Question about HP PSC 1315 All-In-One InkJet Printer
Will not print
I changed the ink cartridge in the printer and did not run the Align function. The printer will not print at all until I run this function. How do I do it?
    Scholar:
  • 84 Answers
Take the cartridge out and reinsert it. This should trigger off the alignment tool again. Otherwise look on your programs menu for utilities to change cartridge. Assuming you have XP follow this Click on start Click on printers & faxes Double click on your printer Click on printer Click on properties Click on advanced Click on printing defaults Click on services Open HP Toolbox (or whatever your option is) There you should see align Hope this helps
Posted on Sep 17, 2007
SOURCE:
New black cartridge horz lines cleaned head &cartridge roller ; bought new cartridge still lines
Try to clean the print cartridge nozzles:
  1. On the printer control panel, press Menu.
  2. Press the down arrow button until you highlight Clean Cartridge. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  3. Print the document again to verify that print quality has improved.
  4. If print quality has not improved, try cleaning the print cartridge nozzles up to two more times.
You can also try to align the cartridges:
  1. On the printer operator panel, press Menu.
  2. Press the down arrow button until you highlight Align Cartridge. Press Select.
Jul 28, 2011 | Lexmark P4350 All-In-One InkJet Printer
After changing ink carteidge it keep saying align cartridge, what can i do to erase this error?
It is my pleasure to guide you.
These steps will take you through the process of replacement and alignment.
HP PSC 2175 All-In-One InkJet Printer
1. Turn on the unit, then open the print-carriage access door by lifting the
handle until the door locks into place. The print carriage moves to the center of the unit.
2. After the carriage stops moving, lift the latch to release the print cartridge, then pull it toward you out of its slot.
3. If you are removing the black print cartridge in order to install the photo print cartridge, store it in the print cartridge protector.
4. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape.
Caution! Do not touch the copper contacts or ink nozzles.
5. Push the new print cartridge into the appropriate slot until it clicks into place. The tri-color print cartridge goes on the left and the black or photo print cartridge goes on the right.
6. Pull the end of the latch toward you, press down until it stops, and then release. Make sure the latch catches below the bottom tabs.
7. Close the print-carriage access door.
align the print cartridges
The HP PSC prompts you to align cartridges every time you install or replace a print cartridge.
Aligning the cartridges ensures high-quality output.
To align the print cartridges when prompted:
1. Press Enter on the front panel. A page of patterns is printed. The cartridges are aligned correctly. Recycle or discard the page.
To align the cartridges at any other time:
1. Press Setup.
2. Press 2, then press 2.
This selects Maintenance, and then selects Align Print Cartridges.
I found the manual for this printer, if you do not have it already. If you wish to download it click or copy this link
http://h10032.www1.hp.com/ctg/Manual/bpu73527.pdf
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
Jun 15, 2011 | HP PSC 2175 All-In-One InkJet Printer
How do I reset my hp officejet 6110 all-in-one printer? It keeps asking me to align cartridges.
Press menu and then press the Right Arrow key until you get to maintenance screen then press enter.
Option 2 is you align print cartridges.
Automatic cartridge alignment
Perform the following steps to align the ink cartridges:
1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
1. Press Setup or Menu on the front panel (depending on the model).
2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
3. To determine if the automatic alignment is functioning correctly, look into the output tray as the alignment page is printing; a blue light should be visible periodically on the page as the cartridges move back and forth. If this light is not visible, the product will not be able to align the cartridges and will require service. Service the product.
4. If the blue light is visible and the alignment pages are printing correctly, but the alignment pages still fails, there still may be a hardware problem with the unit.
If there are no other printing problems and you wish to continue, use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. The information from last successful alignment will be used.
If the message keeps reappearing or other print quality problems occur, service the product.
