip so your back to 100%, done and saved 20 pound each for both tacks each time.
SOURCE: Epson rx620-waste ink pad replacement Instructions
No Problems M8!
Here is the manual for your printer
http://files.support.epson.com/pdf/rx620_/rx620_qr.pdf
Good luck to you
If you find my answer helpfull, dont forget to vote!
SOURCE: Clean "Waste Ink Cartridge" Epson R300
Had the same problem. (its a work around without removing the waste ink pad)
Took alot of work but I fixed it.
Frist thing you need to know that error means your ink waste pad is
full. Its a $75.00 to replace but there is a work around it.
You will need this free app. SSC service utitlty.
http://inkjetprinterhelp.us/epsonSSC.html Its a great app.
Instrusctions are on the website there.
You will also have to Open the access panel on the rear of the printer (remove screw) and
look inside carefullly with a flashlight. You will see a tube (down and
to your left) coming from the cleaning pump and it will have an open
end on it. This is the tube that delivers ink to the waste pad.
Use a piece of coat hanger wire or equivalent, and fish out this
piece of tube. Bring it to the outside of the printer, thru the access
panel.
Find yourself a suitable container
(Tupperware or a plastic cup or jar) that is not too tall. Put the tube
into this container and secure the tube and container so they won’t
come apart or lose connection if the printer is moved.
If you wish you can make a hole or notch in the access panel cover so it can be replaced.
SOURCE: EPSON 2200 - Waste Ink Pad Replacement
You can replace the pads yourself.... I wouldn't really mess with it though. There are other ways Google search "Waste Ink Epson 2200" to see how to setup an external tank.. I have mine setup this way and its been no problem.... If you're set on taking them out remove the screws from the sides and middle and the bottom will drop away and reveal the pads.
SOURCE: Waste ink full How i 'll reset my printer epson dx4450
Sorry to say that there isn't currently a confirmed reset utility available on any of the usual sites...
The only POSSIBLE option I found that MIGHT work is the CX5600/DX4400 adjustment utility from 2manuals
Best of luck and hope you find a usable solution.
