Question about Frigidaire GLER331A Electric Dryer
Beko DRCS68 condensor dryer is making loud vibration noises
I replaced the belt and it was working fine for a week and now if i turn it on it makes loud noise. i have checked screws and all were tight. baring looks central. any ideas what could be wrong.
cheers.
I found a coin in mine tipped dryer on side span the drum slowly and it fell out woohoo
Posted on Oct 05, 2014
    Scholar:
  • 123 Answers
Hi there......when you replaced the drive belt you most likley disturbed the drum on its bearing seats (small plastic curved units) or indeed knocked 1 out altogeathrer...this would account for the loud bearing or metallic sound...it may also be the rear bearing these tend to eventually rund dry and fail..
regards Sir GalAHAD
Posted on Aug 23, 2009
2 Suggested Answers
SOURCE: Beko tumble dryer not drying.
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Posted on Aug 20, 2008
Beko condensing dryer Model DRCS68. Hi, my dryer is tripping my electrics as soon as I turn the power on at the fuse spur. Any help on what else could be faulty that is tripping my electrics?
Are your fuses the proper size to run that dryer? A person I know put twenty amp fuses and could not understand why they kept blowing. I am not sure but I think it takes thirty amp fuses.. That's what we put in hers.
Are you sure its wired properly when you replaced the element.
Could be a short some place as well.
Oct 31, 2016 | Dryers
Beko DRVS6W tumble dryer squeaks when the drum comes to a halt
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
May 22, 2015 | Beko DSV64W White Vented Tumble Dryer 6...
Beko WM6355W wahing machine makes a clicking noise when the drum turns, the noise gets louder and a smell of burning rubber comes when it spins
sounds like your drive belt is damaged, it may have a small section stripping of the belt and hitting something in the machine as it turns.
take off the back and check the condition and replace as needed.
Aug 29, 2014 | Beko Washing Machines
Hi. my BEKO condensor sensor dryer cuts out the electric mains flip switch when i turn it on. Have checked the fuse and lead no damage, checked socket and it works other appliances. What would cause t
The same happened to our Beko DCU8230 last week still under 1 year warranty, loud bang, burning smell and trip switch flipped. Beko Engineer who called said mains suppressor capacitor had blown.
Aug 27, 2012 | Dryers
My beko condensor dryer is not turning anymore, the heat is fine but it doesn't tumble
Drum will not turn or rotate
1.broken or slipping belt---replace belt
2.jammed or bearings frozen ----check for foreign article between drum & shroud
Replace defective bearing or bearing support which allows drum to sag or hit
3.loose pulley----tighten pulley set screw
Sep 22, 2011 | Dryers
Beko dryer, drum is turning and heating up fine but making a loud scrapping/rubbing noise, what could it be?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 08, 2011 | Dryers
My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
Looks daunting to start with but just done mine,
remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
Feb 07, 2011 | Dryers
As soon as we turn on the dryer it's really loud and vibrates a ton. It just started one day
Hello
First make sure that its properly balanced, if the issue remains then it is due to the belt that is bad and its time for belt replacement. Usually loud noise comes when the belt is either worn out or broke. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | Maytag Dryers
Candy cc217-80 condensor dryer manual - I need to replace the belt and not too sure how to get to it
hi iv just bought a second hand condenser dryer its the candy cc2 17 and it squakes and make a loud noise what can i do to fix it??
Sep 23, 2010 | Dryers
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
Apr 23, 2008 | Dryers
Frigidaire GLER331A Electric Dryer Logo
1,015 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