Mar 30, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Need to install new ink
Lift the entire top including the scanner portion until it clicks to stay open by itself (like some vehicle hoods). You should see the print head containing all the ink. It will slide back and forth for a moment, this is normal. Wait until it comes to a stop. Notice any blinking lights below the ink cartridges. If the light is solid, there is enough ink. If the light is blinking you'll need to replace that cartridge for the best print quality. Remove the ink by carefully but forcefully pushing on the tab with one finger and holding the back of the cartridge with other. It should simply slide out. Note the EXACT #'s on the ink cartridges. Right down all the information and the type of printer you have and take it to your local best buy or equivalent store, they will give you the replacement cartridges you need. Unwrap the package and carefully remove the orange tab on the bottom by twisting in the direction shown. (You may want to wear rubber gloves because the ink stains fingers badly.) Carefully but forcefully slide the new cartridge in place of the old and push down until you hear a click. The light under the cartridge should now be solid. Once all carts have been replaced close the lid of the printer and give it a moment to situate. Run a print head alignment to manually align all nozzles for best printing quality. Simply click the head align software button and follow the instructions, quite easy. You should be all set and ready to print!
Jun 24, 2010 | Canon PIXMA MP620 All-In-One InkJet...
I have no way of changing the ink cartridge in my printer.
Hi, the information you need is here:
http://support.epson-europe.com/onlineguides/en/sc46/index.htm
Just click on the replacing ink cartridges on the left hand side, follow the instructions and pictures there.
Jan 13, 2010 | Epson Stylus C46 InkJet Printer
How do I change the ink cartridge on my Dell 810 printer
Ink Cartridge Maintenance Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridge:
  1. Load plain paper. For more information, see Loading Paper.
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Right-click the Dell AIO 810 icon.
  2. Click Printing Preferences.
The Printing Preferences dialog box opens.
  1. Click the Maintenance tab.
  2. Click Align Print Cartridge.
  3. Click Print.
A blue and black alignment page prints.
  1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
  1. Press the Scan button scanicoa.jpg .
The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
Hope it helped.
Nov 22, 2009 | Office Equipment & Supplies
My HP printer PSC 1510 All-in-One no longer asks me to align my ink cartridges after a change of cartridges. Now, after a system recovery, it prints an alignment page every time I turn it on, whereas...
The only way to stop this is to press the cancel button, just as it tries to print the test page.
Various people have said the printer won't align (calibrate) successfully unless both ink cartridges are more than 50% full, and until it aligns successfully, it will continue to print the test page on start-up.
It is a total waste of ink and paper, so remember to hit the cancel button when you turn it on.
Apr 11, 2009 | HP PSC 1510 All-In-One InkJet Printer
How to change cartridgeon HP desktop D4160
from HP's web site: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00641960&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN Step one: Replace the old print cartridge
  1. Make sure the product is turned on.
  2. Open the print carriage access door.
  3. Wait until the print carriage moves to the right side of product and is idle and silent.
  4. Press down on the print cartridge to remove it from the slot, and then slide it out of the print carriage.
  5. Remove the new print cartridge from its packaging, and then carefully remove the plastic tape by using the pink pull tab. Figure 1: Remove the tape c00442146.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
  6. Slide the print cartridge at a slight upward angle into the print carriage until it snaps into place. Figure 2: Inserting the print cartridge c00642241.gif
  7. Close the print carriage access door. WARNING: Keep both new and used print cartridges out of the reach of children.
  8. Wait until the print carriage moves to the right side of the product and is idle and silent.
Step two: Align the new print cartridge
  1. Load Letter or A4 size, unused, plain, white paper in the input tray.
  2. Open the printer Toolbox . Follow these steps to open the printer Toolbox .
    1. From the File menu in the software program, click Print . The Print dialog box appears.
    2. Click the Properties button. The Print Properties dialog box appears.
    3. Click the Features tab.
    4. Click Printer services . The printer Toolbox appears.
  3. Click Align the Print Cartridges .
  4. Click Align , and then follow the on-screen instructions. The product prints a test page, aligns the print cartridges, and then calibrates the product. Recycle or discard the test page.
Dec 23, 2007 | HP 83 3-ink Black UV Cartridge Multipack...
Ink cartridge alignment problem
well, what i did, and it seemed to work, in the short run anyway. i took and threw my hp in the back of a waste management truck,  then i called amazon.com and i ordered a new epson printer,
Oct 26, 2007 | HP PhotoSmart C4180 All-in-One Color...
Color Cartridge Failure
You know, I'm not going to read the other solution. I know 100% FOR SURE, when a cartridge fails, it is dead and there is nothing you can do about it, but there is a good side. HP ink cartridges have a year warranty. Call them and tell them it failed, they'll send you a new one!
Sep 18, 2007 | HP PhotoSmart 7760 InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
52 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
